Is this Expression Dimensionally Consistent?
  • Thread starter Thread starter tony873004
The expression v² = 2ax is dimensionally consistent, where v represents velocity in meters per second (m/s), a represents acceleration in meters per second squared (m/s²), and x represents length in meters (m). The factor of 2 is dimensionless, confirming the equation's dimensional consistency. This equation derives from the work-energy theorem, illustrating that velocity squared is directly proportional to the product of acceleration and displacement. Ensuring all terms in equations have the same dimensions is crucial for verifying correctness in advanced dynamics.
  • Understanding of basic physics concepts, specifically kinematics.
  • Familiarity with dimensional analysis and unit conversion.
  • Knowledge of the work-energy theorem in classical mechanics.
  • Basic algebra skills for manipulating equations.
  • Study the work-energy theorem in detail to understand its applications in mechanics.
  • Learn about dimensional analysis techniques for verifying equation consistency.
  • Explore advanced dynamics courses that cover equations of motion (EOM) and their dimensional requirements.
  • Investigate common pitfalls in unit conversion and dimensional analysis in physics problems.
Students of physics, engineers, and anyone involved in mechanics or dynamics who seeks to deepen their understanding of dimensional consistency in equations.
tony873004
Is this expression dimentionally consistent?
[tex]v^2=2ax[/tex]
where v is velocity, a is acceleration and x represents a length in meters.
[tex](m/s)^2=2*m/s^2 * m[/tex]
[tex]m^2/s^2=2*m/s^2 * m[/tex]
[tex]m^2/s^2 = 2 * m^2/s^2[/tex]
I'm not sure if the 2 makes the thing not dimentionally consistent. My guess is since the 2 is unitless, the expression is dimentionally consistent. Any thoughts?
m^2/s^2 = 2m^2/s^2 is correct both dimensionwise and unit-wise
Yes, 2 is dimensionless in this equation. The reason why we 1=2 is because this equation is very specific. By doing this we assume acceleration is constant and that the initial velocity is zero. In fact we we multiply both sides by the mass we have
mv^2 = 2max
F = ma
mv^2 = 2fx
if we assume the force is constant and in the direction of motion we can say
w = fx
im sure you see this now
mv^2/2 = w
KE = w, so the above equation that we started with is actually a derivation from the work energy theorem. And it basically states that work is the change in kinetic energy. more or less velocity squared is directly proportional to the product of acceleration and displacement. So now that the issue of the 2 has been addressed I just want to clear up something else
ft/s^2 is dimensionally correct with m/s^2 as the dimension are both L/T^2
however the equation is not correct by units, in order to make a dimensionally correct equation that has terms with different units into an equation that is correct in both senses, all we need to do is simply multiply by a conversion factor. If you take an advanced dynamics course your EOM's will often have several ugly terms and it is always a good idea to make sure all the terms have the same dimensions. This way if you know the dimensions on a term aren't correct, then you should just accept the fact that the equation in incorrect and there is a mistake in the previous steps, always a good time saver before finalizing any work!
2 dimensionally constant and has no dimensions , can be taken as [itex]M^0L^0T^0[/itex]
