Applications of Integration - Work.
The discussion focuses on the application of integration in calculating work done in lifting a bucket of water from a well. The problem involves a 4 lb bucket filled with 40 lb of water being pulled from an 80 ft deep well, with water leaking at a rate of 0.2 lb/s. The user calculated the total work done as 1600 ft*lb by integrating the force required to lift both the bucket and the leaking water. The calculations included determining the force exerted and setting up the appropriate integral for the work done.
  • Understanding of Calculus II concepts, specifically Applications of Integration
  • Familiarity with techniques such as integration by parts and improper integrals
  • Basic knowledge of physics principles related to work and force
  • Ability to set up and evaluate definite integrals
  • Study the concept of work in physics, particularly the work-energy principle
  • Learn about integration techniques in Calculus, focusing on applications in real-world problems
  • Explore problems involving variable forces and their integration
  • Review examples of solids of revolution and their applications in integration
Students in Calculus II, particularly those struggling with the applications of integration in physics problems, as well as educators looking for practical examples of integration in real-life scenarios.
JohnRV5.1
Hello, it is an honor to finally post on this forum. I have been lurking around for a couple of months now and have enjoyed learning much of the material given. To Get to the point.
I am currently taking CALC II in the summer. So far we have gone over Applications of Integration(area under the curve, solids of revolution) to Techniques of Integration (integration by parts, Trig substitution, Partial Fractions, IMproper Integrals, etc.) From all the problems I have encountered, only this one gives me trouble. It is the chapter on applications of Integration that pertains to work. Here is the problem and the solution I obtained, altough I am unsure I tackled the problem correctly:
Problem:
A bucket that weights 4 lb and a rope of negligible weight are used to draw water from a well that is 80 ft deep. The bucket is filled with 40 lb of water and is pulled up at a rate of 2 ft/s, but water leaks out of a hole in the bucket at a rate of 0.2 lb/s. Find the work done in pulling the bucket to the top of the well.
My Solution:
First I found the work required to lift the bucket byself to the top of the well.
I got Force = (4 lb)(80 ft) = 320 ft*lb
The I obtained the work done in pulling the leaking water to the top of the well using integration.
I found the distance = x
The Force = (40 lb)/(80 ft) - (.2 lb/s)/(2 ft/s) = .5 lb/ft - .1lb/ft = .4 lb/ft or 2/5 lb/ft
therefor the force is = 2/5 dx or .4dx.
I set up the integral using the above info
= Integral from 0 to 80 of .4xdx
evaluating the integral I obtained 1280 ft*lb
So I summed up both the work required to lift the bucket to the top and the work required to lift the water to the top of the well: 1280 ft*lb + 320 ft*lb = Work = 1600 ft*lb! Am I correct
p.s. My calc instructor informed us that no work questions will be on the exam but he did assign homework for it. The problem was due to time constraints, the instructor was not able to lecture on the section on work. Plus I have never taken a single Physics class so I did not feel too confident with my solution.
Thank you for lending your time and efforts to help me. :smile:
i think this goes in the homework section, john.
Ok, Thank you
