Help! John Needs to Carry a Long Piece of Wood
  • Thread starter Thread starter punjabi_monster
    Wood
The problem involves determining the maximum length of a piece of wood that John can carry around a corner where two hallways of different widths meet. The widths of the hallways are 2 m and 2.5 m, and the piece of wood is assumed to have no width. The context is rooted in calculus and geometric reasoning.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using geometric principles and calculus to find the maximum length of the wood. Some mention using Pythagorean theorem, while others explore the relationship between the angle of the wood and its length. There are questions about how to express the length in terms of the angle and how to differentiate to find maximum values.
There is an ongoing exploration of different methods to approach the problem, including the use of trigonometric identities and calculus. Some participants have offered guidance on how to set up the equations, while others express confusion about the differentiation process and the implications of their calculations. No explicit consensus has been reached on the correct approach or final answer.
Participants note potential confusion regarding the setup of the problem and the assumptions made about the dimensions and angles involved. There is also mention of a graph that may aid in visualizing the problem, but the details of this graph are not provided.
punjabi_monster
calculus help :(
John has to carry a long piece of wood horizontally around the corner from a hallway of width 2 m to a hallway of width 2.5 m. Assuming that the piece of wood has no width, what is the maximum length of this piece of wood (in meters)? Give answer to two decimal places.
i do not get htis question. any help would be greatly appreciated.
the way i tried it was to just use pythagorums theorum and i got 3.20, but i dotn think that's right.
Imagine a L-shaped passage which changes its width while turning from a width of 2m to a width of 2.5 m and you are carrying the piece of wood horizontally , so when you turn, you will face problem if your piece of wood is too long . Calculate the length needed at critical turning point.
BJ
BJ
But what if it is carried this way? (Refer picture)
In this case, let the angle the rod make with the horizontal be "theta".
Find the length of each part of the rod in term's of theta. Now the sum of the length of each part is constant. So use calculus and find the maximum value
I think that's exactly what Dr. Brain was saying! (Your "horizontal" is different from his!)
Punjabi, you following this? I've attached a graph, drawn to scale. Note where theta is. Can you calculate the length of the ladder (or wood or whatever) across both hallways as a function of theta? The ladder will just fit around the corner when this function reaches a minimum. You can calculate that right? What is the ladder length as a function of theta? Break it up into two parts, h and k, as functions of theta.
so...
you are trying to max x +y
sinθ=2.5/y
y=2.5/sinθ
cosθ=2/x
x=2/cosθ
2.5/sinθ + 2/cosθ = sum
from this part i get confused...
2.5/cosθ - 2/sinθ = ds/dt
2.5/cosθ - 2/sinθ = 0
2.5/cosθ = 2/sinθ
the answer is 6.35.
punjabi_monster said:
so...
sinθ=2.5/y
y=2.5/sinθ
cosθ=2/x
x=2/cosθ
2.5/cosθ = 2/sinθ
the answer is 6.35.
Your derivative is wrong. Those trig functions are in the denominators of those fractions.
[tex]\frac{dsin\theta}{d\theta} = cos\theta \ ,\ \ but \ \ \ \frac{d}{d\theta}\left[\frac{1}{sin\theta}\right] \ne \frac{1}{cos\theta}[/tex]
then would it be:
2.5cscθ + 2secθ = y
2.5(-cscθ)(cotθ)(dθ/dt) + 2(secθ)(tanθ)(dθ/dt) = y'
2.5(-cscθ)(cotθ)(dθ/dt) + 2(secθ)(tanθ)(dθ/dt) = 0
and what would u do next? i am confused.
Where did t come from? To find the θ that maximizes the length, differentiate with respect to θ:
-2.5 (cscθ)(&cotθ)+ 2(secθ)(tanθ)= 0.
You should be able to 2.5 cos3θ+ 2sin3= 0.
ok thanks for your help...i managed to get the right answer.
13K
