Vortex Panel Method: Solving for \theta_{ij}
  • Thread starter Thread starter sid_galt
    Method Vortex
The discussion revolves around the vortex panel method in fluid dynamics, specifically focusing on the calculation of the angle \(\theta_{ij}\) when the control point and the inducing panel are the same (i = j). Participants explore the implications of this scenario within the context of numerical methods for analyzing flows over surfaces, particularly airfoils.
  • One participant questions the value of \(\theta_{ij}\) when \(i = j\) and mentions a reference suggesting it is \(\frac{\lambda_i}{2}\) for source panels, but is uncertain about vortex panels.
  • Another participant points out potential errors in the original equation, suggesting it should include \(\cos(\beta_i)\) and that the subscript on \(\lambda\) should be [j].
  • A participant explains that both source and vortex panel methods are numerical approaches for modeling flows, with the vortex method applicable to lifting cases.
  • One participant emphasizes that solving for \(i = j\) is essential to understanding the contribution of all panels to the potential at the control point of the ith panel.
  • Resources are shared for further exploration, including links to online tools and source code related to the vortex panel method.
There is no consensus on the value of \(\theta_{ij}\) when \(i = j\), and multiple viewpoints regarding the correctness of the original equation and its components are presented. The discussion remains unresolved regarding the specific value and implications of \(\theta_{ij}\).
Participants express uncertainty about the correct formulation of the equation and the implications of using different methods (source vs. vortex panels). There are references to specific resources that may provide additional insights but do not resolve the current discussion.
This discussion may be useful for individuals interested in computational fluid dynamics, particularly those working with vortex panel methods in the context of airfoil analysis.
sid_galt
In the vortex panel method the following equation is used
[tex] V_{freestream}sin \beta_i - \sum_{j=1}^n \displaystyle\frac{\lambda_i}{2\pi} \int \displaystyle\frac{d\theta_{ij}}{dn_i} ds_j = 0[/tex]
where n is the panel number, i is the control point at which the vortex strength is being calculated and j is the panel which is inducing some vortex at i, [tex]\lambda_i[/tex] is the vortex strength at i and
[tex]\theta_{ij} = \arctan{\displaystyle\frac{y_i-y_j}{x_i-x_j}}[/tex]
My question is what is the value of [tex]\theta_{ij}[/tex] when i = j?
Does anyone know? What is the value of [tex]\theta_{ij}[/tex] when i = j?
For source panels I have read it is [tex]\frac{\lambda_i}{2}[/tex]. But I don't know what it is for vortex panels.
According to my reference, your original equation is incorrect. It should have cosBeta to the right of Vfreestream. Also, the subscript on lambda should be [j], not what your equation shows.
Both source panel and vortex panel methods are numerical methods for flows over arbitrary shapes. But because the source panel method has zero circulation it only applies to non-lifting cases. Vortex panel method can be used for lifting cases. The idea behind both methods is to treat the surface as if it were a streamline, i.e. a physical surface does not exist, it is replaced by a flow line. A source panel achieves this by balancing the dynamic pressure of the onrushing flow with an infinitesimal flow source on a surface, which exerts an outward pressure against it. Like air hockey. The table is a set of source panels balancing the weight per unit area of the puck. But try to imagine this system without the table (the table doesn't exist), just the sources. And the puck is the freestream airflow impinging on the source panels.
To answer your question, at least attempt to, these methods are numerical. To obtain a solution for i = j is the whole point of the method. The solution is physically the contribution of all the panels to the potential at the control point of the ith panel.
Just out of curiosity, what are you applying this method to?
You may want to check out the resources listed here:
http://www.aae.uiuc.edu/m-selig/ads.html
In particular, see the online utility posted by Professor Kevin Jones of the Naval Postgraduate School:
http://www.aa.nps.navy.mil/~jones/online_tools/panel/about/
He even posts his source code (in FORTRAN). If all else fails, perhaps running your question by him might provide an answer.
Regards,
DuncanM
http://www.rocketscientists.ca/
Ya, I realized that a few days after posting the question
To airfoils. To be more precise, I am trying to create a Java program to implement this method.
Thank you for the reply.
Regards,
DuncanM
Thank you for the links. The second one is very helpful.
  • · Replies 26 ·
