Adiabatic expansion of argon gas
The discussion revolves around the adiabatic expansion of argon gas in a turbine, focusing on the relationship between pressure, volume, and temperature during the expansion process. The original poster presents a scenario involving specific conditions of the gas and seeks to determine the exit temperature after expansion.
  • The original poster attempts to derive a relationship between pressure and temperature using the equations PV^(gamma)=constant and TV^(gamma-1)=constant, expressing uncertainty about the derivation process. Some participants suggest substituting variables from the ideal gas law to facilitate this derivation.
Participants are actively engaging with the original poster's approach, providing guidance on how to manipulate the equations. There is a recognition of the need to clarify the conditions under which the pressures are defined, and multiple interpretations of the equations are being explored without reaching a consensus.
There is mention of potential confusion regarding whether the pressures discussed are absolute, which may affect the calculations. The original poster has indicated they have a specific answer in mind, but the discussion remains focused on the derivation and understanding of the relevant equations.
Erik Horwath
argon enters a turbine at a rate of 800 kg/min, a temp of 800C and a pressure of 1.5MPa. It expands adiabatically as it pushes on the turbine blades and exits at a pressure 300KPa. Calculate its temperature at exit.
The equations I am working with are PV^(gamma)=constant and TV^(gamma-1)=constant. In this case gamma=1.67. If I could figure out how the second of these equations was derived from the first (I'm assuming it involves PV=nRT) I have a feeling I could solve the problem by deriving a similar expression involving P and T but I not sure how and my brain is tired.
Help would be appreciated. By the way I have the answer - it is 564K.
You have the right idea. Start with the first equation, PV^(gamma)=constant. Then pick the variable you would like to eliminate. To eliminate P, substitute P = nRT/V (from the ideal gas law). Just plug it in and you'll see that it equals your second equation, TV^(gamma-1)=constant. (The constants will be different of course, but that doesn't matter.) Try it!
Then to find the equation you need to solve your problem, eliminate V in the same manner.
Your answer is ok if the above said pressures are absolute, otherwise it would differ.
So that would mean P^(1-gamma)T^(gamma)=constant? Thanks for your help.
Exactly right.
