What Are the Different Definitions of Dimension in Mathematics?
  • Context: Undergrad
  • Thread starter Thread starter shekoofeh
    Dimension Mean
The discussion revolves around the various definitions of dimension in mathematics, exploring its implications in different contexts, including physics and topology. Participants examine how the term is used in both mathematical theory and practical applications, such as condensed matter physics.
  • Some participants express confusion about the meaning of dimension and inquire about the concept of 2-dimensional matter.
  • One participant references a definition from Merriam-Webster, highlighting various interpretations of dimension, including its mathematical and physical contexts.
  • Another participant suggests that the term dimension is used in different ways in physics, particularly in the context of 2-dimensional systems in condensed matter physics, where the effective behavior of electrons can be described in two dimensions despite the atoms being three-dimensional.
  • A participant notes that there is no single definition of dimension that applies universally in mathematics, leading to multiple definitions tailored to specific types of spaces, such as Euclidean spaces.
  • Some definitions mentioned include the concept of dimension as the boundary of higher-dimensional objects, with examples illustrating how a line bounds a point and a plane bounds a line.
  • A reference to the Lebesgue covering dimension is made, which is appreciated for its applicability to basic topological spaces.
Participants do not reach a consensus on a singular definition of dimension, indicating that multiple competing views and interpretations exist within the discussion.
The discussion reflects the complexity of the concept of dimension, with limitations noted in the applicability of definitions across different mathematical and physical contexts. There are unresolved aspects regarding the definitions and their implications in various scenarios.
shekoofeh
Dimension,
what does this mean?!
and Has anyone heared about 2-d matter?
SOURCE OF DEFINITION~Merriam Webster dictionary online*(AOL)
Main Entry: [1]di·men·sion
Pronunciation: d&-'men(t)-sh&n also dI-
Function: noun
Etymology: Middle English, from Middle French, from Latin dimension-, dimensio, from dimetiri to measure out, from dis- + metiri to measure —more at MEASURE
Date: 14th century
1 a (1) : measure in one direction; specifically : one of three coordinates determining a position in space or four coordinates determining a position in space and time (2) : one of a group of properties whose number is necessary and sufficient to determine uniquely each element of a system of usually mathematical entities (as an aggregate of points in real or abstract space) <the surface of a sphere has two dimensions>; also : a parameter or coordinate variable assigned to such a property <the three dimensions of momentum> (3) : the number of elements in a basis of a vector space b : the quality of spatial extension : MAGNITUDE, SIZE c : a lifelike or realistic quality d : the range over which or the degree to which something extends : SCOPE — usually used in plural e : one of the elements or factors making up a complete personality or entity : ASPECT
2 : obsolete : bodily form or proportions
3 : any of the fundamental units (as of mass, length, or time) on which a derived unit is based; also : the power of such a unit
4 : wood or stone cut to pieces of specified size
5 : a level of existence or consciousness
- di·men·sion·al /-'mench-n&l, -'men(t)-sh&-n&l/ adjective
- di·men·sion·al·i·ty /-"men(t)-sh&-'na-l&-tE/ noun
- di·men·sion·al·ly /-'mench-n&-lE, -'men(t)-sh&-
shekoofeh said:
Dimension,
(1) See Mariko's post, especially 1a and 3, which are the contexts in which physicists use the term dimension.
(2) Perhaps you are thinking about 2-d systems, which crop up in condensed matter physics a lot? For example, you can have a 2-d lattice of atoms in a material such that that the electrons living on this lattice effectively live in this 2-d sheet. (That's a really rough way of thinking about it.) Note that the 'matter' itself is not two dimensional--atoms have definite volume in 3-space, it's just that the extension in the third dimension is pretty small causing the system to behave in a way where there are only 2 relevant directions.
Dimension has a large number of closely related definitions in mathematics.
http://en.wikipedia.org/wiki/Dimension
In mathematics, no definition of dimension adequately captures the concept in all situations where we would like to make use of it. Consequently, mathematicians have devised numerous definitions of dimension for different types of spaces. All, however, are ultimately based on the concept of the dimension of Euclidean n-space E n. The point E 0 is 0-dimensional. The line E 1 is 1-dimensional. The plane E 2 is 2-dimensional. And in general E n is n-dimensional.
In the rest of this article we examine some of the more important mathematical definitions of dimension.
You might also want to look at the following old thread in the math forum
https://www.physicsforums.com/showthread.php?t=41627&highlight=dimension
I rather like the Lebesque covering dimension, because it defines the concept in very primitive spaces, called topological spaces, that need only the concept of a point and it's neighborhood. This is a much more basic concept (IMO) than a vector space.
The idea that a n-dimensional object is the boundary of a n+1 dimensional object is also an appealing way to define dimension, and is discussed somewhat in the above thread. Thus a line bounds a point, if you take a point out of a line it divides it into two parts. A line bounds a plane, etc, etc.
  • · Replies 19 ·
