What is the definition of a density function in cartesian coordinates?
The discussion revolves around the definition of a density function in Cartesian coordinates, specifically focusing on the mathematical formulation and conceptual understanding of mass density. Participants explore various definitions, the relationship between mass and volume, and the implications of different approaches to defining density.
  • One participant proposes defining the density function as the limit of the mass contained in a volume as the volume approaches zero, suggesting a rigorous mathematical formulation.
  • Another participant challenges this definition, arguing that it does not align with the standard integral definition of mass in terms of density.
  • Concerns are raised about the completeness of the proposed definition and the implications of assuming certain conditions, such as the relationship between density and volume.
  • Some participants reference established theories in probability and measure theory, suggesting that density should be viewed as a measurable function rather than a point function dependent on surrounding masses.
  • There is a discussion about the Radon-Nikodym theorem and its relevance to defining density as a derivative of mass with respect to volume.
  • Several participants express differing views on the necessity of a rigorous definition, with some advocating for a more intuitive understanding of density based on physical principles.
  • Technical difficulties are acknowledged regarding the definition of regions and how to properly approach limits in the context of density.
Participants do not reach a consensus on the definition of the density function. Multiple competing views are presented, with some advocating for a rigorous mathematical approach while others prefer a more intuitive understanding.
Limitations include unresolved definitions of mass and volume in the context of density, as well as the dependence on specific mathematical frameworks that may not be universally accepted among participants.
quasar987
I want a rigorous description of the density function (in cartesian coordinates) [itex]\rho(x,y,z)[/itex].
I suggest that we define a function M(x,y,z,V'), where V' is a volume of any given shape centered on the point (x,y,z), giving the mass contained in that volume. Then define the density function as
[tex]\rho(x,y,z) = \frac{\partial{M(x,y,z,V')}}{\partial{V'}}\vert_{V'=0}[/tex]
I wrote the volume of the "enclosing volume" as V' to differentiate it from the "volume of integration" V such that
[tex]M_{body} = \int_V \rho dV = \int_{x_1}^{x_2}\int_{y_1}^{y_2}\int_{z_1}^{z_2}\frac{\partial{M(x,y,z,V')}}{\partial{V'}}\vert_{V'=0}dzdydx[/tex]
Any comments?
Actually:
[tex]M = \int_V \rho(x,y,z) dx\,dy\,dz[/tex]
Your expression for [itex]\rho[/itex] doesn't quite match this.
It doesn't ?!
it doesn't. coz it isn't complete differential. why you put |v' = 0?
It makes no sense to write
[tex]M=M (x,y,z,V)[/tex]
How would you exemplify and justify such choice?
Daniel.
See any book on probability theory and/or measure theory-Lebesgue integration. A highly general density function is defined as a measureable (positive) function.
For mass, any positive integrable point function will work as a density. For charge, any integrable function will do.
Your definition makes no sense, as written. Why do you assume thaqt dx/dV is zero?
If V is contained in W, what's the relation between the density with V vs. that of W? Etc., etc... (In probability, you could have density conditional on a volume, but why?. Why mess up the notion that density is purely a point function. That is, if density is local, the local density does not depend upon far away charges, masses, or whatever.
And, what's wrong with density=limit(V->0) deltaM/deltaV? This definition has survived for several centuries.
Regards,
Reilly Atkinson
I don't understand any of your objections so I won't reply to them.
But reilly, how are defined M, V, [itex]\Delta M[/itex] and [itex]\Delta V[/itex] in
[itex]\rho(x,y,z) = \lim_{\Delta V \rightarrow 0}\frac{\Delta M}{\Delta V}[/tex]?<br /> <br /> How could that limit span a function of x,y,z if M is not itself a function of x,y,z? and how could M be differentiated wrt V if M is not also a function of V?[/itex]
Quasar, I really don't see a need for a mathematically rigorous definition of a mass-density function. The idea is physically clear as it is.
What you WANT from the density function is that the integral of that function over some volume gives the mass enclosed by that volume. That is sufficient to completely characterize it. Take that as your definition.
Insightful post as always Galileo. So really there is no definition of M and V in
[tex]\rho = \frac{dM}{dV}[/tex]
other than that M is the mass of the object such that rho integrated over V equals M? Is this your opinion too reilly?
You were somewhat on the right track, quasar. The leap you were missing is that you want mass to be a set function. In particular, you wanted something like:
For any region R, M(R) is the mass contained within R.
This should be a special kind of set function called a measure.
The function V(R) = volume of R is another measure.
The thing we like to do with measures is to integrate (measurable) functions over regions. You're quite familiar with integrals such as [itex]\int_R f \, dV[/itex]. Well, volume isn't "special": we can do this with any measure.
For example, we have the following identity:
[tex]M(R) = \int_R \, dM[/tex]
Now, back to density...
It is often better to ask yourself, "What do I want a thing to do?" than to ask yourself "How do I construct this thing?" As Galileo said, then thing you really want to be able to say is:
[tex]M(R) = \int_R \rho \, dV[/tex]
In other words, the mass enclosed within a region is the integral of ρ with respect to volume within that region.
And then we appeal to powerful mathematical machinery. (IOW the stuff that says we can do what we want to do) :biggrin:
The Radon-Nikodym theorem says that, given two measures μ and ν satisfying some reasonable conditions, there is a function f such that:
[tex]\nu(E) = \int_E \, d\nu = \int_E f \, d\mu[/tex]
over any (Borel) set E.
mass and volume ought to satisfy those reasonable conditions (I'll assume no point masses -- that surely messes things up), so this theorem guarantees the existence of a density function.
There is a strong analogy with differentiation: in fact, we like to say that ρ is the Radon-Nikodym derivative of mass with respect to volume, and Royden writes it as:
[tex]\rho := \left[ \frac{dM}{dV} \right][/tex]
Voila, a rigorous existence proof.
Anyways, now that you know that you need to think of mass and volume as being a function on sets, I'll let you work out a more "constructive" definition for ρ. Hint: you were with the right track thinking about regions enclosing a particular point.
Wow, that was sa-weet! :biggrin:
Ok, err, so how about, for R centered on (x,y,z),
[tex]\rho(x,y,z) = \lim_{\Delta R \rightarrow 0}\frac{M(R+\Delta R) - M(R)}{V(R+\Delta R) - V(R)}=\frac{dM}{dV}[/tex]
...and I can't help but add "evaluated at R = 0" *take cover*.
It's not that simple. What's a &Delta;R, for instance? How do you add sets?
I can imagine three ways to proceed:
Trying to figure out how to make everything make sense in the approach you're taking.
Thinking geometrically about how the &epsilon;-&delta; definition of a limit for ordinary functions works.
Thinking about the integrals.
I don't know man.
This here
seems quite ok a definitnion and it involves integral, but that's probably not what you were thinking about.
We usually call domains by [itex]D[/itex]. That [itex]R[/itex] can be mistaken with the set of reals.
Daniel.
Can you just tell me what it is you had in mind Hurkyl?
The basic idea is that we want a small mass (&Delta;M) enclosed in a small volume (&Delta;V) containing the point in question, and take the ratio.
So, what we want to do is something like:
[tex] \rho(P) = \lim_{V(S) \rightarrow 0} \frac{M(S)}{V(S)}[/tex]
where S ranges over all regions containing P. But there will be technical difficulties! (See if you can figure them out!)
But, we can do this:
[tex] \rho(P) = \lim_{\epsilon \rightarrow 0^+} \frac{M(B(P, \epsilon))}{V(B(P, \epsilon))}[/tex]
where B(P, &epsilon;) is the open ball centered on P with radius &epsilon;.
We could be somewhat more loose in what regions we allow the limit to range over, but I would expect any such workable variation to be equivalent to this one.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 21 ·
