Can Moving Charges Create a Magnetic Field? A Discussion on Electromagnetism
  • Context: Graduate
  • Thread starter Thread starter kartiksg
    Electromagnetism
The discussion centers on the relationship between moving charges and the creation of magnetic fields within the context of electromagnetism. Participants explore various aspects of this relationship, including the conditions under which magnetic fields arise, the role of acceleration versus drift velocity, and the implications of different reference frames on electric and magnetic fields.
  • Some participants question the relative nature of magnetic fields created by moving charges, particularly whether parallel moving electrons interact magnetically.
  • There is a discussion on whether magnetic fields arise from the acceleration of charges or their drift velocity, with some suggesting that different materials might produce varying magnetic fields.
  • Participants express confusion regarding the application of the Lorentz force equation, particularly the meaning of the velocity 'v' in different reference frames.
  • Some argue that electric and magnetic fields can be interchanged under certain conditions, while others seek clarification on how to distinguish between them.
  • One participant mentions that the electric field of a charged particle changes shape when the particle moves, leading to the generation of electromagnetic waves.
  • There is a proposal that all magnetic effects could potentially be described in terms of induced electric fields, though this remains uncertain.
  • Participants inquire about the charge density of moving electrons as observed from different frames and seek equations to describe the magnetic field of a single moving charge.
  • Discussion includes the idea of a unified description of electric and magnetic forces, referencing the electromagnetic field tensor.
Participants express differing views on the nature of magnetic fields and their relationship to electric fields, with no consensus reached on several key points, including the role of acceleration versus drift velocity and the interchangeability of electric and magnetic fields in different frames.
Participants acknowledge limitations in their understanding of the mathematical frameworks involved, particularly in relation to relativistic effects and the application of the electromagnetic field tensor.
kartiksg
Hi,
I would like to clarify some points on electromagnetism. Most (if not all) of my teachers say that moving charges create a magnetic field. I would just like to know... relative to what? If two electrons move parallel to each other with the same velocity, would they show any magnetic interaction?
Furthermore, my prof.s also say "Current creates a magnetic field. When a current flows in a conductor, electrons are flowing in them, this creates the field" Again.. electrons are 'flowing'... does that mean the magnetic field is created due to the acceleration (electrons do accelerate across a potiential difference right?) or is it due to the drift velocity as it is. If it is the drift velocity, then shouldn't wires of differnet mterial produce different magnetic fields? Also, we know the Lorentz formula
F = q(E + vxB) - what is the v relative to? for. eg. If I take a stream of electrons that are accelerating with constant acceleration 'a' from x=-[oo] to x=[oo], then all inertial frames that move parallel (or antiparallel) to this stream describe the stream (i.e, parallel to x axis) in the same manner. So how do I decide what the 'v' in Lorentz equation is?
Also, is there any way of absolutely distinguishing between an electric and magnetic field? Is it possible that an electric field in one frame might appear like a magnetic field in another? I was thinking of motional emf and its field when I wrote the previous line... it can be thought of on the basis of magnetic field, but it is an electric field as well ( I think... ).Is it possible to describe all magnetic effects on the basis of induced (mebbe imaginary) electric fields alone?
In replies, please use mathematics or formal theoretical framework wherever possible but... I am in high school ok :wink:
Thanks for any help
Kartik
Hi
Yes, Magnetic Fields are created by accelerated charges and no An Alectric field in one frame is not seen as a Magnetic Field in the other.
I still don't get how to apply v in the formula. Relative to what? How do I sense the movement relative to a field? Also, according to http://rognerud.com/physics/html/sec_1.html , it says u can interchange the fields... can someone gimme some feedback on that?
Kartik
Thanks... I understood most of it... but I still didnt get the parallel electron part. You said that the magnetic field will exist in the frames where the electrons are in motion. So if in a frame, I see the electron moving with velocity v, I see 2 forces on the electrons
1. Coulombic force (repulsive):- Fe = k e^2 / r^2 where r is the dist of separation and k is the coulomb's constant.
2. Magnetic force (attractive):- Fm... I am not sure what its magnitude will be as I don't know how to calculate the magnetic field produced by an electron... but I know it will be attractive (Using the Maxwell's Grip rule and the Fleming's Left hand rule).
In yet another frame, the observer sees no motion of the electrons. So he sees only the coulomb force.. call this Fe'
Using the first postulate of relativity:
Fe' = Fe + Fm
How can this be... I tried asking my teachers (3 of them) this and didt get a good answer...
Is it that the coulomb force is decreasing in the first frame... or increasing in the second.. or is there some other force I am not taking into consideration? ( I suppose u can ignore the effects caused due to the electron spin as they will be common in both... or can u? )
Thanks for the help
Kartik
Also, can u elaborate on how different observers will measure different charge densities for the stream of electrons?
Can I also have an equation on how to describe the magnetic field of a moving electron? I have equations for fields of a current - Biot Savart Law.. but none for a single charged particle.. or a system of particles. Also, is there a single equation that describes all the electric and magnetic forces together - simultaneously.. rather than four separate equations - as in maxwell's 4 equations. I read stuff on other threads about the EM field tensor... can someone explain what it is and how I ca apply it?
Thanks
Kartik
Thanks a lot.. the site really helped... as for those weird looking equations... I guess Ill wait till I get to college and do partial derivatives before I try to get what it meant :wink:
Again, Thanks a ton for the help
Do write about why the forces need not be equivalent in different frames and how they are balanced when u get time.
Kartik
Originally posted by kartiksg
... I still didnt get the parallel electron part.
... I see 2 forces on the electrons
1. Coulombic force ... Fe ...
2. Magnetic force ... Fm ...
Fe' = Fe + Fm
How can this be...
Is it that the coulomb force is ... increasing in the second.
Yes. (If I understand you correctly). In Newtonian physics, the magnetic force will balance the electric force when the electrons are moving at c parallel to each other (an interesting result, I think). Applying relativistic effects, the equation you suggest will be true. You can look at it two ways: 1) The charge on the electrons will increase (a relativistic phenomenon, kind of like an increase in mass, but different, so don't go around telling people that I said it was the same) the faster they go, thus increasing the electric repulsion, and thus canceling the magnetic attraction 2) You can consider the tensor equation, but that's more sophisticated.
If you know what a vector and a matrix are, then just think of the Newtonian version of the electric and magnetic fields as 3-D vectors and the charge as a scalar. The relativistic version of the electromagnetic field as a 4x4 matrix the charge and current get lumped into one 4-D vector. Then, you operate the 4x4 matrix on the 4-D vector to get the 4-D force.
Hi,
A charged particle radiates an electric field. When the particle is moved there is a lag in the time it takes for the field to catch up. There is a difference in the shape of the electric field from the initial position and the succeding positions. The waves created in the electric field by moving the particle generating the field are electromagnetic waves.
So the answer is that charges moving relative to their own electric field create magnetic fields.
Originally posted by kartiksg Also, is there any way of absolutely distinguishing between an electric and magnetic field?
A magnetic field is an electric field with transverse waves in it. The electric field is always potentially radiant. The waves that cause it to become "magnetic" are at right angles to the radiant vectors of the electric field's potential.
This is a very important question. If an electric field is stationary relative to the charge from which it emanates, could there be motion in some other frame such that the electric field seems to be possessed of transverse waves propagating at C?
Electric fields naturally arise from charged particles. There is no way to induce an electric field in a particle. Electrons have one kind of charge, Protons have the other kind of charge, and Neutrons don't have any charge. There doesn't appear to be any way to induce an electric field in a particle that it doesn't already have one, or to change the one it has.
It is true that all magnetic effects arise from the electric field.
Hi,
Thanks to all u ppl... I am finally beginning to get the hang of this... E field and B field by themselves arent Lorentz invariant but taken together, they are invariant. Force by itself is not invariant, but the four vector of force is. Thanks... Thanks a ton... I am finally beginning to see how 'relative' relativity can actually get .
I have seen the formulae for length contraction, time dilation etc. but havnt seen one for charge increase... can I know how the rest charge differs from moving charge? Also, it was stated in www.modernrelativity.com that the mass by itself remains the same in the transformation between frames and we should associate the [gamma] with the velocity vector.. or sumthing like that. Is is the same thing here with the charge as well? ( I am not sure I phrased that well... ).
Also... if magnetic field can be thought of as the lag of electric field... how do we think of the lag of a magnetic field? Is there something like that? I think that should happen when u accelerate the charge, resulting in a gradual lag of the lag of the electric field ( all tongue twisted.. ).
Thanks
Kartik
Originally posted by kartiksg Also... if magnetic field can be thought of as the lag of electric field...
This isn't quite right. The electric field itself doesn't lag. There is a lag in the adjustment of its position when you move the source of the field. The lag in the adjustment of it position is extremely small but measurable: it is the speed of light.
You can't ever accelerate a charge to the speed of light, therefore there is no risk of accelerating it faster than the magnetic field that results from its change of position can propagate.
(1)
(2)
(3)
... the mass by itself remains the same in the transformation between frames and we should associate the [gamma] with the velocity vector.. or sumthing like that. Is is the same thing here with the charge as well?
Just don't forget that you have to put them together in an object a lot like a matrix, called a second rank 4-D tensor. A simple vector just won't do anymore. Then, you have something a lot like a matrix operating on a vector that gives you another vector as the force.
(2) The relativistic charge density is the rest charge density multiplied by the γ factor (if I remember correctly).
(3) I agree with this, but it is apparently still quite popular to speak of the mass as a component of a tensor (the time-like component of the four-momentum). It is almost the same thing with charge, but charge density really. The charge density is the time-like component of the electric four-current. By charge density, I mean, that part of the electric four-current that effects the electric field components of the Farady tensor, as opposed to the magnetic field components.
Originally posted by Ambitwistor This definitely is not true. You can have electric and magnetic fields without any waves in them at all.
This is the point of contention. The illustration presented at the site you linked to shows the stationary particle with radiant lines that are supposed to represent both electric and magnetic lines. That is: the charged particle is radiating two completely different kinds of lines of force when at rest. Thus, according to that site, when the particle is accelerated, both kinds of energies are "kinked", but the kink in the electric field doesn't have anything to do with the magnetic properties of the field created .
Is this how you understand it?
When you accelerate a charge, the changing electric field generates a changing magnetic field, which in turn generates a changing electric field, etc., to produce an electromagnetic wave.
You say the changing electric field generates a changing magnetic field. We start with electric, how is it transduced to magnetic?
However, it is a mistake to claim that all of magnetic fields are produced from changing electric fields...
Give me some examples of magnetic fields which are not produced from changing electric fields.
or are related to waves
The word "kinks" used at the site is acceptable.
Consider electrostatics and magnetostatics.
I'm not sure how electrostatics
supports your point, and I've never heard of magnetostatics so you'll have to fill me into the extent it's necessary to understand how it supports your point.
And no, the "radiant lines" in the linked site's figures do not represent both electric and magnetic fields. It was a diagram of just the electric field.
Thank God.
The magnetic field of a moving point charge isn't radial at all. For that matter, a charge at rest doesn't radiate a magnetic field at all (unless you're including an intrinsic magnetic moment due to its spin, which I'm not; I'm just considering a classical point charge).
This last concurs with what I already thought to be true.
Ampere-Maxwell's law: a changing electric field induces a magnetic field.
This is simply a description of what happens, not an explanation of how it happenes.
The magnetic field of a charge moving at constant velocity.
This is in conflict with what you said earlier, that a magnetic field only arises from acceleration. You said it was misleading of me to say it arose from simply "moving" the particle.
Electrostatics is the special case of electromagnetism when the electric field is static.
I've never heard it described as a special case of electromagnetism, and I still don't see where it supports your point.
Magnetostatics is the special case when the magnetic field is static. There are no wavelike, propagating disturbances in such fields: that's the definition of "static" (unchanging with time).
I understand the concept,then, but you are ignoring the fact that non-varying magnetic fields are being generated by constantly moving charged particles. The initial question was about this basic kind of field, not oscillating fields. The static field around a wire carrying current results from the moving charges in that wire. Likewise the static field around a permanent magnet results from the electrons in the material constantly moving around tiny circuits in the magnetic domains.
The magnetic fields, in these situations, are in fact "kinks" in the electric field.
Originally posted by Ambitwistor Fundamental physical theories always explain what happens, not "how it happens". Gravity doesn't say "how mass produces a gravitational field", it just says that when mass is present in some amount, there is a gravitational field. Likewise, Maxwell's theory doesn't say "how a changing electric field produces a magnetic field", it just says that when a changing electric field is present, there is a magnetic field.
My question was how does the electric field create the magnetic field. Simply restating that it does is not an answer. Then evading my objection to that by saying physical theories always explain what but not how is also not an answer. If you don't know just say so. GR says that mass creates gravity by curving the Space-Time around it.
I never said that. In fact, I specifically said the opposite: that electromagnetic radiation from accelerating charges doesn't account for all magnetism.
Here is what you said:
Originally posted by Ambitwistor This is misleading. If a charge accelerates (not just moves), it will emit electromagnetic radiation, which is a self-supporting oscillation of electric and magnetic fields. (And it will create radiation even in the particle's instantaneous rest frame.) But that doesn't account for all magnetism, it just accounts for electromagnetic waves. There are plenty of other magnetic phenomena. The point is not that a changing electric field will produce a magnetic field in some frame; it's that an electric field (changing or not) in one frame is (at least partly) a magnetic field in another frame.
So, I stand corrected, you did not say accelerating a charged particle was the only way to create a magnetic field.
It seemed were implying that magnetic fields always arise from changes in the shape of the electric field, as when you accelerate a charge. That's what I called misleading; it is not true for the magnetic fields arising from a charge in inertial motion. Rather, the electric field in one frame transforms to be a partly electric and partly magnetic field in another frame. The fields do not change shape in this situation.
I did say that magnetic fields are created when charged particles move relative to their electric fields. I did not imply this was the only way. Kartiksg asked if it were possible that an electric field might seem like a magnetic one from another frame of reference. I said that was an important question, and I restated it, paraphrasing it, meaning: I did not know the answer but wanted to find out. This is in my post 11-02-2003 03:07 AM
What, electrostatics?? Magnetostatics?? Electrostatics and magnetostatics are what you get when you set the time derivatives in Maxwell's equations to zero: that's the very definition of "electrostatics" and "magnetostatics".
What did you think the definition of "electrostatics" was?
I thought the definition of "electrostatics" was the study of the behaviour and properties of charges at rest. I still do. I wasn't commenting on the definition of electrostatics, I merely said I had never heard it classified as you classified it.
The point is that in an electrostatic or a magnetostatic situation, there are no waves, and no changing fields. So your statement, "A magnetic field is an electric field with transverse waves in it" cannot be true.
Since I am willing to abandon the word "waves" in favor of "kinks" I hope you will be satisfied.
That's my point! You were the one who was claiming that a magnetic field is "an electric field with waves in it". But there are certainly cases of magnetic fields where no waves are involved.
If by the latter you are referring to the basic static field around a current carrying conductor, or a permanent magnet then I still am in disagreement. The magnetic field in them is created as I described it to be. We may call the disturbances in the electric field "kinks" instead of waves because my sense is that you will only accept "waves" in the case of electromagnetic radiation resulting from oscillation of the polarity of a magnetic field. But in permanent magnets and current carrying conductors the "kinks" are in constant motion away from the source at C and are constantly being replaced by more of the same as the charged particles continue to move.
I am not evading your question. The laws of physics do not state "how a changing electric field creates a magnetic field".
I believe the whole point of explaining how the field becomes kinked when the charge is accelerated is to explain the exact mechanism whereby the electric field takes on different properties that manifest as magnitism.
GR does not specify "how" mass produces spacetime curvature, and EM theory does not specify "how" a changing electric field produces a magnetic field. GR just gives an equation that says if some amount of mass is present, then some amount of curvature will also be present: it doesn't specify a mechanism. EM theory just gives an equation that says if an electric field is changing at some rate, a magnetic field will also be present: it doesn't specify a mechanism.
Each new level of understanding about the "how" can beg the next question. It is quite likely we'll never get to the last "how" question,concerning any phenomenon. With gravity, to assert that the mere presence of mass curves the space-time around it is to specify a mechanism. It is a huge step in explaining how gravity works: It specifies that mechanism as opposed to something else , (like an attractive force, or a pushing force.)
Also, I did not interpret a charge moving at constant velocity to be "moving with respect to its electric field" -- it carries its electric field along with it, with no "kinks".
It does seem logical to conclude that a charge moving with uniform velocity would carry a uniformly shaped field along with it. I'm not sure this situation can exist, and if it can it isn't what is going on when current moves in a conductor or when electrons orbit in a permanent magnet.
There are no "kinks" in the electric (or magnetic) field of a point charge in uniform motion.
I'll need an example of a situation of a point charge in uniform motion.
There are no "kinks" in the field in these cases either -- the fields are static, and carry no propagating changes, wavelike or otherwise, at speed c or otherwise. At least, not if they're ideal current-carrying conductors or magnets (i.e., they dissipate no energy).
We should expect to find kinks in the electric fields of all the electrons that are moving in a current-carrying conductor and of all those moving in a permanent magnet because the motion of these particles is not straight line uniform motion. These electrons are constantly in circular motion and therefore are constantly undergoing centripetal acceleration.
The field as a whole can be regarded as "static" only in the sense there is no change in its intensity or polarity, but the field itself arises from the constant changes in the positions of the electrons whose electric fields are the basis of the magnetic field. The change in position is an acceleration in this case, and since we are already agreed on kinks arising in cases of acceleration of charges, I hope we can agree on kinks in this case of acceleration of charges.
Zooby:
Did you catch that it is acceleration relative to an EMF that produces an electromagnetic wave, not Newtonian spatial acceleration? A constant current in a coil (with a circular EMF), although changing position relative to Newtonian space, does not radiate energy. But a constant current there, or anywhere, maintains a constant field there including a (claimed) circular component around the current called: magnetic.
Originally posted by Ambitwistor Look: whenever "kinks" in the field propagate, they always carry energy away. The mechanical system loses energy. No system that doesn't "run down" can have them (unless it's continually receiving energy from outside, like if it's in thermal equilibrium with the environment). That includes charges in inertial motion, current in an ideal, resistanceless wire, electrons in atoms, and permanent magnets. All those systems have fields with no propagation, (except for the non-ideal case of thermal radiation, which in any case is not responsibile for the vast majority of their magnetism).
I'm not dead. I'm thinking about this.
... if you want to describe "how" a changing electric field generates a magnetic field, you're not going to get a deeper answer than the Ampere-Maxwell law,
Might I suggest the Farady tensor as a deeper answer?
No. The Faraday tensor is just a way of encapsulating the electric and magnetic fields. To determine how a changing electric field relates to a magnetic field, you need the field equations, which are Maxwell's equations, of which one is the Ampere-Maxwell equation -- regardless of whether you choose to write them in terms of E and B, or F.
Actually, E and B are not tensors, but F is. If you mean that the Faraday tensor just serves an organizational purpose, then I disagree with that. It is my understanding that a tensor is a deeper object than even its own representation (in this case, the 4x4 matrix that encapsulates the components of the electric and magnetic fields). In Fact, the four Maxwell's equations just reduce to two tensor equations. One of these equations contains the relationship between the changing electric field and the resulting magnetic field. It is not so disjointed as some integral equation that expresses the magnetic field as the result of a changing electric field, but a statement that the Faraday tensor is a geometric object in space-time, independent of representation in space-time.
If you meant "the Ampere-Maxwell equation" as the tensor equation, then I guess I do agree. But I interpretted you to mean one of the four Maxwell equations.
I thought we were talking about a deeper insight, not a mathematical equation. I think that viewing the Faraday tensor as a geometrical object, rather than viewing the E and B fields as 3-vectors, provides deeper insight. I must have misunderstood the issue.
Zooby:
You are asking about a matter that I offered a novel opinion on on another thread, I don't know whether you read it, but I'm always happy to repeat own ideas.
To reiterate the idea most simply I will point out that two close, slack, parallel wires carrying same direction currents will attract each other laterally. If I roll the wires up into coils, even just single loop coils, and place them on the same axis, and apply same direction currents, they will again attract each other.
If I now hold the coils in my hands, and try to feel out the source of the forces between the two coils, it will feel like it is coming from the centers of the two coils, rather than directly, wire to wire, from the edges of the coils. A magnetic compass needle (which is the electrical equivalent of a miniature DC carrying coil) will indicate the same thing, But, obviously, nothing electrical or dynamic has changed between the two wires except the spacial, but still parallel, arrangement of the two wires.
But scientists, starting with Oersted, Faraday and Ampere, decided to settle on the apparent force source as a true basic force, although they couldn't separate it from the circular current situations in which it appears, except by arbitrary backward logical extrapolation to a single current carrying wire, or by being hypnotized by compass needles. This, in my opinion, is a misconception which is a carry over from the earlier perception of magnetism as it appears in nature in lodestone and magnets.
In other words, I believe there is only a complication of a single kind of field which is introduced when a current is put in a circle. I will refrain from calling this single kind of field an electric field because an electric field has already been defined as something else (a charge around an un neutralized electron or proton). The two different types of fields may be connected but independent phenomena when an electron current flows. (A layman's view only.)
Originally posted by Ambitwistor Likewise, Maxwell's theory doesn't say "how a changing electric field produces a magnetic field", it just says that when a changing electric field is present, there is a magnetic field.
Ambitwistor,
On the above point: In the case of current flowing in a conductor the only change I see, according to your description of the electric field moving along at drift velocity without kinking, is a change of position. This, by your assessment, should be enough for it to acquire the magnetic properties it acquires, and is analagous to the magnetic properties that would be experienced by something in another frame moving relative to a charged body at rest. If this is not a correct characterization of your understanding, point out where I have misunderstood you.
All quite fascinating, but not what I was asking.
In the case of current flowing in a conductor pinpoint for me, if you would, what aspect of the electric field is changing such that it fullfills Maxwell"s "when a changing electric field is present, there is a magnetic field." It seems to me that if the field is not kinking, but moving along with the current at drift velocity, the only change the field is experiencing is one of position.
As I just said above, current flowing through a conductor is not a case where the magnetic field is due to a changing electric field; it is a case where the field is due to the velocity of the moving charges. That's the point of what I have been saying.
This does seem to be the point of many of your statements. I perceived an apparent contradiction between this and your report of what Maxwell said. I am trying to get that cleared up in my mind.
In Maxwell's equations, current directly is a source of the magnetic field, just like charge directly is a source of the electric field. In addition, a changing electric field can also produce an electric field, and a changing magnetic field can produce an electric field --- but changing fields are not necessary to produce either an electric or magnetic field.
This, I must ponder.
If you postulate an infinite, perfect wire with current moving at a uniform drift velocity, there isn't a change in field at all: the electric and magnetic fields are static.
This last seems to contradict something you said earlier:
Originally posted by Ambitwistor Also, I did not interpret a charge moving at constant velocity to be "moving with respect to its electric field" -- it carries its electric field along with it, with no "kinks".
I understand that you are saying there is no change in the shape of the field, but did you mean that the field was not moving along with the drift current n the example of the infinite, perfect wire?
OK. I think I understand what you are saying. (Didn't follow the equation, but do go into it now.)
What, then, made the wire twirl around the magnet in Faraday's experiment with the wire, magnet, and mercury?
I'll try.
He had a dish of mercury. Pushed up through the center of the dish was one pole of a permanent magnet. Obviously the hole through which the magnet came was sealed off so that the mercury wouldn't run out - say with wax.
Suspended over the dish was a copper wire. This wire hung vertically, by a loop, from a copper horizontal member. It was just large enough in gage to be stiff, not flexible. It hung low enough that it entered the mercury at its bottom end. The loop from which it hung was large enough to allow it to swing in a circle.
Faraday connected one pole of a battery to the mercury, and the other to the horizontal copper cross member. The current then flowed through the cross member to the hanging wire, down the wire into the mercury, then back to the battery.
The hanging wire began twirling as fast as it could around the pole of the magnet sticking up through the mercury. As far as anyone knows this was the first electric motor.
You can make the same set up with salted water instead of mercury.
Two charges moves in the same speed and direction.
Seen from our referencesystem, the electric force between the charges
gets weaker the faster they move due of the magnetical force.
Seen from another valid referencesystem
moving in the same speed and direction as the charges,
there is no magnetical force.
The magnetical force is a relativistic effect.
both the charges are relativistic.
You have to visit http://www.quantumnet-string.tk
  • · Replies 22 ·
