How Do You Calculate the Compression of Aluminum and Brass Rods Under Force?
The discussion focuses on calculating the compression of aluminum and brass rods under a compressive force of 8400N. The rods, each measuring 0.45m in length and 1.5cm in diameter, experience a combined length decrease of 0.55mm. Participants clarify that the Young's modulus of each material should not be combined; instead, the compression for each rod must be calculated separately before summing the results. The correct approach involves determining the individual compressions based on the material properties and applying the formula for compression.
  • Understanding of Young's modulus for aluminum and brass
  • Knowledge of the formula for calculating compression under force
  • Familiarity with cross-sectional area calculations
  • Basic principles of material mechanics
  • Research the Young's modulus values for aluminum and brass
  • Learn the formula for calculating compression: ΔL = (F * L) / (A * E)
  • Explore how to calculate the cross-sectional area of cylindrical rods
  • Study the principles of composite material behavior under load
Mechanical engineers, materials scientists, and students studying mechanics of materials will benefit from this discussion, particularly those interested in understanding the behavior of different materials under compressive forces.
Lalasushi
"2 rods of equal length (0.45m) and diameter (1.5cm) are placed end to end. one rod is aluminium, the other is brass. if a compressive force of 8400N is applied to the rods, how much does their combined length decrease?" [ans: 0.55mm)
with this question, I am not sure whether its ok to find the compression of each of the rods separately first, then add the answers together to get the combined length decrease because i couldn't get the right answer that way...and i don't know if its ok to add the 2 young's modulus for the 2 materials together and then treat it as one material...can anyone help me out here?
Your first method should have worked. Did you find the areas? You cannot add the moduli of the two materials first. Show what you did and someone will find where you went wrong.
Hint: You need to calculate the decrease in length for two rods individually and then add the compressions of both.
BJ
