Why Is a 200 N Upward Force Required to Match Gravity in MCAT Physics?
  • Thread starter Thread starter LeKahlua
    Physics
The discussion revolves around a physics problem related to forces acting on a mass in free fall, specifically addressing the required upward force to achieve a certain acceleration in the context of gravity.
  • Participants explore the relationship between gravitational force and the net force required to achieve an upward acceleration equal to gravity. Questions arise regarding the net force needed to counteract gravity and achieve the desired acceleration.
The discussion is progressing with participants clarifying their understanding of the forces involved. Some guidance has been provided regarding the need for a net force to achieve upward acceleration, and there is acknowledgment of the reasoning behind the required upward force.
Participants are working within the constraints of a physics problem that requires understanding of forces and acceleration, with specific values provided for mass and gravitational force.
LeKahlua
Mcat Physics Question: A 10 kg. mass is in free fall with no air resistance. In order to slow the mass at a rate equal to the magnitude of g, an upward force must be applied with magnitude:
0 N, 10 N, 100 N, or 200 N.
I solved if F=mg then F=10*10 or 100 N downward force. Therefore an upward force of 100 N resistance would be required. Why is the answer 200 N? Answer book says you want a net force of mg=100 N upwards but I'm not sure why 200 N upward is equal to a magnitude of g, which is only 100 N downward. What am I missing here?
Leigh
To "slow the mass at a rate equal to the magnitude of g" means you need to make the acceleration of the mass g upwards. So what must be the net force on the mass to give it such an acceleration?
(If you did nothing, and let gravity do its thing, the mass would have an acceleration of g downward. If you applied an upward force equal to its weight, the net force would be what? And the net acceleration would be what?)
Hmmm...so if I apply 100 N of force upward, then F=0 and if F=ma then acceleration also equals 0. So now...the velocity is constant, but not slowed down. So to slow it down so that a=10 (equal to the magnitude of gravity) I need to apply an additional 100 N of force upward, requiring 200N. If this is the correct line of reasoning then thank you so much for your assistance.
Leigh :)
Exactly right.
