| Thread Closed |
Tides due to the moon vs. the sun??? |
Share Thread | Thread Tools |
| Oct31-03, 04:32 PM | #1 |
The acceleration of gravity on the earth due to the sun is 177 greater than gravity on earth due to the moon.
Why are the tides predominantly due to the moon and not the sun, in spite of this number??? Nautica |
| Oct31-03, 05:20 PM | #2 |
Recognitions:
I can't give you any numbers, but the moon is so much closer that its effect on the oceans is much larger than that of the sun.
| Oct31-03, 05:41 PM | #3 |
Mentor
| Oct31-03, 06:10 PM | #4 |
Tides due to the moon vs. the sun???Thus, the sun is 26730000 times more massive than the sun and 400 times the distance. therefore its g-force on the Earth is 26730000/400² = 167 times that of the moon's, but its tidal effect is 26730000/400³ = 0.4 times, or a little less than 1/2 that of the moon's/ |
| Oct31-03, 06:11 PM | #5 |
But the 177 x's is based on how close the moon is to the earth relative to the distance of the sun to the earth - distance has already been taken into consideration. So, I do not see how distance from the sun to the earth vs the moon to the earth makes a difference in the effect of the tides. Thanks Nautica |
| Oct31-03, 06:45 PM | #6 |
The sun is 149,000,000 million miles away from the Earth so the distance difference is about .00856 %. This means that the difference in force accross the Earth varies by about .017% The moon is 384000 km away, so the % distance difference is 3.3%, and the force difference is about 6% If the acceleration due to gravity of the sun is 167 time that of the moon, then its tidal effect (the difference in force between far and near side of the Earth) is 167 * .017% = 2.839%, when compared to the moon's, or again, about 1/2. |
| Oct31-03, 06:50 PM | #7 |
Tidal forces aren't caused by the strength of gravitational attraction; they're caused by the differences in gravitational attraction at different points on an object.
Here's an exercise for you. We know the mass of the sun is 1.99 * 10^30 kg. The mass of the moon is 7.35 * 10^22 kg. The earth's radius is 6.38 * 10^6 m. (assume all of these values are exact) At a particular point in earth's orbit, its center is 1.50 * 10^11 m from the center of the sun. Compute the acceleration due to the sun's gravity at the point of the earth nearest to the sun, and the acceleration at the point of the earth farthest from the sun. The tidal stress on the earth due to the sun is (proportional to) the difference of these two accelerations. At a particular point in the moon's orbit, its center is 3.84 * 10^8 m from the center of the earth. Do the same calculation as you did for the sun. You'll find the tidal stress caused by the moon is greater! |
| Oct31-03, 10:39 PM | #8 |
Is that not what I did, when I determined that the pull of the sun was 177 times greater than that of the moon???
Thanks Nautica |
| Oct31-03, 11:10 PM | #9 |
The near side to the sun is 149,000,000 - 6378 km = 148993622 from the sun, and the far side is 149,000,000 + 6378 km form the sun. You need to calculate the acceleration due to gravity at each of these distances and the sun's mass, and then take the difference between the two to get the net force acting across the Earth which causes solar tides. For the moon, the distances are 384000 - 6378 = 377622 km and 384000+6378 = 390378 km. If you calculate the net difference for these distances, using the moon's mass, you will find that it is twice as great as that of the Sun. |
| Nov1-03, 12:28 AM | #10 |
Tidal forces are important in relativity's spacetime, where gravitation acts not only radially but angularly between finite masses.
| Nov1-03, 09:21 AM | #11 |
Nice, I am a little slow, but have now figured out what you are saying.
Thanks Nautica |
| Nov1-03, 10:47 AM | #12 |
I did what you said and it appears that the difference of gravitional pull on each side due to the moon is 1.068678428 x's stronger on the near side than the far side.
The sun is 1.000170496 greater on the near side than the far side. So how does this account for the fact that the sun only has half of the effect when the numbers show it should have 93% of the affect. Thanks Nautica |
| Nov1-03, 11:47 AM | #13 |
Mentor
You didn't account for the difference in gravitational force - the number you posted in the beginning which got you confused in the first place. That number is how you relate the actual tidal force caused by each.
So convert those two numbers to percent (chop off the 1 then multiply by 100%), then multiply the sun's by the difference in gravitational force. |
| Nov1-03, 12:11 PM | #14 |
Remember I said compute the difference, not the ratio.
| Nov1-03, 12:47 PM | #15 |
The difference in the pull of the moon is 2.20 x 10^-6
The difference in the pull of the sun is 1.01 x 10^-6 Which is .457 or roughly 1/2. You guys are unbelievable. Thanks Nautica |
| Feb24-04, 08:44 AM | #16 |
Thanks people!
This information was really useful to me!! BUT: WHY is it the DIFFERENCE between forces on the far and the near sides of the earth that determines the tides?? Would there not be tides when these forces were (theoretically) equal? I thought the tides are determined by the difference between the gravitational force and the centrifugal force. And that the differences between the far and the near sides of the earth arise because of the difference in direction of the centrifugal force on both sides... Can somebody explain me why?? |
| Feb24-04, 01:11 PM | #17 |
I think this ties in with your question.
http://192.211.16.13/curricular/astr.../tidecause.htm By the way, Anne-ke? Strange name, you wouldn't happen to be Belgian would you? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Tides due to the moon vs. the sun???
| Why does Moon cause larger tides than Sun? | Introductory Physics Homework | 6 | ||
| If the moon was twice as far away from the earth as it actually is, how would tides b | General Astronomy | 11 | ||
| The Moon and The Tides | Earth | 20 | ||
| If the tides on earth one meter high how far away is the moon? | Introductory Physics Homework | 9 | ||
| Moon and tides (tide on the moon instead of earth) | General Physics | 7 | ||
