Ground Fireworks: Witness Epic 20-Minute Show
  • Thread starter Thread starter BicycleTree
    Ground
The discussion revolves around the concept of experiencing a professional-grade fireworks show from a very close distance, specifically within a plexiglass enclosure. Participants explore the feasibility, safety, and potential regulations surrounding such an experience, as well as the materials and conditions necessary to withstand the heat and impact of fireworks.
  • Some participants propose standing within 30 feet of the fireworks in a plexiglass enclosure with ear protection, questioning the safety and experience of such proximity.
  • There are suggestions to consider additional protective measures, such as wearing sunglasses and possibly using water or oil on the plexiglass to mitigate heat effects.
  • One participant mentions the importance of separation distances for safety, referencing a rule of thumb regarding the radius needed based on the size of the fireworks mortars.
  • Concerns are raised about the melting points of various plastics used for the enclosure, with detailed comparisons of materials like acrylic and polycarbonate regarding their heat resistance and transparency.
  • Another participant humorously suggests that the experiment could be done to annoy others, while also discussing the potential for a larger viewing area with multiple enclosures.
  • There is a technical discussion about the temperatures at which different firework components burn, raising questions about the implications for the safety of the plexiglass enclosure.
  • One participant speculates that the speed of fireworks might allow them to bounce off the plexiglass without causing significant heating.
Participants express a variety of opinions on the feasibility and safety of the proposed fireworks experience. There is no consensus on the practicality of the idea, with some expressing enthusiasm while others raise significant safety concerns and regulatory issues.
Discussions include various assumptions about safety regulations, the effectiveness of different materials under extreme conditions, and the potential for insurance requirements that remain unresolved.
BicycleTree
Has anyone ever set off a really big professional-grade star burst style firework on the ground, in a desert somewhere? Maybe at the Burning Man festival?
I am thinking you could stand within 30 feet of the epicenter in a plexiglass enclosure, with ear protection, and be unharmed. What would an entire 20-minute fireworks show look like when experienced from almost ground 0?
You might want to wear sunglasses too.
Elwood: "It's 30 feet to ground 0, we've got a Plexiglass bubble and a pair of earplugs, it's dark, and we're wearing sunglasses." :cool:
Jake: "Hit it."
I've seen shows on professional pyro people. There was just one on yesterday. They have a control booth close to the launch site or whatever it's called. You can try some of these sites if you're bored being home sick. You're looking for Class B a.k.a. 1.3G Fireworks.
http://www.americanpyro.com/index.html (pro)
http://www.fireworksafety.com/safety.htm (seems mostly consumer)
http://www.wf.net/~lcrump1/display.htm
The state laws may specify minimum distances for everything.
Dear BicycleTree..
what is the point of this idiotic experiment?
Separation distances are one of the most important features of display safety. The general rule of thumb is that the radius of the display site should be at least 70 feet for each inch of internal diameter of the largest mortar. All mortars less than 3 inches in diameter are treated as 2-inch mortars. (3.1.3) Therefore, a show with one or more 8-inch diameter shells would require a display site with a 560-foot radius...
- http://firechief.com/mag/firefighting_pyrotechnic_preplan/
Yeah, I'm home with nothing to do. :rolleyes: There's much more to the article, BTW.
cronxeh said:
Dear BicycleTree..
To watch professional-grade fireworks go off all around you. It would be awesome.
No, I'm just kidding. It would be done just to piss you off.
If you're willing to sacrifice a little coolness, you could elevate the fireworks to a tower ten feet or so off the ground and have a whole field full of plexiglass viewing bubbles, two hundred people watching white phosphorous flares arching over them, streaking past them, and fissing down among them. In the fireworks that explode to hundreds of feet wide--the type that seemingly cover half of Plymouth Harbor--I wonder just how fast the sub-fireworks exit from the original explosion. That would probably determine the thickness of the Plexiglass.
Regulations might be a problem, but you could probably get an exception made if it were clear you are making proper safety precautions for viewers.
Heh heh, that's an understatement. Just try to get an insurer to provide a policy for that. I expect regulations of such displays require insurance before permits are issued.
Forget acrylics—they'd melt. Maybe not all the way through, but enough to make them unusable in future and quite possibly enough to release toxic chemicals to the interior.
Hmm--you could have the plexiglass sprayed with water or clear oil. Hopefully the trickles wouldn't interfere with the viewing. Maybe there is some solid heat-resistant transparent substance that you could coat the plexiglass with. Some reduction in transparency is OK--you can just wear lighter sunglasses to make up the difference. If you had a rounded bubble, the fireworks could never be in contact with the plexiglass very long.
plexiglass viewing bubbles.. interesting
consider this however: melting point of most plastics is from 310 degrees F (Noryl) to about 621 F (Teflon). Ah but those arent transparent! The ones you want are transparent plastics, and Acrylic has a continuous service temperature in presence of air of about 180 F max. Coefficient of linear expansion for Acrylic is 1.3 * 10^4. It ranks pretty good with other transparent plastics - at about 92% light transmittance - you may also consider Perspex (92% light transmittence, continuous service temp 180F); or better yet-
Polycarbonate aka Lexan (91% light transmittence, continuous service temp 475F - will start deflecting at 539F, coeff of linear expansion 3.9 * 10^5 );
PALSUN or PALTUF polycarbonate (89% light transmittence, continuous service temp 248 F)
Now the firework components:
Red strontium salts, lithium salts
lithium carbonate, Li2CO3 = red
strontium carbonate, SrCO3 = bright red
Orange calcium salts
calcium chloride, CaCl2
calcium sulfate, CaSO4·xH2O, where x = 0,2,3,5
Gold incandescence of iron (with carbon), charcoal, or lampblack
Yellow - sodium compounds ( sodium nitrate, NaNO3; cryolite, Na3AlF6)
Electric White - white-hot metal, such as magnesium or aluminum, barium oxide, BaO
Green - barium compounds + chlorine producer, barium chloride, BaCl+ = bright green
Blue - copper compounds + chlorine producer, copper acetoarsenite (Paris Green), Cu3As2O3Cu(C2H3O2)2 = blue
copper (I) chloride, CuCl = turquoise blue
Purple - mixture of strontium (red) and copper (blue) compounds
Silver - burning aluminum, titanium, or magnesium powder or flakes
How hot do those burn?
Kelvin Celsius Color
750 480 faint red glow
850 580 dark red
1000 730 bright red, slightly orange
1200 930 bright orange
1400 1100 pale yellowish orange
1600 1300 yellowish white
> 1700 > 1400 white (yellowish if seen from a distance)
So from 750 Kelvin (red) to 1700 Kelvin (white) - that's about 890F to 2600F
You see.. the sucky thing is.. 890F > 475F. That is where those coefficient of expansions come into play - you can even calculate a double integral of the time it would take for a flare to pass through an n inches thick transparent plastic bubble and cook them alive inside.
Hmm... sounds like chicken wire in front of the plexiglass might be the only way to go. Unfortunately that would interfere with viewing. :frown:
It's not as bad as it seems, though. Most of these things would be moving at probably something like a hundred miles an hour when they hit the plexiglass. They'd bounce right off with hardly enough time to get it warm.
9K
11K
