How Does the EPR Paradox Challenge Our Understanding of Quantum Spin?
  • Context: Graduate
  • Thread starter Thread starter niehls
    Experiment Mind
The discussion centers around the EPR paradox and its implications for understanding quantum spin, particularly in the context of particle decay processes. Participants explore the nature of entanglement and the behavior of particles such as muons and pions in relation to quantum mechanics.
  • One participant suggests that a muon decays into two electrons, raising questions about the implications for spin measurement and entanglement.
  • Another participant corrects the claim, stating that muons do not decay directly into two electrons and that EPR tests typically do not involve muons.
  • A further contribution clarifies that the decay of a pion into two photons is a more appropriate example, discussing the entangled state of the photons and the implications for quantum mechanics.
  • One participant notes that the state of the photons cannot be treated as separate entities, emphasizing the concept of entanglement and the limitations it poses on instantaneous interaction.
  • Another participant points out that muons have spin 1/2 and decay into one electron and a gamma ray, correcting earlier misconceptions about muon decay.
  • Participants express confusion and clarify their intentions regarding the discussion of muon versus pion decay.
Participants do not reach consensus on the initial claim regarding muon decay, with multiple competing views presented about the nature of particle decay and entanglement. The discussion remains unresolved regarding the implications of these points for the EPR paradox.
There are limitations in the discussion regarding the accuracy of particle decay processes and the definitions of entangled states. Some assumptions about the nature of measurements and interactions are not fully explored.
niehls
I've been thinking about something for quite a long time now. A muon can decay into two electrons, right? Since the spin of the muon is zero, the total spin of the elctrons must also be zero. That means one of the electron has up spin and the other one has down spin. According to the Copenhagen model the electron actually has neither (or both) before we measure it. ok, so long all is fine. If we measure one electron to be up, we know the other one must be down. (Which by itself is a bit odd). Now to the tricky part. What if, we measure the spin of both electrons with a small time discrepancy. The time between the measurement must not be longer than the time it takes to travel from one of the electrons to the other with the speed of light. Every time we will find, that the electrons has opposite spin, but there is no chance of the electrons ever "interacting". How can the second electron "know" which spin to apply if both electrons, before the measurement, was in the same indeterminate mode?
Cheers
/edit:
Ah, i just found the name of the setup
EPR (Einstein Poldalsky Rosen) -experiment
i'll read some more on the subject
Muons don't have a direct decay path into 2 electrons, as far as I know. EPR tests do not use muons for entangled pair production.
Muon (either plus, minus or zero) cannot decay into 2 electrons, because muon has the same charge as single electron. The simplest decay would be probably pion at rest to 2 gammas:
[tex]\pi^0 \to \gamma + \gamma[/tex]
where gamma's are created in singlet state (conservation of ang. momentum):
[tex]\Psi_{12} = \frac{1}{\sqrt{2}}\left( \Psi_1(\mathrm{up})\Psi_2(\mathrm{down}) - \Psi_1(\mathrm{down})\Psi_2(\mathrm{up})\right)[/tex] .
We cannot write this function as a product: [tex]\Psi_{12} \neq \Psi_1 \times \Psi_2[/tex], which we could if the 2 photons (gammas) would be separate entities (I'm not sure if this is the right word). If I understand correctly, in this sense, the state [tex]\Psi_{12}[/tex] can be called "entangled" state (meaning: "connected"). According to QM, it's correct only to refer them as a single entity or as a one system, not as 2 separate photons. Of course, this doesn't really solve the problem of instant interaction. A little comfort to Einstein's theory of relativity is that this weird interaction still doesn't allow to transfer information at instant (so causality is not affected).
Note to igor s - you described pion decay, not muon. Muons have spin 1/2 and decay into one electron + gamma ray. The electron has spin 1/2. Muon and electron each have charge -1.
Yes, I made some corrections to my post that may have confused you. Hope it's clear now. My intention wasn't to describe muon decay.
ok, sorry. muon, pion, remembered it the wrong way 'round.
  • · Replies 42 ·
  • · Replies 36 ·
10K
  • · Replies 41 ·
