Making 50%v/v and 50%w/v glycerol solutions.
  • Thread starter Thread starter sobored
This discussion clarifies the preparation of 50% v/v and 50% w/v glycerol solutions, highlighting the key differences between the two. A 50% v/v solution consists of 50 mL of glycerol in a total volume of 100 mL, while a 50% w/v solution contains 50 g of glycerol per 100 mL of solution. The density of glycerol is 1.25 gm/mL, which is essential for calculating the weight of glycerol in a volume-based solution. Understanding these distinctions is crucial for accurately preparing glycerol solutions for applications such as cell storage.
  • Understanding of solution concentration terminology (v/v and w/v)
  • Basic knowledge of glycerol properties and density (1.25 gm/mL)
  • Familiarity with laboratory measurement techniques (volume and weight)
  • Knowledge of preparing solutions using distilled deionized water (ddH2O)
  • Research the implications of using glycerol in cryopreservation techniques
  • Learn about calculating solution densities for various concentrations
  • Explore the differences between volumetric and gravimetric measurements in solution preparation
  • Investigate the role of glycerol in microbiological and cell culture applications
Laboratory technicians, researchers in cell biology, and anyone involved in preparing glycerol solutions for cryopreservation or other scientific applications will benefit from this discussion.
sobored
How to make 50%v/v and 50%w/v glycerol? What is the difference? Glycerol/glycerin has a density of 1.25 gm/mL.
Thanks!
Chemistry news on Phys.org
I guess you are making frozen stock of cells.
Glycerol usually comes in a liquid form. So 50% v/v would be 50 mL of glycerol in a 100 mL solution. A 50% w/v would be 50 g per 100 mL of solution. So basically you measure your glycerol by weight (50 g) or by volume (50 mL), depending on your solution, then raise the volume to 100 mL with ddH20.
So if you known the density, all you have to do is calculate the amount of g in a 50% v/v solution and compare it to your 50% w/v solution. You can also calculate the density of both solution and compare it. basically one solution has more glycerol than the other one.
  • · Replies 16 ·
