Register to reply
Acceleration of the center of mass of this cylinder
by sterlinghubbard
Tags: accelerationcom
Share this thread:
sterlinghubbard
#1
Jul13-05, 08:26 PM
P: 5
A 2.81 kg hollow cylinder with inner radius 0.29 m and outer radius 0.5 m rolls without slipping when it is pulled by a horizontal string with a force of 47.7 N, as shown in the diagram below.
Its moment of inertia about the center of mass is .5m(r(out)^2 + r(in)^2).
What is the accelereation of the cylinder's center of mass? Answer in units of m/s^2.
What am I doing wrong? I found the Torque of the hollow cylinder by T = F(r). Then I found the angular acceleration by Torque = Interia * Alpha. Inertia was found using the supplied forumula. After finding the angular acceleration I found the Tangential Acceleration by TangentialAcceleration = radius * AngularAcceleration. What am I doing wrong?
Phys.Org News Partner Science news on Phys.org
Scientists discover RNA modifications in some unexpected places
Scientists discover tropical tree microbiome in Panama
'Squid skin' metamaterials project yields vivid color display
siddharth
#2
Jul14-05, 01:46 AM
HW Helper
PF Gold
siddharth's Avatar
P: 1,197
Isn't the moment of inertia of a hollow cylinder
[tex] \frac{1}{2} M (R_1^2 + R_2^2) [/tex]
So, your value of M/2 is not 0.5 but 2.81/2
sterlinghubbard
#3
Jul14-05, 08:01 PM
P: 5
Quote Quote by siddharth
Hence, .5M which is the same as 2.81/2.
siddharth
#4
Jul14-05, 11:23 PM
HW Helper
PF Gold
siddharth's Avatar
P: 1,197
Oh, you mean 0.5 * 2.81 . Didn't see that, sorry.
There wil be a torque due to friction, the value of which is not known. So, I don't think you can use the above equations alone to get the answer.
Have you applied Newton's second law in the horizontal direction? (ie, F-f = ma). Then eliminate f using all the equations and solve for a. That should give you the correct answer.
Register to reply
Related Discussions
Fluid Mechanics local acceleration and convective acceleration Advanced Physics Homework 1
Person's acceleration and object's acceleration Introductory Physics Homework 3
Centripetal acceleration, incorporating a change in acceleration around the circle... Introductory Physics Homework 3
Uniform Circular Motion: Centripital Acceleration vs. Acceleration Introductory Physics Homework 4
Compare acceleration to free fall acceleration Introductory Physics Homework 3
