Gauss's (hard to understand) Law
  • Thread starter Thread starter physics noob
    Law
The discussion revolves around understanding Gauss's Law in the context of a point charge Q located at the center of an uncharged thin spherical conducting shell. Participants explore the electric field E as a function of the radial distance r, considering different regions: inside the shell, within the shell material, and outside the shell.
  • Participants discuss the application of Gauss's Law to find the electric field in various regions, questioning how the presence of the conducting shell affects the electric field. There are attempts to clarify the implications of charge distribution on the shell and the concept of induced charges. Some participants express confusion regarding the lack of numerical values and the distinction between test charge q and the central charge Q.
There is an ongoing exploration of the electric field in different regions, with some participants providing insights into the behavior of charges within the conducting shell. Questions remain about the charge distribution and the implications for the electric field, indicating a productive discussion without a clear consensus yet.
Participants note the importance of understanding the charge distribution on the conducting shell and the implications of Gauss's Law, particularly in relation to the electric field being zero within the conducting material. There is also mention of the need for clarity on the definitions of charges involved.
physics noob
ok here the problem I am having...
a point charge Q rests at the center of an uncharged thin spherical condcting shell. with is the the electric field E, as a function of r...then it asks for r less than the inner radius of the shell... then it asks for inside the shell, and finally beyond the shell.
now how I am invisioning the figure is almost like a washer, with a thickness, like the rings of saturn...
so for the first part i need to find E as a function of r...so i thinks to myself... E0 (constant) = 1/ (4(k)(pi)) and gauss's law states
flux = EA flux also = q/E0 so EA = q/ Eo after a little algebra
i get E= Qk/ R^2 using SA of a sphere for area... ok so I am pretty sure that's right for the first question...if not please tell me where i went wrong...next part asking for r less than inner radius of shell?
i have no idea what to put...one thing i do understand is that when there is a charge in a shell, the electric field continues as if there was no shell present, by this i mean if Q is positive , negative charges accumulate on inner shell circumference, and positive accumlate on SA of total spherical shell... this is all kind of new to me, and i don't think i have a great grasp on all of this,,,,,,also a coule off topic questions...what is the diff,,,between q (test charge) and Q////// as always thanks a million for any help/ information.
I assume that the second part is asking you what is the electric field less than the outer surface of the shell but more than the inner surface of the shell, i.e. what is the electric charge inside the conducting shell.
Your right, outside of the whole shell, you will not see the shell because it will not insulate the charge, so it will be like the shell didn't exist.
And also inside of the shell, it will be like the shell doesn't exist because the charge doesn't need to move through the shell to get from the charge to the point where you are testing.
Hope this helps,
~Lyuokdea
yes, it does,,, so i guess i would just describe what the electric field does,,, i think I am getting confused because of the lack of numbers, i guess i just explain what's happening. thanks
You are asked to calculate E(r), when :
(i) r < R(in)
(ii) R(in) < r < R(out)
(iii) r > R(out)
In the first and third cases, the total enclosed charge is Q. So, you can find the fields from Gauss' Law, and they will have the same form. But this is not so in the second case. The charge enclosed here will be different because of the induced charges on the inner surface of the shell. So, find the new value of the enclosed charge, and again calculate the field from GL.
Is the result you get for (ii) surprising, or expected ?
so would Q=0 inside the shell since all charges are found on the surface of conductors? thanks everyone for the help
I think you are talking about the total charge Q within a spherical Gaussian surface that is inside the material of the shell. If so, since the electric field is zero within the conducting shell, the total charge Q contained in that Gaussian sphere is zero.
In this case, though, I think you want to reason the other way round. You are asked to find the field on this Gaussian surface, so you must determine the charge enclosed. First there's +Q at the origin, and then there's -Q distributed on the inside of the shell. So the total enclosed charge is zero, and hence, the field within the material of the shell is zero (as expected, since the field inside the body of a conductor must be zero).
OK, but how do you know that there's -Q distributed on the inside of the shell? (You need to start with some knowledge; I usually make use of the fact that the field must be zero within the conductor.)
  • · Replies 23 ·
