Current produced by rev of electron
The discussion revolves around calculating the current produced by an electron revolving around a proton in a hydrogen atom, specifically focusing on the electron's rate of revolution and its implications for current. The subject area includes concepts from electromagnetism and atomic physics.
  • Participants explore the relationship between the electron's rate of revolution and the resulting current, questioning how to convert angular velocity into current. Some suggest breaking down the problem into steps involving the number of revolutions per second and the charge of the electron.
The discussion is active, with participants providing guidance on how to approach the problem. There is a focus on understanding the relationship between the electron's motion and the current produced, but no explicit consensus has been reached regarding the final answer.
Participants express uncertainty about whether additional factors, such as current density, need to be considered in the calculation.
kanki
I'm having a bit difficulty in understanding this question...
In a Hydrogen aton, an electron goes round the proton at a rate of 7 x 10^5 rev/s in a circular orbit of radius 5.0 x 10^-11
What is the current produced by the revolution of electron?
Well, the formula for current is Q/t and Ne/t. I don't know how to convert the angular velocity to current. Please help!
1. If you look at a point along the electron's "orbit", how many times does the electron passes through that point in a second?
2. If an electron has a charge e, from your answer to (1), how much charge has passed through that point per second?
3. Oh wait, what you now have is... look at that! You have "amount of charge passing through per second"! This is current!
Zz.
Oh then i just have to use the number of revolutions per second.
The electron passes through the point 7 x 10^5 times in a second, so the amount of charge, Q is equal to 7 x 10^5 times the charge e in a second?
And that's the answer?
It should be, unless it wants current density or something I'm not noticing.
Zz.
11K
