Photon propagator in an arbitrary gauge
The discussion revolves around deriving the photon propagator in an arbitrary gauge within the context of quantum field theory. Participants explore the mathematical formulation involving the Lagrangian, equations of motion, and the Green function as a vacuum expectation value of the time-ordered product of fields.
  • One participant presents the Lagrangian with a gauge-fixing term and derives the equation of motion for the photon field.
  • Another participant suggests inverting the quadratic differential operator in momentum space to facilitate the calculation of the propagator.
  • A later participant asks for clarification on how to invert the matrix associated with the quadratic differential operator using linear algebra methods.
  • Another participant proposes that the inverse matrix must be a linear combination of the metric tensor and the momentum tensor, suggesting an Ansatz for the form of the inverse.
  • Responses indicate that the choice of a linear combination is based on the requirement to construct a Lorentz tensor, although no formal justification is provided.
Participants generally agree on the approach to derive the propagator and the necessity of using linear combinations of tensors, but there is no consensus on the specific methods for inverting the matrix or the justification for the Ansatz.
Some participants express uncertainty about the inversion process and the justification for the form of the inverse matrix, indicating that assumptions about the structure of Lorentz tensors are not fully resolved.
kryshen
My aim is to derive the photon propagator in an arbitrary gauge. I follow Itzykson-Zuber Quantum Field Theory and start from the Lagrangian with gauge-fixing term:
[tex] {\cal L}(x) = -\,\frac{1}{4}\,F_{\mu\nu}(x)F^{\mu\nu}(x) -<br /> \,\frac{1}{2\xi}\,(\partial_{\mu}A^{\mu}(x))^2[/tex]
I get the following equation of motion:
[tex] \left(\Box g_{\mu\nu} - \Big(1-\frac{1}{\xi}\Big) \partial_\mu \partial_\nu \right) A^\nu (x) = 0[/tex]
We can write the solution as a superposition of plane waves:
[tex] A^{\mu}(x) = \sum_{\lambda}\int \frac{d^3k}{(2\pi)^3 2\omega(\vec{k}\,)}\,<br /> \Big[c(\vec{k},\lambda)\,e^{\mu}( \vec{k},\lambda)\,e^{-ik\cdot x}<br /> + c^{\dagger}(\vec{k},\lambda)\,e^{*\mu}( \vec{k},\lambda)\,<br /> e^{+ik\cdot x}\Big],[/tex]
where [tex]e^{\mu}[/tex] is a polarization vector.
Then I use the following commutation relations for the creation and annihilation operators to quantize the field:
[tex] [c(\vec{k},\lambda),\,c^{\dagger}(\vec{k}\,',\lambda\,')] <br /> = (2 \pi)^3\, 2 \omega (\vec{k})\, \delta^{(3)} (\vec{k}-\vec{k}\,')\,\delta_{\lambda \lambda\,'}[/tex]
[tex] [c(\vec{k},\lambda),\,c(\vec{k}\,',\lambda\,')] <br /> = [c^{\dagger}(\vec{k},\lambda),\,c^{\dagger}(\vec{k}\,',\lambda\,')] = 0[/tex]
I want to calculate the Green function as a vacuum expectation value of the time-ordered product:
[tex] -\,i\,D^{\mu\nu}(x - y) = \langle 0|{\rm T}(A^{\mu}(x)A^{\nu}(y))|0\rangle[/tex]
To do this I need to derive the expression:
[tex] \sum_\lambda e^{\mu}(\vec k, \lambda) e^{*\nu} (\vec k, \lambda) = <br /> \left(g^{\mu\nu} - (1-\xi) \frac{k^\mu k^\nu}{k^2}\right)[/tex]
I am novice at QFT. Please, could you advise on the methodology, how I could derive the expression for the sum of the products of polarisation vector components.
You simply need to invert the quadratic differential operator above in momentum space (aka Fourier space).
In momentum space the photon kinetic term looks like
[tex] \int \frac{d^{4}k}{(2 \pi)^{4}}<br /> A^{\mu} (k) \left(k^{\beta} k_{\beta} g_{\mu\nu} - \Big(1-\frac{1}{\xi}\Big) k_\mu k_\nu \right) A^\nu (-k)[/tex]
The quadratic differential operator becomes a (0 2) tensor [itex]M_{\mu \nu} \equiv \left(k^{\beta} k_{\beta} g_{\mu\nu} - \Big(1-\frac{1}{\xi}\Big) k_\mu k_\nu \right)[/itex], which you can invert by linear algebra methods.
I know this is an old post, but could anyone comment on how to invert the [tex]M_{\mu\nu}[/tex] matrix above by linear algebra methods?
The inverse matrix has to be a linear combination of [tex]g^{\mu \nu}[/tex] and [tex]k^{\mu}k^{\nu}[/tex], so Ansatz [tex]Ag^{\mu \nu}+Bk^{\mu}k^{\nu}[/tex] should work.
Thank you, that did work, how did you know it had to be a linear combination of those things?
Well, what else could it be? :) To construct a Lorentz tensor with two indices, there really is no other choice. I cannot justify it any better than by noticing that it works.
  • · Replies 0 ·
  • · Replies 24 ·
