What is the % efficiency of this system ?
  • Thread starter Thread starter PhysicsNoob88
    Efficiency System
The discussion revolves around a physics problem set involving concepts of momentum, power, and efficiency in mechanical systems. The original poster presents multiple scenarios, including a collision between fish, a pulley system lifting weights, and an inelastic collision between two objects, seeking assistance with calculations and understanding.
  • Mixed
  • Participants suggest using conservation of momentum for the collision problems and provide formulas for calculating power and work. Some express urgency for quick answers, while others emphasize the importance of understanding rather than simply providing solutions.
Some participants have offered guidance on how to approach the calculations, particularly for power and momentum conservation. There is an ongoing exploration of the physics principles involved, but no consensus has been reached on specific answers or methods.
The original poster has indicated a need for step-by-step assistance and has expressed uncertainty about their initial calculations. There are also reminders about the forum's policy against doing homework for others.
PhysicsNoob88
These are some problems I am having difficulty with, the first problem I got an answer but I am unsure if it is correct and the others I have no clue. If you can step by step how to do them it would be greatly appericated.
A 12 kg. fish swimming at a velocity of 3 m/s swallows an absent-minded 4 kg fish swimming toward it at 10 m/s. What is the velocity, including direction (e.g., direction of larger fish or smaller fish), of the larger fish after lunch ?
I used m=mv and I got the answer to be -4m/s (big fish travels bacwards from its original postion) < I am not sure if this is correct if you can verify that would be awsome.
2) A pulley system is set up to lift boxes weighing 750 N from ground level to a position 6 meters high. A man pulls 30 meters of rope with a force of 200 N.
(b) If it takes the man 50 seconds to accomplish this task, (1) how much power is he putting in and (2) how much power is he getting out ?
(c) What is the % efficiency of this system ?
3) Consider the inelastic collision between two objects (A and B). Object A has a mass of 10 kg. and is moving at 12 m/s. Object B has a mass of 6 kg. and is moving at 8 m/s toward object A (Objects A and B are moving towards each other). How much energy is dissipated as heat ?
HINT: The velocity of the wreckage must first be determined. Then use the principle of conservation of energy.
To whom who ever does it I truly thank you. :redface:
I need the answers by 10 minutes from now, please anyone help...
For number two, [itex]P = \frac{W}{t}[/itex] and [itex]W= Fd[/itex]. Can you go from here?
the rules are that we don't do your homework for you.
For No. 1 first conserve momentum and then v = momentum/mass
For no.3
whether the collision is elastic or inelastic momentum is conserved.
The difference of initial and final energies is the heat dissipated.
  • · Replies 25 ·
  • · Replies 22 ·
