Angular momentum at near-c velocities
The discussion centers on the transformation of angular momentum at relativistic velocities, particularly its representation as an antisymmetric tensor and the implications of this for both classical and quantum contexts. Participants explore the definitions, transformations, and interpretations of angular momentum in relation to different reference points and worldlines, as well as the relationship to quantum spin.
  • Some participants assert that angular momentum is defined as an antisymmetric rank 2 tensor that transforms similarly to other tensors, but emphasize the complexity of transformations depending on the chosen base point.
  • There is a discussion about the implications of the condition u_{a} S^{ab} = 0 when the center of mass is the base point, with some suggesting that this condition implies the tensor cannot include quantum spin.
  • Others argue that the tensor S^{ab} depends on both the base point and the four-velocity, indicating that the relationship between angular momentum and spin is more intricate than initially suggested.
  • Participants mention scalar invariants such as S^{a} S_{a} and S^{ab} S_{ab} as quantities that remain invariant under transformations, linking them to the angular momentum operator in quantum mechanics.
  • There is a proposal to define angular momentum in terms of integrals over spacelike hyperplanes, which introduces additional complexity when not using a center of mass.
  • Some participants highlight that the decomposition of angular momentum into orbital and spin components is standard in multipole moment analysis, but the definitions and implications vary depending on the reference frame used.
Participants express differing views on the implications of the tensor representation of angular momentum, particularly regarding its relationship to quantum spin and the effects of reference points. The discussion remains unresolved with multiple competing perspectives on these issues.
Limitations include the dependence on the choice of reference points and worldlines, as well as the complexity of transformations that may not be universally applicable. The discussion also touches on the intricacies of defining angular momentum in both classical and quantum frameworks.
Mortimer
I was wondering how angular momentum transforms at relativistic velocities. I read that it is defined as an antisymmetric tensor, quite similar to the electromagnetic field tensor. Does that mean that there are more similarities between the two (also in the transformation)? And if yes, how to interpret the components of the tensor? Clearly some of its components must represent spatial angular momentum, but what is the rest? Rotation about the temporal axis? Spin? :confused:
Yes, angular momentum is an antisymmetric rank 2 tensor. It transforms just like any other such tensor. There are, however, two types of transformations you can talk about here. I just mentioned a transformation of the tensor from one coordinate system to another.
But angular momentum is also defined with respect to a particular base point (more precisely, it is defined along a chosen worldline, and the hypersurfaces orthogonal to that line also enter the definition). This is true even in Newtonian physics (e.g. a ball moving in a straight line has an angular momentum unless it is moving radially away from the chosen base point). Transforming from one point to another is considerably more complicated. The ideas in general are rather intricate to describe in any detail here.
I'll just say that if the base point is chosen to be the center-of-mass, then it happens that [tex]u_{a} S^{ab} =0[/tex] (this condition is actually used to define center-of-mass in more general treatments), where u is the four-velocity of the center-of-mass. This implies that [tex]S^{ab}[/tex] can be entirely replaced by a vector
[tex] S^{a} = \epsilon^{abcd} u_{b} S_{cd}[/tex]
Now, [tex]S^{a}u_{a}=0[/tex], so this is basically a 3-vector (in the center-of-mass frame). It is called the 'spin' angular momentum, and is closely analogous to what you're used to in Newtonian physics. If z is not at the center-of-mass, there is also an 'orbital' component which which basically just takes into account things like the offset ball example above.
By far the best treatment I know of these things is unfortunately in a hard-to-find book by WG Dixon written about 25 years ago (titled "Special Relativity: The Foundation of Macroscopic Physics"). I don't know what level you want to learn things at, though. That book is nowhere near as introductory as its title suggests!
Thanks for the info Stingray. Looking at the scarce reactions, I must have posed an either impopular or tough topic. I'm looking for a rather detailed description.
If [itex]u_aS^{ab}=0[/itex] for all [itex]u_a[/itex] with the center of mass as base point than it seems to me that this tensor cannot include the quantum spin, am I right? After all that spin should be invariant.
I think that you misunderstood slightly. When you say that [tex]S^{ab} u_{b}=0[/tex] for all u, it sounds like you're considering S to be fixed while u is varied. This is not correct. S itself depends on both the base point and u. The latter quantity effectively defines a preferred time direction. So there is only one constraint.
There is no lack of invariant quantities either. [tex]S^{a} S_{a}[/tex] is a scalar invariant, for example. More generally, [tex]S^{ab} S_{ab}[/tex] is always an invariant no matter whether we're using center-of-mass definitions or not. These quantities are related to the square of the angular momentum operator in quantum mechanics. In any case, here are some details of the classical theory:
As mentioned, the angular momentum depends on both a choice of base point and a preferred time direction. This would usually (though not always) be dealt with by defining a 'reference' worldline [tex]z^{a}(s)[/tex]. Of course, this has a 4-velocity [tex]u^{a}(s) = \dot{z}^{a}(s)[/tex] (assume it is normalized, so s is a proper time for someone moving along z). Now, the direction of the 4-velocity is naturally interpreted as the time direction of an observer on z, so define a set of spacelike hyperplanes [tex]\Sigma(s)[/tex] that intersect [tex]z^{a}(s)[/tex], and are orthogonal to [tex]u^{a}(s)[/tex]. These can be taken as naturally-defined 'moments of time.' Note, however, that these surfaces will intersect each other if they are extended too far (unless [tex]\dot{u}^{a} =0[/tex]).
Now, both the linear and angular momenta are naturally defined as objects on z. In terms of 'normal' variables, though, they are integrals over the hyperplanes. The most common definitions (again, these are not universal) look like
[tex] p^{a}(s) = \int_{\Sigma(s)} T^{ab}(x) d\Sigma_{b} ,[/tex]
[tex] S^{ab}(s) = \int_{\Sigma(s)} \left(x-z(s) \right)^{[a} T^{b]c}(x) d\Sigma_{c} .[/tex]
In the quantum theory, particles have intrinsic spins that can add extra terms here.
Anyway, you can see that the angular momentum depends on the base point z, but also on the surface of integration (defined here in terms of z and u). It is therefore instructive to rewrite these quantities more abstractly as [tex]p^{a}\left(\Sigma(u,z) \right)[/tex] and [tex]S^{ab}\left(z, \Sigma(u,z) \right)[/tex].
Let's now define a center-of-mass. This fixes the reference line, so let's forget about the one we've assumed to exist for now. Instead, choose a single point [tex]z(s_{0})[/tex]. Then it can be shown that under reasonable conditions, there exists a unique vector [tex]u^{a}[/tex] such that
[tex] p^{a} \left( \Sigma(z,u) \right) \propto u^{a}(z)[/tex]
From looking at the integral form of p, you can see that this is actually a highly implicit definition. In any case, given any z, it fixes a u.
We now need to find a way to pick out a unique z. This is done with
[tex] S^{ab} \left( z, \Sigma(z,u) \right) p_{b} \left( \Sigma(z,u) \right) = S^{ab} u_{b} =0[/tex]
Again, this is extremely implicit, but it works. Using the integral expression for the angular momentum, you can show that this is equivalent to the usual expression defining a center-of-mass expression:
[tex] \int_{\Sigma} (x-z)^{a} \left( u_{b} u_{c} T^{bc} \right) d\Sigma =0[/tex]
where the quantity in parentheses is usually interpreted as the mass density seen by on observer with velocity u.
Anyway, taking these two conditions together defines a unique reference line usually called the center of mass. Rewriting the integral for [tex]S^{ab}[/tex] so that it gives [tex]S^{a}[/tex] shows that this quantity is basically an integral over the cross products [tex]\bf{r} \times \bf{\mathcal{P}}[/tex], where [tex]\bf{\mathcal{P}}[/tex] is a momentum density. This is just as it is in Newton's theory.
We also have (at least) two natural scalar invariants in this formalism:
[tex]m^{2} := -p^{a} p_{a}[/tex]
[tex]|S|^{2} := S^{a} S_{a}[/tex]
Neither of these quantities are necessarily constants (ie independent of s) unless there are no forces acting on the system.
Continuing in the next post...
It is now interesting to look at what happens when we're not using a center of mass. Then it is still possible to define [tex]S^{a}[/tex]. The difference is that it will no longer contain all of the information in [tex]S^{ab}[/tex]. It becomes
[tex] S^{a} = \int \epsilon^{abcd} u_{b} (x-z)_{c} T_{df} u^{f} d\Sigma<br /> \\<br /> = \int \epsilon^{abcd} u_{b} (x-z)_{c} \mathcal{P}_{d} d\Sigma[/tex]
where again,
[tex] \mathcal{P}^{a} = T^{bc} \left( \delta_{b}^{a} + u_{b} u^{a} \right) u_{c}[/tex]
The quantity in parentheses is a projection operator if you're not familiar with it.
Anyway,
[tex] S^{ab} = \epsilon^{abcd} u_{c} S_{d} + S^{ab}_{\rm{orb}},[/tex]
where the second term vanishes in the center of mass frame. I might have a sign or factor of two wrong on the first term, but let's assume that its correct (I always forget how to contract [tex]\epsilon^{abcd}[/tex]'s).
Combining these expressions gives
[tex] S^{ab}_{\rm{orb}} = - \int_{\Sigma} (x-z)^{[a} u^{b]} \left( u_{c} u_{d} T^{cd} \right) d\Sigma[/tex]
In this context, we now have more scalar quantities, but they are not as fundamental as the previous ones.
To back up a bit, all of this stuff about defining reference lines and so on is actually quite standard whenever one wants to decompose something in terms of multipole moments. The linear and angular momenta are basically the monopole and dipole moments of the stress-energy tensor.
Thanks again Stingray. I'll need some time to work my way through that info. If I get stuck somewhere I will ring a bell.
Rob
I'm not sure much the following will help - it's an old link I found. It would probably help to know about p-forms and the wedge product, and/or Clifford algebra
http://panda.unm.edu/Courses/finley/P495/TermPapers/relangmom.pdf
The thing you need to know is that the cross product in three dimensions is actually the dual of a geometric entity known as a "bi-vector". You can think of a bi-vector as an oriented surface
http://www.mrao.cam.ac.uk/~clifford/introduction/intro/node4.html
In three dimensions, there is only one vector perpendicular to a specified bi-vector (a specified oriented surface), the operation of going from a bi-vector to a vector is called "taking the dual".
The root link to the above is Imaginary numbers are not real which goes into Clifford algebras in great detail.
Thanks Pervect. I am a bit familiar with Clifford Algebra and already knew the last link. The first link looks very promising.
Well, after studying the relangmom.pdf document and Stingray's explanations I conclude that this is much more complex than I expected (and a bit over my head). Even my "Goldstein" mechanics has no more than about one page about it. Info is rare anyway. One of the reasons must be its non-inertial character that probably makes it belong to GR. Is this topic ever treated in graduate courses?
No I don't think so. That's a canard anyway; SR can perfectly well treat accelerating frames, even spinning ones. But the product of two boosts is a bost plus a rotation, which means that anything with a rotation in it is going to be more complicated math. See Thomas precession in almost any good text.
This topic is usually treated in GR courses to varying degrees. I think that Misner, Thorne, and Wheeler discuss it at length, for example. The emphasis is often different than the one I've written down, though.
It's a little difficult to say where to find things because angular momentum can be discussed from many different points of view. Depending on what you want to do with it, it might even be convenient to adopt completely different (and incompatible) definitions of the angular momentum tensor.
Anyway, I think that these things are not often discussed at length in SR books because almost all of them are very elementary. SR is usually only taught properly in GR courses (as a special case).
  • · Replies 0 ·
  • · Replies 30 ·
  • · Replies 0 ·
