First Law of Thermodynamics question
The discussion centers on the application of the First Law of Thermodynamics to a gas in a cylinder receiving 1600J of heat and having 800J of work done on it. The correct formula to calculate the change in internal energy (ΔU) is ΔU = Q - W, where Q is the heat added to the system and W is the work done by the system. In this scenario, since work is done on the gas, it is treated as negative, leading to a final calculation of ΔU = 2400J. This clarification resolves the initial confusion regarding the correct application of the formula.
  • Understanding of the First Law of Thermodynamics
  • Familiarity with thermodynamic concepts such as internal energy
  • Basic knowledge of heat transfer and work in thermodynamic systems
  • Ability to manipulate equations involving energy terms
  • Study the implications of the First Law of Thermodynamics in closed systems
  • Learn about the differences between work done on and by a system
  • Explore real-world applications of thermodynamic principles in engines
  • Investigate advanced thermodynamic cycles and their efficiencies
This discussion is beneficial for students of physics, engineers working with thermodynamic systems, and anyone interested in understanding energy transfer processes in gases.
in10sivkid
a quantity of gas in a cylinder receives 1600J of heat from a hot plate. At the same time 800J of work are done on the gas by outside forces pressing down on a piston. Calculate the change in thermal energy of the gas
Input heat Q = 1600J
The amount of work done on the gas is, W = 800J
now I'm not exactly sure how I'm supposed to set this up
do I use U = Q - W
or Q = W + U
so i either get 800J or 2400J for the answer for U
i know its a simple question but i think I'm just a bit confused conceptually. any help would be great :)
It should be [itex]\Delta U = Q + W[/itex], where Q is the heat input to the system and W is the work done on the system. In [itex]\Delta U = Q - W[/itex], W is the work done by the system.
do I use U = Q - W
or Q = W + U
you are correct.
it's the first form:
ΔU = Q - W,
where ΔU is the change in internal energy, Q is the heat added to the system, and W is the work done by the system. of course, when work is done to the system (like your problem), W is negative, so that -W is positive, resulting in an increase in internal energy (like your problem):
ΔU = (1600) - (-800) = 2400 J
check here for more info:
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/firlaw.html
  • · Replies 27 ·
