Ethanol Production Through Fermentation: Questions Answered
The discussion centers around the production of ethanol through fermentation, exploring various sources of sugar and cellulose, the fermentation process, and practical considerations for small-scale production. Participants raise questions about the types of materials that can be fermented, the efficiency of different sources, and the challenges involved in breaking down cellulose.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested, Experimental/applied
  • One participant questions whether ethanol is produced from sugar or cellulose, seeking clarification on the types of materials that can be fermented.
  • Another participant inquires about the specific organic substances that yield the most ethanol and whether certain additives can enhance fermentation rates.
  • A participant expresses interest in the feasibility of constructing a small fermentation plant capable of producing 20 gallons of ethanol per month within a limited space.
  • Questions are raised regarding the byproducts of fermentation, specifically what solid waste remains after the process.
  • Some participants highlight the challenges of producing ethanol from cellulose, particularly the difficulty in breaking down cellulose into fermentable sugars, noting that lignin complicates this process.
  • There is a suggestion that fermentation of paper could be a viable option since lignin is removed during paper production, though this is met with skepticism regarding the ease and cost-effectiveness of such an approach.
Participants express uncertainty regarding the best sources for ethanol production and the efficiency of different fermentation processes. There is no consensus on the feasibility of using cellulose or paper as primary materials for ethanol production.
Limitations include the unclear efficiency of various fermentation methods, the complexity of breaking down cellulose, and the potential economic viability of using paper as a fermentation source.
Individuals interested in biofuel production, small-scale fermentation, and the biochemical processes involved in ethanol generation may find this discussion relevant.
GiTS
I have read that ethanol is produced by fermenting sugar, but I do not know what kind. I also read ethanol is produced by fermenting cellulose, which is correct?
I've heard that ethanol can be produced from grass and newspaper, is there anything special you have to do to it?
What crop/organic substance produces the most ethanol or contains the most substance that can be fermented?
Is there anything I can add to increase the fermentation rate?
I want to make a small fermentation plant to produce 20 gallons per month, can this be done in a 10' cube?
Why don't ethanol producers simply recreate the chemical reactions yeast would do instead of the long process of fermenttion?
Chemistry news on Phys.org
What gets left behind after fermentation (solid waste)?
iansmith said:
You may want to look at this.
http://www.hort.purdue.edu/newcrop/ncnu02/v5-017.html
The major problem of producing ethanol from cellulose is the breakdown of cellulose into simple and useable sugar by the microorganisms.
According to that article the cellulose is incased in Lignin. The removal of the cellulose from the lignin is the hardest part. But all my encyclopedias and sources say that lignin is removed in the process of making paper , so wouldn't fermentation of paper be easy cheap?
  • · Replies 29 ·
15K
17K
9K
  • · Replies 17 ·
11K
