How Do You Derive the Volume of an n-Dimensional Sphere?
  • Thread starter Thread starter rocket
    Sphere Volume
The volume of an n-dimensional sphere, denoted as V_n(r), is established as V_n(r) = r^n * V_n(1), where V_n(1) can be derived using the formula V_n(r) = (π^(n/2) * r^n) / Γ(n/2 + 1). The discussion emphasizes the application of Fubini's theorem to set up integrals for calculating V_n(1) in terms of V_{n-2}(1). The bounds for the triple integral are defined as [-1, 1] for x and [√(1-x^2), -√(1-x^2)] for y, facilitating the derivation of the volume in higher dimensions.
  • Understanding of n-dimensional geometry
  • Familiarity with integration techniques, specifically Fubini's theorem
  • Knowledge of the Gamma function and its properties
  • Ability to perform change of variables in integrals
  • Study the derivation of the volume formula for n-dimensional spheres using integration and the Gamma function
  • Learn about Fubini's theorem and its applications in multiple integrals
  • Explore change of variables techniques in multivariable calculus
  • Investigate the properties of the Gamma function and its relationship to factorials
Mathematicians, physics students, and anyone interested in advanced calculus and geometric analysis, particularly those studying volumes in higher dimensions.
rocket
let [tex]B_n(r) = \{x \epsilon R^n| |x| \le r\}[/tex] be the sphere around the origin of radius r in [tex]R^n.[/tex] let [tex]V_n(r) = \int_{B_n(r)} dV[/tex] be the volume of [tex]B_n(r)[/tex].
a)show that [tex]V_n(r) = r^n * V_n(1)[/tex]
b)write [tex]B_n(1)[/tex] as [tex]I*J(x) * B_{n-2}(x,y),[/tex] where I is a fixed interval for the variable x, J an interval for y dependent on x, and [tex]B_{n-2}(x,y)[/tex] a ball in [tex]R^{n-2}[/tex] with a radius dependent on x and y. set up an integral to allow for use of fubini's theorem in order to find [tex]V_n(1)[/tex]in terms of [tex]V_{n-2}(1)[/tex].
for a), I assume that [tex]V_n(r)[/tex] is proportional to [tex]r^n[/tex]. So [tex]V_n(r) = C*r^n[/tex]where C is a constant. [tex]V_n(1) = C*(1)^n = C[/tex]. we have the equation
[tex]V_n(1) / V_n(r) = C / C * r^n[/tex]
[tex]V_n(1) / V_n(r) = 1 / r^n[/tex]
[tex]V_n(r) = r^n * V_n(1)[/tex]which completes the proof.
the only problem is, i don't know how to prove the assumption i used - that [tex]V_n(r)[/tex] is proportional to [tex]r^n[/tex]. I know that [tex]V_1(r) = 2 * r^1 = 2r, V_2(r) = \pi * r^2, and V_3(r) = 4/3 * \pi * r^3[/tex], which is how i guessed the assumption in the first place, but I don't know how to prove it holds true for [tex]V_n(r)[/tex]. I tried using induction but I don't know what is [tex]V_{n+1}(r)[/tex] in terms of [tex]V_n(r)[/tex]. My instructor suggested that we set up an integral and use a change of variables of some sort. I was wondering how would I set up an integral to find the volume of a sphere in n-dimensions.
i'm having a lot of trouble understanding b). the bounds of the triple integral would be as follows: the interval for x would be [-1,1] for a sphere centered on the origin, since we're dealing with a radius of 1. the interval for y would be [tex][\sqrt{1-x^2}, -\sqrt{1-x^2}][/tex]. But I don't understand how to derive the bounds for [tex]B_{n-2}(x,y)[/tex]. Also, how do we find what function over which to integrate?
I assume you're defining [tex]V_n(r)[/tex] as an integral over a volume, where r gives the radius. Fix n. Given r, you can recalculate the integral to be a constant times [tex]V_1(r)[/tex] by making a variable change [tex]x_k <= r x_k'[/tex] for [tex]1 \leq k \leq n[/tex]. The constant is your [tex]r^n[/tex] factor.
Carl
To prove that V_n(r) is proportional to r^n, we can use the formula for the volume of a sphere in n-dimensions, which is V_n(r) = \frac{\pi^{n/2}r^n}{\Gamma(n/2 + 1)}. This formula can be derived using integration and the change of variables method.
For b), we can use the formula for the volume of a sphere in n-dimensions and apply Fubini's theorem to set up an integral. We can write B_n(1) as the product of B_{n-2}(x,y) and the interval I*J(x), where I is the interval for x and J(x) is an interval for y dependent on x. The bounds for x would be [-1,1] and for y, we can use the equation \sqrt{1-x^2}, -\sqrt{1-x^2}. This can be derived using the Pythagorean theorem.
To find the function to integrate, we can use the formula for V_n(r) and substitute 1 for r. Then, we can use the change of variables method to convert the integral into a single variable integral in terms of x and y. This will give us an equation in terms of V_{n-2}(1), which we can solve for to find V_n(1) in terms of V_{n-2}(1).
  • · Replies 97 ·
  • · Replies 23 ·
