| Thread Closed |
Reports on web |
Share Thread | Thread Tools |
| Jul26-05, 04:41 AM | #1 |
Reports on web
We have a linux server and some win clients.
Our webbased accounting system is soppused to make reports in different formats like .DOC. The system is written in PHP. How can we generate that format? |
| Jul26-05, 08:55 AM | #2 |
Recognitions:
I did a google search to see if there was a program in php that could do the conversion but there are none. Doc is a closed format and unless your willing to put in time to reverse engineer the format then no. PDFs on the other hand can be generated on the fly as well as the Oasis (xml based) format used in Openoffice.
http://www.fpdf.org/ If your not going to sell this software your better off using: pdflib http://www.pdflib.com/ http://www.pdflib.com/products/pdfli...1-Linux.tar.gz |
| Jul26-05, 10:40 AM | #3 |
(I'm not familiar enough with PHP to see if these are directly applicable to you.)
Is .RTF acceptable? http://php9.bloghi.com/2002/07/23/us...-external.html http://www.phpbuilder.com/annotate/m...hp3?id=1011981 http://www.wlug.org.nz/RTF says "You can also give an RTF file a ".DOC" extension and then MicrosoftWindows users will be able to transparently open it in MicrosoftWord, blissfully unaware what format the file is actually in." Here's a start: http://jakarta.apache.org/poi/hwpf/index.html The following need a Windows machine. Maybe you could set up a local Windows machine (real or virtual?) that could serve your linux servers with the required files. http://schmidt.devlib.org/java/libraries-word.html points to: http://www.java400.de/Javactpe.htm "Java Bean Word Processing. Freeware. Read and write Word 97 and 2000 files. Needs a driver that runs only under Windows." Here's something in Python http://www.win32com.de/index.php?opt...173&Itemid=130 more from http://www.win32com.de/index.php?opt...=86&Itemid=130 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Reports on web
| What font should I use for lab reports? | Introductory Physics Homework | 1 | ||
| Scientific reports | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Lab reports | Academic Guidance | 0 | ||
| LAB Reports ... | General Discussion | 2 | ||
| Reports startegy! | Introductory Physics Homework | 2 | ||
