What is the Angular Acceleration of a Free-Rotating Rod at a Specific Angle?
The discussion focuses on calculating the angular acceleration of a uniform rod (mass = 2.0 kg, length = 0.60 m) free to rotate about a frictionless pivot. At an angle of 60 degrees below the horizontal, the angular acceleration can be determined using the moment of inertia and torque. The moment of inertia for a rod pivoting at one end is essential, and the torque is derived from the gravitational force acting at the rod's center. Applying Newton's second law for rotation allows for the calculation of angular acceleration as the ratio of torque to moment of inertia.
  • Understanding of moment of inertia for a rod pivoting at one end
  • Knowledge of torque and its calculation from gravitational forces
  • Familiarity with Newton's second law for rotational motion
  • Basic trigonometry to determine angles in rotational dynamics
  • Calculate the moment of inertia of a rod pivoting at one end
  • Determine the torque acting on a rod due to gravitational force
  • Apply Newton's second law for rotation to find angular acceleration
  • Explore the parallel axis theorem for moment of inertia calculations
Students studying physics, particularly those focusing on rotational dynamics, as well as educators and tutors seeking to clarify concepts related to angular acceleration and torque in free-rotating systems.
rlmurra2
A uniform rod (mass=2.0 kg, length=.60m) is free to rotate about a frictionless pivot at one end. The rod is released from rests in the horizontal position. What is the magnitude of the angular acceleration of the rod at the instant it is 60 degrees below the horizontal?
Please help! I really need this one!
You should show us your attempt to solve this problem, then ask for help
https://www.physicsforums.com/showthread.php?t=4825
In case you have no idea where to get started, you need to calculate the moment of inertia of a rod pivoting at one end. You might find that by looking it up, or by using the parallel axis theorem after looking up the moment of inertia of a rod rotating about its center. Then you will need to calculate the torque acting on the rod about the pivot point. This torque comes from the force of gravity acting at the center of the rod. Then you will use "Newton's second law for rotation" to find the angular acceleration as the ratio of the torque to the moment of inertia.
Please show some work, such as the appropriate formula for calculating angular momentum as a function of the position (angle) of a rod pivoting at one end.
  • · Replies 62 ·
14K
  • · Replies 22 ·
  • · Replies 25 ·
