Calculate the Electric Potential
The problem involves calculating the electric potential at a specific point due to a non-uniformly charged rod. The original poster is attempting to derive the potential using integration and has encountered discrepancies between their result and the expected answer.
  • The original poster discusses their integration approach and expresses confusion about their result compared to the expected answer. They also question their setup regarding the charge distribution.
  • Some participants suggest that the charge distribution is non-uniform and question the implications of this on the calculations.
  • Others propose an alternative integration method that may simplify the process and yield the correct result.
Participants are actively engaging with the problem, offering insights into the setup and integration methods. There is recognition of the complexity of the integral involved, and some participants express relief upon realizing their initial setup was correct despite the evaluation issues. Multiple approaches are being explored without a clear consensus on the best method.
The problem context includes a non-uniform charge distribution, which is a key factor in the calculations. Participants are also navigating the challenges of integrating with respect to different variables, which affects their results.
discoverer02
What am I doing wrong here?
Here's the problem:
For the arrangement descripbed in the previous problem (see attachment), calculate the electric potential at point B that lies on the perpendicular bisector of the rod a distance b above the x axis.
[lamb] = [alpha] x where [alpha] is a constant.
The correct answer is
V = -(k[alpha]L/2)ln(([squ] [(L^2/4) + b^2)] - L/2)/[squ] [(L^2/4) + b^2)] - L/2))
I'm not getting the same answer.
So far I've got the following: [the] = [<]'a' on the diagram.
V = kq/r
x' = btan[the]
dx' = bsec^2[the]d[the]
x = L/2 + x'
r = bsec[the]
dq = [lamb]d(L/2 + x') = [lamb]dx'
dq = [alpha](L/2 + x')dx' = [alpha](L/2 + btan[the])bsec^2[the]d[the]
so dV = k[alpha](L/2 + btan[the])bsec^2[the]d[the]/bsec[the]
Taking the integral of both sides from -[the] to +[the] doesn't yield the correct result.
I'd appreciate it if someone could point out where I went wrong. I have a feeling the problem's in [lamb] = dq/dL = dq(L/2 + x').
Thanks.
I forgot the attachment. Here it is.
How is that rod charged?
You say
dq = &lambda; dx' with
&lambda; = &alpha; x.
This would mean that the rod is NOT uniformly charged. Are you sure this is what the problem says?
Normally, problems like this have a uniformly charged rod, meaning
sth. like dq = &lambda; dx', where &lambda; is a constant.
The rod is not uniformly charged. [lamb] varies with x.
Small typo in the answer. Should be:
-(k&alpha;L/2)ln{( sqrt[(L2/4) + b2)] + L/2)/ (sqrt[(L2/4) + b2] - L/2)}
(the answer you posted equals 0)
Don't set it up in terms of the angle.
You want V = -k&int;dq/r
dq = &Lambda;dx and &Lambda; = &alpha;x
therefore:
dq = &alpha;xdx
and
r = sqrt(b2 + (x - L/2)2)
so your integral is
V = -k&alpha;&int; (xdx/(sqrt(b2 + (x - L/2)2)) from x=0 to x=L
It actually does work out. Happy integrating. :smile:
Thanks again gnome.
That integral is a royal pain!
I'm curious. What was wrong with the integral I was originally working with other than the fact that it might be easier integrating with respect to 'x' rather than the angle?
Actually, nothing. Shoulda done it your way.
dV = k&alpha;(L/2 + btan&theta;)bsec^2&theta;d&theta;/bsec&theta;
dV = k&alpha;(L/2 + btan&theta;)sec&theta;d&theta;
V = k&alpha;L/2 &int;sec&theta;d&theta; + k&alpha;b &int;tan&theta;sec&theta;d&theta;
V = k&alpha;L/2 {ln|sec&theta; + tan&theta;|}{from -&theta; to &theta;} + k&alpha;b{sec&theta;}{from -&theta; to &theta;}
The way you have defined theta, up at the top there, sec(-&theta;) = sec(&theta;) = (sqrt[L2 + 4b2])/(2b) so the second term of the integral drops out completely.
tan&theta; = L/(2b)
tan(-&theta;) = -L/(2b)
so the integral, evaluated from -&theta; to &theta;, becomes:
(k&alpha;L/2)(ln{(sqrt[L2 + 4b2])/(2b) + L/(2b)} - ln{(sqrt[L2 + 4b2])/(2b) - L/(2b)})
Play around with that a little & you get exactly the same answer.
Thanks.
It's a relief to know I set the integral up correctly. A stupid mistake on my part evaluating the integral turned into something it's not, so I thought I was going about it the wrong way.
