Why do oscillations occur around the equilibrium point?
  • Context: Graduate
  • Thread starter Thread starter dock
    Point
Oscillations around the equilibrium point can be explained using two fundamental laws: conservation of energy (E=FxR=const) and a modified interpretation of Newton's second law (Fxdelta(R)>0). The discussion emphasizes that force (F) and distance (R) are vectors, with their magnitudes and directions influencing oscillatory motion. The author illustrates that at maximum displacement from the equilibrium point, the force is zero, while at the equilibrium point, the force is at its maximum. This relationship is crucial for understanding oscillations in systems such as a mass on a spring.
  • Understanding of vector mathematics
  • Familiarity with Newton's laws of motion
  • Basic principles of oscillatory motion
  • Knowledge of energy conservation in physics
  • Explore the mathematical derivation of oscillatory motion using differential equations
  • Study the implications of energy conservation in mechanical systems
  • Learn about the dynamics of harmonic oscillators
  • Investigate the effects of damping and resonance in oscillatory systems
Physics students, mechanical engineers, and anyone interested in the principles of oscillatory motion and energy dynamics in physical systems.
dock
Around equilibrum point!
i chacked my books on periodical/oscilatory motion and this is what i found:
F=Fmaxcos(wt)
R=Rmaxcos(wt)
this is at best description how not explanation why oscilations take plase.by the way here I'm going to show that it's not quite right.
HERE IS MY WAY OF EXPLAINIG OSCILATIONS:
oscilations could be explained with only two laws
(1)E=FxR=const
and
(2)Fxdelta(R)>0
the news is that the bold are vectors.
F=the vector of the force positioned on y-axes
R=the distance from the object to the equilibrum point positioned on x-axes
E=energy positioned on z-axes
the first (1) is conservation of energy.
the second (2) is my substitution for the invalid Newton the 2nd.
the second (2) also states that the force and the displacement have same direction or the force is the reason for the contineuos displacement (never being at rest).here actually all the vectors are constant by norm/magnitude except the fact that E is also constant in direction while F and R are rotating around E.draw it in 3d.
in a case of "tunnel thru earth" scenario we project every vector on the y-axes (parallel with the force) and then:
F=Fmaxcos(wt)
R=Rmaxsin(wt)
E=0
this means that at the extreme distance from the equilibrum point the force is zero and at the equilibrum point the force is extreme.on the other hand we are sure that at extreme height from the center of the Earth in that scenario the force is extreme.that's why the equilibrum points are the most distant point from the centar of the earth.
while I'm here i'd like to stress that:
when the matter gets densed by the gravity pull, in order to make certain densed state a state of equilibrum it will have to release some energy (preferably thru an explosion) and what's more to it; an point of singularity creation takes release or infinite amount of energy.if no energy is being released then the matter will oscilate around the equilibrum point/state.
Thank you very much.
I LOVE THIS FORUM.
why there are no replies?
no one got any thing to say?
am i not clear enough?
assume you have an object hanging on a sping.when you are pull it down for x distance from the equilibrum point you can say that at the moment of releave the distance from the eqilubrum is max but then the force has to be zero.otherwise you can say that the force is max but then the distance has to be zero.
actually they are both right if you know where you project them.
if you project the F(orce) and the D(istance) on F direction then:
Fx=Fmaxcos(fi1)
Dx=Dmaxsin(fi1)
if you project the F(orce) and the D(istance) on D direction then:
Fy=Fmaxsin(fi2)
Dy=Dmaxcos(fi2) where fi2=-fi1
and then:
FxDy-FyDx=
FmaxDmax=Ez
there is no doubt that
Energy vector = Force vector x Distance vector.
the second law just gives the perpetual push.
  • · Replies 31 ·
10K
