Thread Closed
definition of simultaneity and on the relativity of lengths and times by a. einstein
Share Thread Thread Tools
Jul30-05, 01:56 AM   #1
§ 1. Definition of Simultaneity
Let us take a system of co-ordinates in which the equations of Newtonian mechanics hold good. In order to render our presentation more precise and to distinguish this system of co-ordinates verbally from others which will be introduced hereafter, we call it the "stationary system."
If a material point is at rest relatively to this system of co-ordinates, its position can be defined relatively thereto by the employment of rigid standards of measurement and the methods of Euclidean geometry, and can be expressed in Cartesian co-ordinates.
If we wish to describe the motion of a material point, we give the values of its co-ordinates as functions of the time. Now we must bear carefully in mind that a mathematical description of this kind has no physical meaning unless we are quite clear as to what we understand by "time." We have to take into account that all our judgments in which time plays a part are always judgments of simultaneous events. If, for instance, I say, "That train arrives here at 7 o'clock," I mean something like this: "The pointing of the small hand of my watch to 7 and the arrival of the train are simultaneous events.''
It might appear possible to overcome all the difficulties attending the definition of "time'' by substituting "the position of the small hand of my watch" for "time." And in fact such a definition is satisfactory when we are concerned with defining a time exclusively for the place where the watch is located; but it is no longer satisfactory when we have to connect in time series of events occurring at different places, or--what comes to the same thing--to evaluate the times of events occurring at places remote from the watch.
We might, of course, content ourselves with time values determined by an observer stationed together with the watch at the origin of the co-ordinates, and coordinating the corresponding positions of the hands with light signals, given out by every event to be timed, and reaching him through empty space. But this co-ordination has the disadvantage that it is not independent of the standpoint of the observer with the watch or clock, as we know from experience. We arrive at a much more practical determination along the following line of thought.
If at the point A of space there is a clock, an observer at A can determine the time values of events in the immediate proximity of A by finding the positions of the hands which are simultaneous with these events. If there is at the point B of space another clock in all respects resembling the one at A, it is possible for an observer at B to determine the time values of events in the immediate neighborhood of B. But it is not possible without further assumption to compare, in respect of time, an event at A with an event at B. We have so far defined only an "A time" and a "B time." We have not defined a common "time" for A and B, for the latter cannot be defined at all unless we establish by definition that the "time" required by light to travel from A to B equals the "time" it requires to travel from B to A. Let a ray of light start at the "A time" tA from A towards B, let it at the "B time" tB be reflected at B in the direction of A, and arrive again at A at the "A time" t‘A.
In accordance with definition the two clocks synchronize if
tB - tA = t’A - tB
We assume that this definition of synchronism is free from contradictions, and possible for any number of points; and that the following relations are universally valid:--
1. If the clock at B synchronizes with the clock at A, the clock at A synchronizes with the clock at B.
2. If the clock at A synchronizes with the clock at B and also with the clock at C, the clocks at B and C also synchronize with each other.
Thus with the help of certain imaginary physical experiments we have settled what is to be understood by synchronous stationary clocks located at different places, and have evidently obtained a definition of "simultaneous," or "synchronous," and of "time." The "time" of an event is that which is given simultaneously with the event by a stationary clock located at the place of the event, this clock being synchronous, and indeed synchronous for all time determinations, with a specified stationary clock.
In agreement with experience we further assume the quantity
2AB/(t’A - tA) = c
to be a universal constant--the velocity of light in empty space.
It is essential to have time defined by means of stationary clocks in the stationary system, and the time now defined being appropriate to the stationary system we call it "the time of the stationary system."
§ 2. On the Relativity of Lengths and Times
The following reflections are based on the principle of relativity and on the principle of the constancy of the velocity of light. These two principles we define as follows:
The laws by which the states of physical systems undergo change are not affected, whether these changes of state be referred to the one or the other of two systems of coordinates in uniform translatory motion.
Any ray of light moves in the "stationary" system of coordinates with the determined velocity c, whether the ray be emitted by a stationary or by a moving body. Hence
velocity = (light path)/(time interval)
where time interval is to be taken in the sense of the definition in §1.
Let there be given a stationary rigid rod; and let its length be l as measured by a measuring-rod which is also stationary. We now imagine the axis of the rod lying along the axis of x of the stationary system of co-ordinates, and that a uniform motion of parallel translation with velocity v along the axis of x in the direction of increasing x is then imparted to the rod. We now inquire as to the length of the moving rod, and imagine its length to be ascertained by the following two operations:
(a) The observer moves together with the given measuring-rod and the rod to be measured, and measures the length of the rod directly by superposing the measuring-rod, in just the same way as if all three were at rest.
(b) By means of stationary clocks set up in the stationary system and synchronizing in accordance with §1, the observer ascertains at what points of the stationary system the two ends of the rod to be measured are located at a definite time. The distance between these two points, measured by the measuring-rod already employed, which in this case is at rest, is also a length which may be designated "the length of the rod."
In accordance with the principle of relativity the length to be discovered by the operation (a)--we will call it "the length of the rod in the moving system"--must be equal to the length l of the stationary rod.
The length to be discovered by the operation (b) we will call "the length of the (moving) rod in the stationary system." This we shall determine on the basis of our two principles, and we shall find that it differs from l.
Current kinematics tacitly assumes that the lengths determined by these two operations are precisely equal, or in other words, that a moving rigid body at the epoch t may in geometrical respects be perfectly represented by the same body at rest in a definite position.
We imagine further that at the two ends A and B of the rod, clocks are placed which synchronize with the clocks of the stationary system, that is to say that their indications correspond at any instant to the "time of the stationary system" at the places where they happen to be. These clocks are therefore "synchronous in the stationary system."
We imagine further that with each clock there is a moving observer, and that these observers apply to both clocks the criterion established in §1 for the synchronization of two clocks. Let a ray of light depart from A at the time tA, let it be reflected at B at the time tB, and reach A again at the time t‘A.
Taking into consideration the principle of the constancy of the velocity of light we find that
tB - tA = rAB/(c - v) and t’A - tB = rAB/(c + v)
where rAB denotes the length of the moving rod--measured in the stationary system. Observers moving with the moving rod would thus find that the two clocks were not synchronous, while observers in the stationary system would declare the clocks to be synchronous.
So we see that we cannot attach any absolute signification to the concept of simultaneity, but that two events which, viewed from a system of coordinates, are simultaneous, can no longer be looked upon as simultaneous events when envisaged from a system which is in motion relatively to that system.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Thread Closed
Thread Tools
Similar Threads for: definition of simultaneity and on the relativity of lengths and times by a. einstein
Thread Forum Replies
lengths and times relative to S' and S Special & General Relativity 3
Einstein simultaneity: just a convention? Special & General Relativity 152
trying to understand relativity of lengths and times Special & General Relativity 31
definition of simultaneity Special & General Relativity 0
On the Relativity of Lengths and Times Special & General Relativity 4
