Why Add 33º to the Force Direction in Pool Ball Collision?
The discussion revolves around a physics problem related to momentum and impulse in the context of a pool ball collision. The original poster describes a scenario where a white ball collides with a colored ball, resulting in a deflection at a specific angle. The inquiry focuses on understanding the direction of the force exerted by the white ball on the colored ball, particularly the reasoning behind adding an angle to the calculated direction.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between the initial and final momentum vectors, questioning how to accurately determine the angle of the change in momentum. There are discussions about using vector triangles and the implications of angles in the context of momentum changes.
The conversation is progressing with participants sharing their reasoning and interpretations of the vector triangle. Some guidance has been offered regarding the correct interpretation of angles and the relationship between the vectors involved. There is an ongoing exploration of different methods to approach the problem, including the suggestion to use coordinate systems.
Participants note that they have been taught specific methods for solving these types of problems, which may limit their exploration of alternative approaches. There is also a mention of a diagram that illustrates the situation, which may aid in understanding the vector relationships.
shan
The situation: In a game of pool, the white ball of mass 0.35kg traveling at 5.0ms-1 collides with a colored ball and is deflected through an angle of 33º with a velocity of 4.3ms-1.
The question is a carry on (from questions about momentum and impulse) and is: What is the direction of the force the white ball exerts on the colored ball?
The answer is 87.8+33º to the original direction. I found the 87.8º but I don't understand why I have to add 33º to it. Can someone explain?
Rather than just give us your answer, why not show how you got your answer. Then we can take it from there.
Ok... the whole question is:
The game of pool requires the player to use the cue to hit the white ball so that it rolls towards and hits the coloured ball. The direction of the white ball must be such that it hits the coloured ball at an angle which makes the coloured ball roll into one of the pockets. The white ball will be deflected but must not roll into a pocket.
The white ball, of mass 0.35kg, is hit and rolls towards the coloured ball at a velocity of 5.0 ms-1. It collides and is deflected through an angle of 33° with a velocity of 4.3ms-1. Frictional forces acting to slow the ball can be assumed to be negligible.
[There's a diagram of the white ball traveling left, hitting the coloured ball and being deflected 33° upwards]
Q.1
Calculate the size of the change in momentum of the white ball.
-> p(initial) = 0.35 x 5 = 1.75
p(final) = 0.35 x 4.3 = 1.505
Using vector equation of p(final) - p(initial), the vector triangle looks like:
A triangle with it's apex on the bottom. The top side is p(initial) to the right. The left side is p(final) going up. The right side is change in p going up. p(final) makes a 33° with a horizontal line at the bottom.
Using cosine rule: change in p = 1.75² + 1.505² - 2 x 1.75 x 1.505 x cos33 = 0.95385
Q.2 What is the direction of the force the white ball exerts on the coloured ball during the collision?
-> Using the previous vector triangle, θ is the angle between p(final) and change in p:
sinθ/1.75 = sin33/0.95385
θ = 87.756 to the original direction
Hope that helps.
Excellent. Now we're cooking.
You did fine, but you are mixing up angles. First let's find the angle that the change in momentum (of the white ball) makes with respect to the original direction.
If I understand your triangle properly, you have: a horizontal arrow to the right (the original momemtum), another arrow dipping down at 33 degrees to the first (the final momentum), and the third connecting the two (the change in momentum). Note that the change vector points from the head of the original to the head of the final. For some reason you calculated the angle opposite the original momentum; instead, calculate the angle opposite the final momentum (call it theta). The angle that the change in momentum makes with respect to the original direction of the white ball will be 180 - theta.
Of course, the force that the colored ball exerted on the white ball will be in the direction of the change in momentum of the white ball. By Newton's third law, the force on the colored ball is equal and opposite.
Let me know if this helps.
That said, to keep the angles straight I would have approached the problem using an x & y coordinate system and then calculating components in each direction. I wouldn't have used the triangle rules. (Not that there's anything wrong with that!) :smile:
Maybe I should use an actual diagram...
http://www.boomspeed.com/mewmeow/momen.jpg
The top picture is what is happening/happened. The other one is the vector triangle. Could you explain what you were talking about again? ^^;
Hmmm x & y coordinate system... We've only been taught the triangle way to do things
Your triangle is fine, but you must interpret it correctly. It's a picture of Final - Intial = Change. I think you are forgetting that what you labeled as initial is really minus the initial. Now find the angle that the change makes with the original direction (which is horizontal to the left). You found the angle of the triangle opposite the initial vector: you have to add 33 degrees to it to get the total angle.
Bottom line: find the angle between the vectors not just the sides of the triangle.
Yay I get it now! Thank you so much
  • · Replies 24 ·
