Thread Closed
Carnot Cycle and Adiabatic process
Share Thread Thread Tools
Jul30-05, 02:28 PM   #1
I have a question regarding Carnot Cycles and Adiabatic processs.
I have cylinder with n moles of a mono-atomic gas with a specific Volume, Pressure and Temperature. This Cylinder is closed by a piston.
This system undergoes the four step Carnot Cycle A-B, B-C, C-D and D-A.
A-B: Is the adiabatic process where no heat gets in or out Q=0. What I'm required to do is to calculate the change in Pressure, Volume and Temperature. Any hits or idears on how I do that?
Is it something about calculating the work done by the gas? Which during the adiabatic process expands the initial volume. But does this also change the pressure and temperature of the gas too ?
Sincerley and Best Regards,
Bob
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jul30-05, 03:26 PM   #2
Thanks,
I will this out, and get back to You if the need more asistance.
/BOB
Jul30-05, 11:27 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by Bob19
You will have to use the adiabatic condition: [tex]PV^\gamma = constant[/tex]
AM
Jul31-05, 06:29 AM   #4
Hello again,
The mono-atomic gas is not specified. Therefore which [tex]\gamma [/tex] -value do I use ? 1.64 or 1.69 ??
/Bob
Quote by Andrew Mason
AM
Jul31-05, 08:03 AM   #5
Therefore which [tex]\gamma [/tex]-value do I use ? 1.64 or 1.69 ??
i believed that for mono-atomic gas we assume [tex]\gamma=5/3=1.67 [/tex]
Jul31-05, 02:58 PM   #6
Quote by Yegor
I have a second question.
As part of the carnot cycle I have the isothermical process D -> C, where
[tex]P_D = 711.3 \textrm{KPa} , V_D = 15.0 \textrm{L and} \ T_D = 584.43 \textrm{K}[/tex]
Since D and C are on the same path in the carnot cycle then according to theory T_D = T_C.
I'm required to calculate V_C from the data availible to me. Which formula do I use to calculate V_C ?
Sincerely
Bob
Aug1-05, 03:03 AM   #7
If A-B is adiabatic then C-D (or D-C) is also adiabatic.
Nevertheless, if both are isothermic, then you should use [tex]PV^\gamma = constant[/tex] for adiabatic and [tex]PV = constant[/tex] for isothermic.
I think that any parameter in point B or A must be given. Isn't it?
Aug1-05, 04:10 AM   #8
Since A and B are on the same path in the carnot cycle then
[tex]T_A = T_B[/tex]
I have reached the following point (where I'm stuck in my calculation of [tex]V_C[/tex] and [tex]P_{C}[/tex]
[tex]P_{c} * V_{c} = T_{c} \frac{P_{D} * V_{D}}{T_c}[/tex]
I get that [tex]P_{c} * V_{c} = 10671,5[/tex]
Can I use this result to obtain [tex]V_{C}[/tex] and [tex]P_{D}[/tex] ??
/Bob
Quote by Yegor
Aug1-05, 04:20 AM   #9
Or it was another problem???
I have reached the following point (where I'm stuck in my calculation of and
Can I use this result to obtain [tex]V_{C}[/tex] and [tex]P_{D}[/tex]??
Yes, you can use, but it isn't enough.
Do you realy have nothing more given?
P.S. How it's possible to quote? What is the right command?
Aug1-05, 04:55 AM   #10
Hello again,
Yes its a different part of the problem this time:
First I made a typoo:
Here is the right formula
[tex]P_{c} * V_{c} = T_{c} \frac{P_{D} * V_{D}}{T_D}[/tex]
I'm told that [tex]V_C = 24 \ Liters[/tex] but how thats derrived from the above result I'm a bit unsure of ?
/Bob
Quote by Yegor
Aug1-05, 05:12 AM   #11
May be you should use any results from another parts of the problem!?
If you have worked this out you should have some information about other points of the cycle.
Aug1-05, 05:15 AM   #12
I have data for D and A the volume in C but not other data.
So what do I do ?
BOB
Quote by Yegor
Aug1-05, 05:26 AM   #13
C-D and A-B are isothermic; and D-A and B-C - adiabatic.
Then [tex] V_C P_C= V_D P_D[/tex]
[tex] V_A P_A= V_B P_B[/tex]
[tex]P_D V_D^\gamma=P_A V_A^\gamma[/tex]
[tex]P_B V_B^\gamma=P_C V_C^\gamma[/tex]
Also use [tex]PV^\gamma = TV^{\gamma-1}=P^{1-\gamma}T^\gamma =constant[/tex] for adiabatic. Now you can calculate all data
Aug1-05, 05:29 AM   #14
Quote by Yegor
Hi,
Which of these formulas do I then use to calcualte V_c ?
/Bob
Aug1-05, 05:34 AM   #15
Hm. I think it's impossible. Imagine the P-V plot. You have two points D and A, as you told. There are no restrictions on where adiabata B-C intersects isothermas.
Aug1-05, 06:15 AM   #16
Sorry scratch that:
I have discovered that [tex]V_C = 24[/tex] is avalible in the text.
Sorry I missed that cause I'm suffering from terrible hayfever today.
I'm Sorry :-)
/Bob
Thread Closed
Thread Tools
Similar Threads for: Carnot Cycle and Adiabatic process
Thread Forum Replies
Carnot Cycle question Introductory Physics Homework 1
The Carnot Cycle Classical Physics 4
carnot cycle Introductory Physics Homework 1
Adiabatic Processes in the Carnot Cycle Classical Physics 2
carnot cycle Introductory Physics Homework 3
