Calculating the Speed of a Hopper Car After Dumping Coal
  • Thread starter Thread starter huskydc
    Car Coal Speed
The discussion revolves around calculating the speed of a railroad hopper car after it has dumped its load of coal. The problem involves concepts of momentum and the effects of mass loss on velocity in a physics context.
  • Participants explore the application of the conservation of momentum principle, questioning whether the speed of the car remains constant after the coal is dumped. There are discussions about the role of forces and momentum transfer during the coal's release.
The discussion is active with participants presenting differing viewpoints on the effects of coal dumping on the car's speed. Some suggest that momentum is conserved while others question the assumptions regarding forces and collisions. No consensus has been reached, but various interpretations of the problem are being explored.
Participants are considering the significance of the time duration over which the coal is released and its potential impact on the car's speed. There are mentions of the absence of a collision and the implications of the coal's downward movement on the overall momentum of the system.
huskydc
A railroad hopper car has mass 50000 kg when empty and contains 50000 kg of coal. As it coasts along the track at 10 m/s the hopper opens and steadily releases all the coal onto a platform below the rails over a period of 4 s.
How fast does the car travel after all the coal is dumped?
i applied the mv(initial) = mv (final) equation...
i got something like
(100000 kg) (10m/s) = (50000 kg) V final
apparently it's incorrect, any hints?
How is that incorrect? That should be exactly what you get. Now just solve for V.
Technically... shouldn't it travel the same speed? There wasnt a momentum transfer and there's no readily apparent force acting on the car.
It should pick up speed. The momentum changed. Think of it as a reverse inelastic collision.
But there is no collision, no momentum has changed because there's no force.
The only force I coudl see is if there was one generated by the coal which means a force of 125000 kg*m/s^2 was generated for 4 seconds... which still arrives at 20m/s for some reason... Well I am lost.
momentum is conserved, i kept getting 20 m/s
does the time, 4 sec matter in answering this question?
It has to... there's some sort of force acting here and I think this is where it occurs (at the 4 seconds). Did you put the whole question in the post?
There is no collision in an explosion (another reverse inelastic collsion), yet momentum changes.
An explosion?
When are the geniuses going to come to this thread and show us how this is actually done?
may i ask what explosion? or collision? the only thing happening is that the cart is dropping off coal..
Pengwuino said:
An explosion?
Because someone already had the right idea?
Unless the coal is getting launched backwards relative to the hopper car, the velocity does not change. If we assume that the downward movement of the coal is negligble, then the coal is moving at the same velocity as the car when it falls out of the car. A few moments later, it collides with the platform, but it is not longer connected to the train car at that point. The velocity of the car should be unchanged.
See that's what I am saying! I was waiting for someoen to come in and tell one of us that we were right because we had 2 different opinions on what was going on.
  • · Replies 27 ·
