What is the magnitude of the magnetic field at the center of the coil?
The discussion revolves around a problem involving a circular current loop and the magnetic field generated at its center. The original poster outlines a series of questions related to magnetic fields, magnetic flux, and induced electromotive force (emf) in a secondary loop placed within the magnetic field of the first loop.
  • Mixed
  • The original poster attempts to derive expressions for the magnetic field and magnetic flux, while also seeking clarification on how to apply Faraday's law to find the induced emf.
  • Some participants question the definitions of magnetic flux and the application of the product rule in differentiation.
  • Others suggest considering the area of the smaller loop and its relationship to the magnetic field when calculating flux.
Participants are actively engaging with the problem, exploring various aspects of magnetic fields and their effects on loops. Some guidance has been offered regarding the definitions and mathematical approaches, but there is no explicit consensus on the final steps needed to solve the problem.
The problem involves multiple parts, with specific assumptions about the constancy of the magnetic field over the smaller loop and the nature of the time-varying current. Participants are also navigating the complexities of calculus as they relate to the problem.
jaymode
Alright there is a problem I was given and it has four parts, I got the first two but am having trouble with the last two.
A)Consider a circular current loop of radius 10.5 cm with 200 total turns. Assume
that the current through the coil is I. What is the magnitude of the magnetic field at the center of the coil? (Your answer should be a numerical value multiplied by the current I).
B_center= [(4*pi*10^-7)*(200)*(I)]/(2*.105) = 0.001197*I
B A time-varying current of the form I(t)=Iosin(2*pi*f*t) is passed
through the circular coil in part a) where Io= 10 mA. Using your
result from a), write down the expression for the time varying
magnetic field B(t) at the center of the coil.
B_center(t) = 0.001197*(.01*sin(2*pi*f*t))
C A small 1.5 cm radius circular current loop is placed at the center of the large current loop from part a) (as shown in the photo) oriented so that the plane of the current loop is perpendicular to the magnetic field. Assume that the magnetic field from the large current loop is constant over the small loop. What is the magnetic flux through the small current loop (use your result from part b))?
This is where I do not know what to do and for the next part I do not really know what to do either.
D What is the total induced emf in the small current loop assuming that it has 2000 turns (use your result from part c))? The frequency of the time-varying current is f=1000 Hz. (Your answer should be in the form of a numerical value times a trigonometric function of 2*pi*f*t).
This requires you to know the definition of magnetic flux: Magnetic flux through a loop equals the area of the loop times the component of the magnetic field perpendicular to the area. (Your text can give you a more precise definition.)
This one requires understanding of Faraday's law, which states that induced emf is proportional to the rate of change of the flux through the coil and the number of turns in the coil. (For details, see your text or here: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html#c1)
Ok so the are of the loop. I would assume that the area of the loop is pi*r^2 with the radius being that of the smaller loop which is 1.5cm?
and for the last part ould it be taking the derivative of B and the derivative of the area? Then using the equation -N(d(BA)/dt) ?
That's right.
In that equation you are taking the derivative of BA. But A is a constant so [itex]d(BA)/dt = A \; dB/dt[/itex].
ok thanks. My math is a little rusty. right now I have B = 0.0000197*sin(2*pi*f*t)
if i remember correctly the derivative of this would be f'(x)*g(x) + f(x)*g'(x)?
What are you taking as f(x) and g(x)? That looks like the "product rule"; it's not clear to me how that will help here.
All I see is a constant times a sin function: [itex]a \sin (bt)[/itex], where a and b are constants.
Yes I was using the product rule. It has been a while since I last did derivatives so I need some refreshing. I was using a as f and the sin as G
But what I get from you is that the derivative would be:
bcos(bt)?
bcos(bt)?
Almost. Don't forget the constant "a".
