Finding Mass with a Lever: A Scientific Approach
  • Thread starter Thread starter deuterium
    Lever Mass
The discussion focuses on determining the mass of a meter stick using a lever system, specifically employing torque principles. The procedure involves balancing the meter stick on a fulcrum, using a known mass (100 g) and a mass hanger (16.5 g) to create a torque balance equation: mgd = MgD. By measuring the distances from the fulcrum and repeating the experiment at various points, users can accurately calculate the mass of the meter stick. This method emphasizes the importance of understanding center of gravity and torque in experimental physics.
  • Understanding of torque and its calculations
  • Familiarity with the concept of center of gravity
  • Basic knowledge of mass measurement techniques
  • Experience with experimental design and data collection
  • Study the principles of torque in physics
  • Explore the concept of center of gravity in various objects
  • Learn about experimental error analysis in physics experiments
  • Investigate different methods for measuring mass without scales
This discussion is beneficial for physics students, educators conducting hands-on experiments, and anyone interested in practical applications of torque and mass measurement techniques.
deuterium
i was given a lab to find the mass of a meter stick using only a lever. Here's what the writeup says:
Problem: Find the mass of a meter stick. (No cheaters, no scales!)
Materials: Fulcrum, a 100 g mass, a mass hanger of mass 16.5 g, fulcrum pivot, meter stick.
Procedure: You are completely on your own to come up with on this one. (Hint: Remember that the mass of the meter stick acts like it comes completely from the center of gravity.)
Not exactly sure where to start with this one, though i think that you need to use torque. Any help will be appriciated, Thanks.
You should be able to balance the meter stick on the fulcrumat the center of the meter stick. Then you should hang the mass on the meter stick and move the meter stick until it balances again. You can then balance the torques to find the mass -->
mass of meter stick = m
mass of hanger plus 100g mass = M
distance between fulcrum and center of meter stick = d
distance between fulcrum and M = D
Set up a torque balance equation and find that:
mgd = MgD
So, with M known, you measure d and D and calculate m. You should repeat the experiment a number of times with the mass at different points to get a good experimental measure of m. For example, you could hang the weight at 5 cm intervals. position it correctly, measure, and calculate.
Alright, i think i understand it now, thank you very much for the help.
  • · Replies 33 ·
23K
9K
42K
  • · Replies 30 ·
  • · Replies 31 ·
9K
