Chemistry Lab Help: Identifying Unknown Chemicals Using Solubility Rules
  • Thread starter Thread starter Markiss
    Chemistry Lab
The discussion revolves around a chemistry lab task where participants seek assistance in identifying unknown chemicals using solubility rules and precipitation tests. The specific chemicals in question are lead(II) nitrate, lithium carbonate, ammonium sulfate, and sodium chloride, with various solutions available for testing.
  • Homework-related
  • One participant expresses confusion about how to approach the lab task and requests help in developing a procedure for identifying the unknown chemicals.
  • Another participant suggests that precipitation tests are essential for identifying the unknowns and emphasizes the importance of reading the lab manual for guidance.
  • A later reply discusses the principle of adding one salt to a solution to observe precipitate formation, providing an example involving lead sulfate precipitation as a potential indicator for lead(II) nitrate.
  • Participants note that the results of various combinations of salts and solutions may be found in the textbook, implying that prior knowledge is necessary for successful execution of the lab.
Participants generally agree on the use of precipitation tests as a method for identifying the unknown chemicals, but there is no consensus on the specific results or procedures to follow, and some uncertainty remains regarding the details of the reactions.
Participants mention the reliance on solubility rules and textbook references, indicating that specific assumptions about the reactions and results may not be fully articulated in the discussion.
Markiss
I have a lab and have no clue what to do some help would be very usefull please! Here it is!
It has been a very hot weekend in the school. You have just walked into your chemistry room and have found 4 storage bottles with the labels fallen off. You must come up with a lab procedure to determine which chemical is in each storage bottle.
the four chemicals in the storage bottle are lead(II) nitrate, lithium carbonate, ammonium sulphate, and sodium chloride
there are the following solutions: sodium sulphate, sodium chloride, sodium carbonate, sodium phosphate, sodium hydroxide, calcium nitrate, lead(II) nitrate, barium nitrate calcium nitrate, copper(II) nitrate
I need to right a procedure to determine the identities of the unknowns. i need help asap! thanks a bunch
ps i teacher said that solubility rules wud come in handy!
Chemistry news on Phys.org
It looks like you need to do some precipitation tests. The cannon fodder of freshmen chemistry labs. My first advice to any lab student is to make sure you thoroughly read through the lab manual. Ninety nine times out of ten the answers are right there.
thts the lab, above, thts all tht was sent...:S its grade 11 so can u help me at all?
How these lab's work is, you add one salt to a solution and you get a tell tale result; for example, and this is going off of my memory, so it's entirely unreliable, if you add the lead salt to the sulfate solution you should precipitate out lead sulfate, which is bright yellow and very distinct. Therefore if you add one of your unidentified salts to the sodium sulfate solution and you get a bright yellow precipitate, then the unknown was likely lead nitrate. That's how these experiments work in principle. What the results are in each combination and permutation I don't remember or care to. But they're probably in your textbook and you shoud read it so you can properly do this lab.
THNX A bunch
peace yo
  • · Replies 18 ·
11K
  • · Replies 19 ·
11K
