Calculating Elongation of an Orange Spring
  • Thread starter Thread starter brayrbob
    Elongation Spring
The elongation of an orange spring with a spring constant of 14,000 g/s² when a 200-g mass is attached is calculated using the formula elongation = hanging mass * gravity / spring constant. By substituting the values, elongation equals 200 * 980 / 14,000, resulting in a stretch of 14 cm. This calculation confirms that the spring will extend by 14 cm from its original unstretched position, validating the accuracy of the method used.
  • Understanding of Hooke's Law
  • Basic knowledge of mass and gravitational force
  • Familiarity with unit conversions (grams to kilograms)
  • Ability to manipulate algebraic equations
  • Explore advanced applications of Hooke's Law in mechanical systems
  • Learn about the effects of different spring constants on elongation
  • Investigate the relationship between mass, gravity, and spring behavior
  • Study real-world examples of spring applications in engineering
Students in physics, mechanical engineers, and anyone interested in understanding the principles of spring mechanics and elongation calculations.
brayrbob
An orange spring has a spring constant of 14,000 g/s^2. How much should it stretch if a 200-g mass is attached from it?
I took the equation hanging mass * gravity=spring constant * elongation and turned it around for solving elongation
elongation = 200 * 980/14,000 = 14cm and I'm checking to see if this is the right answer.
Looks correct to me.
Your calculation is correct! The equation you used, elongation = hanging mass * gravity / spring constant, is the correct formula for calculating elongation of a spring. By plugging in the given values, you correctly determined that the orange spring should stretch by 14cm when a 200-g mass is attached to it. This means that the spring will increase in length by 14cm from its original unstretched position. Great job!
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 18 ·
