Convergence of the integral ln(sin(x))
The discussion revolves around the convergence of the integral \(\int_0^{\frac {\pi} {2}} \ln(\sin(x)) \, dx\). Participants explore the nature of this integral, noting that it is improper due to the behavior of \(\ln(\sin(0))\) and questioning the positivity of the integrand.
  • Participants discuss various attempts to analyze the integral, including comparisons with other integrals and the implications of the logarithmic function's behavior near zero. There are questions about the continuity and boundedness of \(\ln(\sin(x)/x)\) and the implications for convergence.
The discussion is active, with participants sharing insights and questioning each other's reasoning. Some have suggested focusing on specific intervals to analyze convergence, while others are exploring generalizations related to improper integrals. There is no explicit consensus yet, but several productive lines of inquiry are being pursued.
Participants note that the integral involves improper behavior at the lower limit and that assumptions about the positivity of terms in the integral are being questioned. The discussion includes references to the convergence of related integrals and the implications of function composition on convergence.
pbialos
I have to study the convergence of the following integral:
[tex]\int_0^{\frac {\pi} {2}}ln(sin(x)).dx[/tex]
My first attempt was to do the following:
[tex]\int_0^{\frac {\pi} {2}}ln(sin(x)).dx\leq\int_0^{\frac {\pi} {2}}ln(x).dx\leq\int_0^{\frac {\pi} {2}}x.dx[/tex]
But then i realized it was not an integral of positive terms, so my previous work was wrong.(This integral has all negative terms, right?)
I also realized that it is an improper integral, since [tex]ln(sin(0))[/tex] doesn't exist.
I really don't know what to do, maybe trying to express the series of ln, and sin, but i would really appreciate if you could point me into the right direction.
Thankfully Paul.
Thankfully Paul.
[tex]\log(\sin(x))=\log(x)+\log(\frac{\sin(x)}{x})[/tex]
log(sin(x)/x) will have no problems so focus attention on
[tex]\int_0^\frac{\pi}{2} \log(x) dx[/tex]
or for that matter
[tex]\int_0^h \log(x) dx[/tex]
for any h s.t. 0<h<pi
show
[tex]\int_0^{0^+} \log(x) dx=0[/tex]
This seems to be an example of the general case:
If:
[tex]\int_a^b f(x)dx[/tex]
converges, and:
[tex]a\leq g(x)\leq b\quad\text{for}\quad a\leq x\leq b[/tex]
Can we say that:
[tex]\int_a^b f[g(x)]dx[/tex]
also converges? I believe so but as yet cannot come up with a proof. Note that:
[tex]\int_0^1 ln(x)dx[/tex]
Converges and:
[tex]0\leq Sin[x] \leq 1\quad \text{for} \quad x\in [0,\pi/2][/tex]
Let me see if i understand: You said that log(sin(x)/x) doesn't have problems because it is a continuous and bounded function between 0 and pi/2 , and therefore converges, right?
On the second part of the integral:
i don't understand why you substituted pi/2 by h on the next step, instead of substituting 0 by h which is what i would have done.
Thanks you very Much, Paul.
It will work out the same since
[tex]\int_0^\frac{\pi}{2} \log(x) dx=\int_0^h \log(x) dx+\int_h^\frac{\pi}{2} \log(x) dx[/tex]
I like to focus on (0,h) because that is where the problem is. Others like to focus on (h,pi/2) since that is where there are not problems.
For your way just show that the limit h->0 exist.
and yes log(sin(x)/x) is good because it is continuous and bounded.
If:
converges, and:
Can we say that:
Converges and:
The problem is we have impropper integrals, so that will not be true in general
[tex]\int_0^1 \log(x) dx=-1[/tex]
conveges
0<exp(-1/x)<1
if x>0
but
[tex]\int_0^1 \log(e^{-\frac{1}{x}}) dx=-\int_0^1 \frac{1}{x} dx[/tex]
diverges
i get it
Thank you so much, i now understand this problem, and i could get
[tex]\int_0^{0^+} \log(x) dx=0[/tex] using parts integration.
Saltydog's generalization seems pretty interesting, at least to me, but i think he overused the same variables a and b for different meanings, am i right?
I will try to prove it later, with my little knowledge, but probably i will come back crying for help.
I really appreciate all your explanations.
Grateful, Paul.
edit: It seems I am so slow writing my messages that everytime i finish one, there is another one that i couldn't read.
Obviously i am not going to try to prove saltydog`s generalization now.
conveges
0<exp(-1/x)<1
if x>0
but
diverges
Alright Lurflurf. Thank you. I yield. May I have some defense: You used a composite of three functions, the second was the inverse of the first and the third was a function known to diverge in the interval. That is:
[itex]\int_a^b f[f^{-1}(g(x))]dx[/tex]<br /> <br /> This is equivalent to:<br /> <br /> [tex]\int_a^b g(x)dx[/tex]<br /> <br /> which diverges.<br /> <br /> Thus, perhaps a better phrasing might be if:<br /> <br /> [tex]\int_a^b f(x)dx[/tex]<br /> <br /> converges and g(x) is NOT the inverse of f(x), then the proposition holds. Might you suggest a counter-example for such?<br /> <br /> Thanks. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" /><br /> <br /> Edit:<br /> Perhaps a better wording would be:<br /> <br /> If:<br /> <br /> [tex]\int_a^b f(x)dx[/tex]<br /> <br /> converges, then under what suitable restriction imposed on g(x) will:<br /> <br /> [tex]\int_a^b f[g(x)]dx[/tex]<br /> <br /> also converge?<br /> <br /> Yes, I like that better and will spend some time on it.[/itex]
That was just a simple example. The problem is we are dealing with improper integrals. That is functions unbounded in the interval. Composing functions the way you suggest has a possibility of destryoying convergence.
say we are on (0,1) f is integrable but f diverges to infinity at 0. If we compose f with g where g is small often we can destry the convergence.
What you state will work if the functions are continuous and bounded, but not under conditions as weak as you desire.
The question was one of convergence, but this is one of those famous let's find the value for fun integrals.
[tex]I=\int_0^\frac{\pi}{2}\log(\sin(x))dx=\int_0^\frac{\pi}{2}\log(\cos(x))dx=\frac{1}{2}\int_0^\frac{\pi}{2}\log(\frac{\sin(2x)}{2})dx[/tex]
change variable u=2x in the last of these and breaking int(0,pi) into 2int(0,pi/2)
[tex]I=\frac{1}{2}\int_0^\frac{\pi}{2}\log(\frac{\sin(2x)}{2})dx=\frac{1}{2}\int_0^\frac{\pi}{2}\log(\frac{\sin(u)}{2})du[/tex]
then
[tex]I=\int_0^\frac{\pi}{2}\log(\frac{\sin(x)}{2})dx-\int_0^\frac{\pi}{2}\log(\sin(x))dx=\int_0^\frac{\pi}{2}\log(\frac{1}{2})dx[/tex]
so
[tex]I=\int_0^\frac{\pi}{2}\log(\sin(x))dx=-\frac{\pi}{2}\log(2)[/tex]
Ok. I'm beginning to see that now and how it's related to the convergence of improper integrals. How very interesting. I can imagine a set of functions:
[tex]S=\{g_i(x)\}[/tex]
and the integral:
[tex]\int_a^b f[g_i(x)]dx[/tex]
for which the integral of f(x) converges. I can envision a range, a spectrum, for which convergence becomes slower and slower (the integral grows larger and larger) until convergence is abruptly lost or lost gradually? I'd be interested in studing how convergence and the loss of such is affected by S. That is, it's as if S is an operator operating on the integral. How then is convergence affected by different S? Suppose it's a question for Functional Analysis. Lots of questions but I better get out now before I interefere too much with real homework questions.
Thanks Lurflurf. :smile:
  • · Replies 21 ·
