Motion of a mass on a spring suspended vertically
The discussion focuses on calculating the spring constant for a spring made from a steel/titanium alloy when a 500 g mass is suspended from it, resulting in an oscillation period of 1.00 seconds. The system mass is determined to be approximately 516.67 g, which includes one-third of the spring's mass. The relevant formula used is T^2 = (4π²m)/k, leading to the rearranged equation k = 4π²/T². The calculated spring constant is approximately 20397.82 N/m.
  • Understanding of harmonic motion and oscillation principles
  • Familiarity with the formula for the period of a mass-spring system
  • Basic algebra for rearranging equations
  • Knowledge of units of mass and spring constant (N/m)
  • Study the derivation of the period formula for mass-spring systems
  • Explore the effects of different materials on spring constants
  • Learn about damping and its impact on oscillation periods
  • Investigate the applications of springs in engineering and design
Physics students, mechanical engineers, and anyone interested in the dynamics of oscillatory systems and spring mechanics.
brayrbob
Okay I have part of this problem right but am not sure how to proceed on the last part.
A 50 g spring is made from a new steel/titanium alloy. Engineers determine that if a 500 g mass is hung from the spring it oscillates with a period of exactly 1.00 seconds. What is the spring's constant?
Equation used is = system mass = hanging mass + (1/3) spring mass
system mass = 500 + (1/3)50 = 516.6666667
Now I have to use the equation Period^2 = 4pi^2 system mass/spring constant.
I have to solve for mass and don't know how to turn this last equation around.
You start with this:
[tex]T^2 = \frac{4 \pi^2 m}{k}[/tex]
To solve for the spring constant, try this: First multiply both sides by [itex]k[/itex], then divide both sides by [itex]T^2[/itex]. That will isolate k.
So then that equation should be k = 4pi^2/T^2?
4pi^2(516.6666667)/1.00^2 = 20397.8243 is the spring constant?
  • · Replies 31 ·
