What is the Taylor expansion for 1/(1-exp(-1))?
The discussion centers around finding the Taylor expansion for the function \( \frac{1}{1 - \exp(-1)} \). Participants are exploring the application of Taylor series in this context, particularly focusing on the expansion of functions involving exponential terms.
  • Participants suggest using long division to derive a Taylor series for \( f(x) = \frac{1}{1-x} \) and substituting \( x = \exp(-1) \). There is also a discussion about the nature of the Taylor expansion for constant functions and the implications of the original question's clarity.
Some participants have provided guidance on how to approach the problem, while others are questioning the clarity of the original question. Multiple interpretations of the problem are being explored, particularly regarding the intent behind seeking a Taylor expansion.
There is an indication that the original question may have been unclear, leading to different interpretations of how to apply Taylor expansions in this scenario. Participants are also discussing the implications of expanding a constant function.
Callisto
Hi
How do you expand
(1-exp(-1))^-1
as Taylor series
Callisto
Try long division to get a Taylor (or McClaurin) series for f(x) = 1/(1-x) for a start.
Then put x=exp(-1) into that series, and there you go!
Taylor series for
1/(1-x) = (1-x)^-1 = 1 + x^2 + x^3 + x^4 +...= SUMi x^i
Then sub in exp(-1) for x
That's it?
Yes. That's it.
Cheers James R!
a constant has a trivial Taylor expansion
The expression you submitted is a constant, it doesn't depend on x.
All derivatives of this function with respect to x (the assumed variable) are zero.
Therefore the Taylor expansion contains only one term (and is exact):
f(x) = 1/(1-exp(-1)) + 0 + 0 + 0 + 0 + 0 + 0 + ... = 1/(1-exp(-1))
(unless you did not formulate your problem correctly)
Technically, you're right of course, lalbatros, but your solution doesn't seem to fit the spirit of the question which was asked. Maybe the question was a little unclear, though...
You are probably right James.
The question probably was: "how can I get an approximate value for 1/(1-exp(-1)) using Taylor expansions".
Then, there are numerous ways to choose how to expand.
For example:
1/(1-exp(-x)) = 1 /(1-sumi((-x)^i / i!))
or explicitely:
1/(1-exp(-x)) = 1/(x-x^2/2+x^3/6-x^4/24+x^5/120 ...)
