Where can I find the image charge for a point charge near conducting surfaces?
The discussion revolves around the concept of image charges in electrostatics, specifically involving a point charge near conducting surfaces. The original poster presents two problems: one involving two semi-infinite grounded conducting planes and another involving a conducting sphere.
  • Participants explore the concept of image charges, questioning how many images would be formed in the case of two mirrors and discussing the necessity of opposite signs for image charges to maintain zero potential at the surfaces. The original poster attempts to apply this reasoning to their specific problems, particularly in determining the locations of image charges.
Some participants have provided insights into the first problem, suggesting that the original poster's reasoning about the number and positions of image charges is likely correct. However, there remains uncertainty regarding the second problem with the conducting sphere, as the original poster seeks further clarification on exploiting symmetry.
The original poster mentions that an image charge will produce zero potential together with the real charge, indicating an understanding of the fundamental principle behind image charges. There is also a note about the symmetry involved in the problems, particularly for the conducting sphere.
Reshma
Someone's got to help me on these two.
1)Two semi-infinite grounded conducting planes meet at right angles. In the region between them, a point charge q is kept such that it is at a distance of 40cm from each of the two planes[i.e.(40,40)]. Find the position of its image charge/charges.
2)A point charge q is placed in the vicinity of a conducting sphere. Find the poition of its image charge.
Just in case...An image charge will produce zero potential together with q.
Have you thought about what the optical image(s) would be if you placed an object in the symmetry plane between two mirrors at right angles? How many images would be formed, and where would they be? For charges, image charges must have the opposite sign to have constant (zero) potential at the surface. When multiples surfaces are involved there can be images of images, just as there are for optical images.
Thank you very much! I think this solves my first problem.
Since my charge is located in the 1st quadrant, I should have one image charge in each of the other three quadrants(total=3). So by your explanation my image charges are located at (-40,40), (-40,-40), (40,-40). Is my answer correct?
However in the 2nd problem, I don't know how to exploit the symmetry for the sphere. Can you help me on that?
Can someone help?
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 19 ·
