What Are the Inverse Elements in Z_7 and Z_13?
  • Thread starter Thread starter Benny
    Definition
The discussion focuses on identifying the multiplicative inverses in the modular arithmetic systems Z_7 and Z_13. It concludes that all non-zero elements in both Z_7 and Z_13 have multiplicative inverses due to the primality of the moduli. Specifically, Z_7 has 6 elements with inverses (1, 2, 3, 4, 5, 6) and Z_13 has 12 elements with inverses (1 through 12). The key principle applied is that for a number n in Z_m, it has a multiplicative inverse if and only if gcd(m, n) = 1, which holds true for all elements in these prime modulus systems.
  • Understanding of modular arithmetic
  • Familiarity with the concept of multiplicative inverses
  • Knowledge of prime numbers and their properties
  • Basic skills in calculating the greatest common divisor (gcd)
  • Study the properties of multiplicative inverses in modular arithmetic
  • Learn about the Extended Euclidean Algorithm for finding inverses
  • Explore the applications of modular arithmetic in cryptography
  • Investigate the structure of other modular systems, such as Z_15 and Z_17
Mathematicians, students studying number theory, and anyone interested in modular arithmetic and its applications in cryptography and algebra.
Benny
Hi I'm not sure what the following two questions (actually there are a few more but if I know how to do the following the others should be ok) is asking for.
In the following systems Z_n, write down the sets of elements that have inverses. ( (n) is equal to the number of elements in these sets.)
a) Z_7
d) Z_13
The answers to 'a' and 'd' are 4 and 12 respectively.
The question asks for "the sets of elements that have inverses" but 4 and 12 are just numbers, so how can they be the answers to the questions? I learned that if a number n(bar) is in z_m then n(bar) has a multiplicative inverse iff gcd(m,n) = 1 but I'm not sure how to apply this here. Can someone help me with this?
I assume the problem is asking for "multiplicative" inverses, since all elements have additive inverses.
Problem (a) is asking for all elements of Z7, n, such that there is some m in Z7 so that mn= 1 (mod 7). One "brute strength" method is took look at every possible number: there are only 6 possibilities. One obvious answer is always "1".
What about 2? Is 2a= 1 (mod 7) for any a? That is, is there a number a such that 2a is of the form 7n+ 1 for some n? Again, an obvious candidate is "4": 2(4)= 8= 7+ 1. 2 has a multiplicative inverse: 4.
What about 3? Is 3a= 1 (mod 7)? 3(2)= 6, 3(3)= 9= 7+2, (3)(4)= 12= 7+ 5, 3(5)= 15= 2(7)+ 1. 3 has a multiplicative inverse: 5.
Of course, 4 has a multiplicative inverse: 2.
Of course, 5 has a multiplicative inverse: 3
That leaves 6. 6*6= 36= 5(7)+ 1. 6 is its own multiplicative inverse.
Every number in Z7 has a multiplicative inverse.
The key point is that 7 and 13 are both prime numbers. " if a number n(bar) is in z_m then n(bar) has a multiplicative inverse iff gcd(m,n) = 1". If n is prime then,
gcd(m,n)= 1 for every number less than n except 0.
The set of all elements of Z7 and Z13[/b] are just the elements of Z7 and Z13 except 0.
Thanks for the help HallsofIvy. The use of the theorem that you mentioned didn't come to me as I was working through the questions but it's good that you've mentioned it. I'll try to keep things like that in mind in future.
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 16 ·
