Commutators and solvable groups
This discussion focuses on the concepts of commutators and solvable groups in group theory. The commutator of a group G is defined as ABA^-1B^-1, and a group is considered solvable if its derived series eventually reaches the trivial group. The Heisenberg group of 3x3 upper triangular matrices is identified as two-step solvable, while the general linear group GL(2,R) is demonstrated to be non-solvable due to its inclusion of the simple group SL(2,R). The discussion also highlights the distinction between solvable and nilpotent groups, emphasizing the necessary conditions for each.
  • Understanding of group theory concepts, specifically commutators and derived series.
  • Familiarity with the Heisenberg group and its properties.
  • Knowledge of the general linear group GL(2,R) and its structure.
  • Basic understanding of nilpotent groups and their definitions.
  • Study the properties of the Heisenberg group and its derived series.
  • Learn how to compute commutators in various groups, specifically upper triangular matrices.
  • Investigate the structure of the general linear group GL(2,R) and its subgroups.
  • Explore the differences between solvable and nilpotent groups in greater detail.
Mathematicians, particularly those specializing in abstract algebra, students studying group theory, and researchers interested in the properties of solvable and nilpotent groups.
JSG31883
I am not really clear on what is meant by commutators. I know that the commutator of G is ABA^-1B^-1, but I am not sure how to check if a group is solvable by having the commutator eventually equal the trivial group.
For example, I know that the Heisenberg group of 3x3 upper triangular matrices is two-step solvable, but am not sure how to SHOW that. I know that it means that the first commutator doesn't equal the identity matrix and that the second one does... but how do I show this?
Also, how do I show that the group GL(2,R) (2x2 invertible matrices) IS NOT solvable?
you need to describe the commutator, so do it. take two arbitrary matrices in the upper triangular matrices and work out the commutator. see what happens. now take the commutator of this with another generic element of the comutator, see what you get. as it happens it is clearer to see that the lie algebra is solvable.
example: upper triangular 2x2 matrices with 1 on the diagonals, what is the commutator or two elements?
[tex]\left(\begin{array}{cc} 1&a\\0&1 \end{array}\right)\left(\begin{array}{cc} 1&b\\0&1 \end{array}\right)<br /> \left(\begin{array}{cc} 1&-a\\0&1 \end{array}\right)<br /> \left(\begin{array}{cc} 1&-b\\0&1 \end{array}\right)[/tex]
well?
as for the second example, GL contains SL which is simple.
How can I show that the group G=<a,b,c> with [a,b]=b, [a,c]=1, [b,c]=1 is solvable but not nilpotent?
A group G is said to be nilpotent if G^i=identity for some i.
A group G is said to be solvable if it has subnormal series G=GncG3cG2cG1=identity... where all quotient groups are abelian.
