Understanding the Role of the Gauge in Expressing Field Situations
  • Context: Graduate
  • Thread starter Thread starter Observable
    Potential Scalar
The discussion centers on the role of vector and scalar potentials in describing electric fields, particularly in the context of radiation regions. Participants explore the implications of using these potentials and the concept of gauge in expressing field situations, touching on theoretical and conceptual aspects of electromagnetism.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants assert that the electric field in the radiation region depends solely on the vector potential, questioning the relevance of the scalar potential.
  • Others argue that this assertion is incorrect, noting that uniform electric fields can arise from well-defined scalar potentials, challenging the idea that scalar potentials can be ignored.
  • A participant highlights the divergence of the electric field in vacuum being zero, suggesting that this leads to a purely rotational field that necessitates the use of vector potential.
  • Another participant introduces the concept of gauge, suggesting that different gauges can express the same physical situation and that gauge choice helps manage the redundancy in the potential descriptions.
  • References to external sources and literature are provided to support claims regarding the relationship between electric fields and potentials.
Participants express disagreement regarding the role of scalar potential in the radiation region, with some asserting it is negligible while others maintain it is significant. The discussion remains unresolved, with multiple competing views presented.
Some claims depend on specific conditions, such as the presence of charges or the nature of the electric field being uniform or non-uniform. The discussion also reflects varying interpretations of gauge theory and its implications for potential redundancy.
This discussion may be of interest to those studying electromagnetism, particularly in advanced contexts involving radiation fields and gauge theory.
Observable
There´s an assertion that the electric field depends only on Vector potential in radiation region. But I couldn´t see clearly why the contribution of scalar potential could be comparatively ignored. Could anyone give me some explanations? Thanks!
well, radiation is nothing more than oscillating electric and magnetic fields, so let's look at maxwell's equations in vacuo...
div E = 0
div B = 0
curl E = -dB/dt
curl B = mu_0 epsilon_0 dE/dt
since the divergence of the electric field is zero (in vacuum), it is "solenoidal," that is, it's purely rotational, and in that situation, you can't use scalar potential--you have to use vector potential.
now it's in the same boat as the B-field! it's divergence is always zero (so long as we don't find any magnetic monopoles!), so it can't have an associated scalar potential.
...did that help?
now...i'm unsure of how the situation changes once charges are introduced. ...is that your question? :redface:
Just to point what seemed to me as an incorrect reasoning:
Uniform electric field has zero divergence and is consequence of a well defined scalar potential V(X,Y,Z) = kX, for instance.
DaTario
Aditionally, it seems that in the space betweem charges (which can be put very far apart) the field is neither uniform, nor can only be described by vector potentials.
DaTario
right! my mistake. :redface:
from pg. 43 of arfken and weber...
"If we have the special case of the divergence of a vector vanishing, the vector...is said to be solenoidal... When a vector is solenoidal it may be written as the curl of another vector known as the vector potential."
This is not true. It does depend on the scalar potential as well.
The separation of E in dV/dr and dA/dt is unfortunately often not given.
(Jackson doesn't show it for instance in Chapter 14 on Radiation by moving charges)
You can find the formulas online here:
http://fermi.la.asu.edu/PHY531/larmor/
see formula 15 for dA/dt and formula 16 for dV/dx. The dotted beta (v/c) is
the accelaration (a/c) which gives the radiation terms. You can simplify the
formula by setting beta itself to zero (v<<c).
You also should be able to find them here:
www.pas.rochester.edu/~dmw/phy218/Lectures/Lect_67b.pdf
At least when rochester.edu is back up again (maintanance?) at page 28.
Regards, Hans
I would like to introduce in this discussion the concept of "gauge". One seems to have some liberty of expressing the same physical situation with different formal expressions.
I once used the radiation gauge and, as I understand it, it represents one possible way of expressing field situations. V and A concepts provide some amount of redundancy, and this gauge choice is a way of fixing this redundant system of language.
Best Regards,
DaTario
  • · Replies 21 ·
  • · Replies 16 ·
14K
