What Is the Significance of Continuum Mechanics in Physics?
The discussion centers around the concept of continuum mechanics in physics, exploring its definition, significance, and the distinction between continuum and discrete materials. Participants delve into the implications of treating materials as continuous versus discrete, and the scale at which continuum mechanics is applicable.
  • Some participants define continuum mechanics as a branch that assumes a continuous distribution of material properties, typically without intrinsic length scales, though exceptions exist.
  • Others emphasize that continuum mechanics allows for the analysis of materials without considering their atomic structure, treating them as if they were continuous.
  • One participant highlights the versatility of continuum mechanics, noting its applicability across a wide range of size scales, from small quantities of liquid to large bodies like oceans.
  • A later reply discusses the limitations of continuum mechanics, suggesting that it is effective only when the continuum is large enough to ignore quantum effects, which may vary depending on the material's molecular composition.
Participants generally agree on the basic definition and significance of continuum mechanics, but there are nuances regarding the scale of applicability and the relationship between continuum and atomic structures that remain open to interpretation.
Some limitations are noted regarding the assumptions made about the size of the continuum and the neglect of quantum physics, which may vary based on the material in question.
chandran
What is continuum mechanics. What does the word "continuum mean"?
What is discrete?
Continuum mechanics is a branch where the material is considered to have continuous distribution of constitutive properties (material properties) and the whole modeling scheme is typically performed without intrinsic length scales (with some exceptions of course, but I'm thinking you're interested about the elementary end). Discrete is the reality material wise.
Yea - what PII said. You treat the material as if you didn't know it was composed of discrete (i.e separate) atoms.
The remarkable thing about continuum mechanics is the range of size scales over which it works - you can use the same mechanics to describe the behaviour of a few drops of water or a whole ocean.
Just adding or supplementing to whatever has been said... A continuum is basically the smallest possible chunk of stuff you can analyze without having to take atoms and molecules into account. Because the stuff in the universe cannot be cut in half an infinite number of times. We eventually get to a point when we're at the atomic level. So continuum mechanics works as long as you make the continuum large enough to neglect the quatumn physics involved in atomic level interactions. That being said, you can imagine the size of the contiuum for different materials will be different since they are made of different stuff in the molecular level.
