The title of the webpage could be: What is the speed of disentanglement?
  • Context: Graduate
  • Thread starter Thread starter ACG
    Speed
The speed of disentanglement between two entangled particles, A and B, has not been definitively established, with current understanding suggesting that the "signal" from A to B is effectively instantaneous, exceeding the speed of light (c) without transferring information. Discussions indicate that no upper limit has been discovered for the "speed of wave function collapse," with some measurements suggesting a value around 10c in the reference frame of the light source. The concept of superluminal action remains a debated explanation, contingent on interpretations of causality and non-local hidden variables.
  • Quantum entanglement principles
  • Wave function collapse theory
  • Reference frames in physics
  • Superluminal communication concepts
  • Research the implications of quantum entanglement on information transfer
  • Study the measurement techniques used in quantum mechanics, particularly those in the referenced arXiv paper
  • Explore the concept of non-local hidden variables in quantum theory
  • Investigate the relationship between wave function collapse and causality in quantum mechanics
Physicists, quantum mechanics researchers, and anyone interested in the implications of quantum entanglement and wave function behavior.
ACG
Speed of "disentanglement"
Hi! If two particles are entangled, A and B, and someone messes with A, have scientists determined the speed at which the "signal" that A has been messed with gets from A to B (so B reacts accordingly)? I read that they currently think it's infinitely fast and is permitted to exceed c because no information is transferred. However, at one point we thought light traveled infinitely fast as well. Have they actually proven that it's instantaneous (and if it is, in whose reference frame, if any)?
Thanks in advance,
ACG
to the extent of my knowledge, entanglement is spoiled with a rate which is in general the highest rate appearing in the system. This in situations involving atoms implies the polarization decay rate which is somewhat near the classical time on one turn of the electron around the nucleus.
Best Regards
DaTario
No upper limit has been discovered on the "speed of wave function collapse" for lack of a better term. No upper limit is anticipated, and this is not much of a burning question at this point. If you look at this well known http://arxiv.org/PS_cache/quant-ph/pdf/9810/9810080.pdf , they measure the value as about 10c in the reference frame of the light source.
Of course, there does not need to be any superluminal (FTL) action going on anyway. That is just one possible explanation of the facts, when you assume causes must precede effects or that there exist non-local hidden variables.
  • · Replies 45 ·
  • · Replies 30 ·
  • · Replies 48 ·
14K
