Heat current through a spherical shell
The discussion focuses on deriving the equation for total heat current through a spherical shell with inner radius 'a' and outer radius 'b', where the temperatures at the inner and outer surfaces are T2 and T1, respectively. The correct formula for heat current is established as H=4*pi*k*a*b*DeltaT/(b-a), which is derived from the integration of the area of the spherical shell. The heat flux is defined as -k*\nabla T, with \nabla T approximated by \frac{\Delta T}{\Delta r}. The geometric mean radius is also discussed as R = \sqrt{r_i r_o}.
  • Understanding of thermal conductivity and its role in heat transfer
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of heat flux and its mathematical representation
  • Basic concepts of spherical geometry and surface area calculations
  • Study the derivation of the heat conduction equation for spherical coordinates
  • Learn about the geometric mean and its applications in thermal analysis
  • Explore advanced integration techniques for varying area calculations
  • Investigate the implications of thermal conductivity in different materials
Students and professionals in physics, engineering, and materials science who are involved in thermal analysis and heat transfer calculations, particularly in spherical geometries.
Swatch
A spherical shell has inner radii a and outer radii b. The temperatures at the inner and outer surfaces are T2 and T1. The thermal conductivity of the shell material is k. I have to derive an equation for the total heat current through the shell.
The equation for heat current through a rod is H=k*A*DeltaT/L where L is the length of the rod.
For this sperical shell the area which is perpendicular to the flow of the heat is changing with the radius. So I have to integrate the area. Am I right here?
I have tried to integrate the area by doing:
A=integrate(4*pi*r^2) from a to b
But I end up with something far from the right answer, don't want to get into that.
Could anyone please give me a hint to this problem?
Thanks
The right answer is H=4*pi*k*a*b*DeltaT/(b-a)
Along the lines of the example H=k*A*DeltaT/L
the current is the area integral of the heat flux.
In general, heat flux is given by -k*[itex]\nabla T[/itex], and [itex]\nabla T[/itex] can be approximated by [itex]\frac{\Delta T}{\Delta x}[/itex], where x is the generalized length dimension.
In the case of the sphere, one would apply [itex]\frac{\Delta T}{\Delta r}[/itex].
Also the area midway between the inner and outer surfaces may be given the the 4[itex]\pi[/itex]*R2, where R = [itex]\sqrt{r_i r_o}[/itex], i.e. the geometric mean radius.
Properly integrating the problem should also give the same answer, but the limits of integration are not (a, b), since one is considering a spherical surface.
Thank you. :smile:
Just one question. How do you derive the mean of the radius?
