Point of inflection - always halfway between 2 critical points?
The discussion clarifies that a point of inflection is not always located halfway between two critical points in a cubic function, such as f(x) = 5x^3 - 2x^2 + 3x - 1. It emphasizes that while a point of inflection indicates a change in concavity, its position is determined by the second derivative and can occur independently of the critical points. The analysis concludes that the inflection point can exist at any location where the concavity changes, regardless of its proximity to critical points.
  • Understanding of cubic functions and their properties
  • Knowledge of first and second derivatives
  • Familiarity with critical points and their significance
  • Ability to analyze concavity changes in functions
  • Study the properties of cubic functions in detail
  • Learn about the relationship between first and second derivatives
  • Explore examples of points of inflection in various functions
  • Investigate the implications of concavity changes in real-world applications
Mathematicians, calculus students, and educators seeking a deeper understanding of the relationship between critical points and points of inflection in polynomial functions.
brum
point of inflection -- always halfway between 2 critical points??
when you look at the graph of a function
say, f(x) = 5x^3 - 2x^2 + 3x - 1
will the point(s) of inflection always be equidistant from 2 critical points (ie the 2 nearest critical points)?
point of inflection -- point where the concavity changes from up to down / down to up
critical point -- point where the function changes from increasing to decreasing or decreasing to increasing
Okay, this is about cubics. With any cubic you can do a linear transformation and produce a coordinate system in which the curve
a) passes through the origin and
b) is unicursal, it only passes through each coordinate line once, and
c) the part in the negative half of the plane is the reversed mirror image of the part in the positive half of the palne.
Now the cubic has at most two critical points and one inflection because its first derivative is a quadratic with two or no real roots, and its second derivative is linear with one root.
So take that one and only one inflection point. Where can it lie? Not in the negative half of the plane, because there's no second inflection point to match it on the positive side. And by the same reasoning not in the right half plane either. Therefore it lies on the y-axis, at x=0.
I think I'll leave the rest of the proof for you to finish.
No, the point of inflection is not always halfway between two critical points. While it is true that the point of inflection is where the concavity changes, it is not limited to being exactly halfway between two critical points. In fact, the point of inflection can occur at any point where the concavity changes, regardless of its distance from the nearest critical points. This is because the point of inflection is determined by the second derivative of the function, which can change at any point where the first derivative is zero. Therefore, the location of the point of inflection is not directly related to the location of critical points.
  • · Replies 22 ·
