Thread Closed
The four-stroke engine with rotary cylinder block
Share Thread Thread Tools
Aug14-05, 11:01 AM   #18
Recognitions:
Gold Membership Gold Member
When a thread comes in this way, I have nothing to do in it. It would take a face-to face conversation with you to make you realise I have never diminished or belittle those engines before hand. We do know what industy is. We do know that if industry people have a thing that works at least infinitesimally better than another one new, they will remain using the older thing, specially in aeronautics and automobiles. I don't know if the word "reacious" exists in english. To sum up, they are too reacious of changing things. I said those models don't work properly merely because they are waiting at the background, not because they simply don't work. I am not an expert at them, but some worse advantages must have in order to be rejected by companies. They hadn't rejected wankel model by the way, they tried it and they have realised about its defects. Diesel and Otto engines have been broaded studied. Maybe in the future, when the studies will be extended to those secondary models, they will get the foreground of the industry, but today they don't work as properly as Otto and Diesel engine. It's a trivial statement.
This is all what I am going to say about this stuff. I can seem very conserver for thinking so, but I only think logically and I don't believe in science fiction films. Anyway, I don't think this discussion benefites the OP, who will be staring at our dialogues with eyes wide open. Let's recover the main topic of the thread, please.
I have not read all his post, nor I understood it well. Can anyone tell me where is the spark plug? Is it rotating or is it steady on the outer cage?. Thanks.
Quote by Kenneth Mann
Let's see if I can understand. You can challenge others but can't be challenged back?
If I challenged the whole automobile industry, I apologize! I simply stated that those like the inventor face stiff obstacles, even when they have engines that are up and working (I don't think this one has a working engine - - - and would suggest that he get one). They are still ignored! and that has nothing to do with me. They would be ignored if I didn't exist; that's obviously not a conspiracy against me. I don't believe in conspiracies. They take too much work.
As far as reliability is concerned, some of those inventions are more reliable, than the Otto and Diesel cycles, and some are less reliable. That and a dollar will get the inventors a cup of coffee, but not much more. The simple fact is that the inventors face an uphill battle, no matter how good or how bad their inventions are. What I am begging you and others for, is to please not dismiss or belittle them beforehand. Give them a chance to prove themselves.
It sometimes takes longer, but not necessarily because of the science; because of the NIH Factor. A perfect case at point, the overhead cam arrangement used by almost all of Today's engines. Duesenberg had it in the 1920s. Ferrari had it in the 1950s, most European and Japanese cars had it in the 1960s and 1970s. The American makers finally discovered it in the 1980s, not because they wanted to but because they had to. How many studies had the Duesenberg people conducted. All we know is that their engines beat the pants off everybody else with their well studied engines. Give the little man a break! Don't reject new ideas out of hand! Keep an open mind, most won't work, but with a little open mindedness, a few will work well.
Actually, I suspect that their engines will encounter serious problems before it can be made to work. I just don't think that balance presents such a serious problem. The thermal/cooling problem that you mentioned earlier strikes me as much more serious. Also an even more serious problem that they face is that of port sealing. I don't see how they are going to achieve the compression ratios needed in an Otto/Diesel Cycle engine without a lot of development work and at great cost. Another problem is the one I brought up just earlier Today. Don't think I'm attacking you. I just ask that you cut the inventors a little slack. They'll need all they can get.
I don't understand. What hidden purpose is this? Remember, you made a few very broad encompassing statements. I just called you on them. Don't get yourself into a huff over it; just back-up what you said. Remember, for instance that you said the following:
This is just not true! Several of these engines have worked just fine. Others are still in development but that doesn't mean that they won't work. I'm asking that rather than knock these efforts, that you encourage them. Some will fall flat on their faces. Others will just be forgotten whether they work or not - - - just like the steam engines of the past (though some of those worked incredibly well). One or more of those though, with a little encouragement, might be just what the world needs. Give them a break! With regard to the idea initially proposed in this string, I remind you of the following:
Before passing judgement, give them a chance to prove themselves. You state that the 'centrifugal turning' will be a problem. I cannot agree. There have been too many such engines with this characteristic that worked very well. I see no problem with this rotational characteristic itself, except that it will make the input and output ports difficult to seal (much like the Wankel). I am very sorry if you took it personally.
KM
Aug14-05, 11:20 AM   #19
Recognitions:
I have realised some problems about this design (sorry man, but if you have posted your invent here, our main mission is to bring you down to the floor ):
i) the performance in exhaust and intake flow is very studied in traditional engines. I don't see how the combustion chamber can swallow air during the rotation. What kind of valves shape would you use?. When the combustion chamber is nearly to end the open angle for intake, the effective shape of the intake duct will be very strange, with a great loss of pressure due to it. I am not able to explain it better, but imagine just the moment when the intake valve is opened and the cylinder block wall approaches it. Also, it would be a complex flow induced by the rotation of the chamber. The nature of this initial flow have a GREAT impact on the combustion process. So a further study will be needed.
ii) combustion process: despites the flow induced by the intake, the combustion process is going to be necessarily influentiated by rotation. Firstly it will be a great cummulation of gasoline near the spark plug, because it is a weighter component. This could be a good thing indeed. It is a great mechanism of producing an stratified mixture and avoiding the effects of flame failure near walls. But what affraid me most is the fact of the spark plug being attached to the outer casing. The plug needs a portion of mixture which initiates the premixed flame. In Otto-Diesel engines, the flame can advance with certain grade of spherical symmetry, but in this engine both burnt gases and flame will be influentiated by the rotation, and by means of the rotation inertia both flame and burnt gas will be prone to remain in the most rearward wall facing the spinning, enhancing the wasting of a great amount of fuel.
Aug14-05, 11:28 AM   #20
Dont forget, Sir Frank Whittle had to practically BEG the british military to get funding to work on the jet engine during WWII, and even he was shot down a few times.
"While often regarded as the father of modern jet propulsion systems, the young Frank Whittle tried without success to obtain official support for study and development of his ideas. He had to persist his research on his own initiative and received his first patent on turbojet propulsion in January 1930."
Sadly, I agree with kennethman man. Even if his engine did work, I dont see it making much change, at least in the auto industry, unless it can provide benifits that are SIGNIFICANT in efficency. You gota remember, people are buying hummers that get 8mi/gal HIGHWAY, frankly, people in the auto industry really just DONT CARE. But I do think it could make it way to powering other devices, such as machines for factories etc. But then again, what company would want to pay retrain their technicians on how to service this new engine if it does not provide, ball park 20-30% efficiency. Its just cheaper to keep what does work and is the industry standard for so many years.
The ONLY car to use a wankel is the nissan. Some aircraft use them, due to the low vibration. But still, go check out any small airplane, its engine is a STANDARD opposed 4 or 6 cylinder. These engines have more vibration than a wankel, but any pilot will tell you that they simply cant afford to replace the seals on the end of the wankel that go bad much faster than the seals on a piston. For a wankel, you have to practically rebuild the engine every time those seals go bad. My little honda has 100k+ miles on it with the same seals. Its a matter of how much money one is willing to spend for the small benifits of a particular engine. Most likely, his engine would have to be used on something highly specialized, not generalized.
Oh, and as far as his picture goes, the only thing I see that could use changing is his pistons. Dont make them square, give them a radius of that circle, so on the compresson stroke, you dont have that wasted space. You can get a very high compresson, and possibly avoid the spark plug.
Aug14-05, 11:37 AM   #21
Recognitions:
Quote by cyrusabdollahi
Mazda's RX-8 uses a Wankel.
I share your sentiment about Whittle though, I think we all have something to learn from his story.
I didn't pick up that the pistons would be square! Why would they be square? How would square holes be sealed, or even bored and honed for that matter?
Have I missed something? Usually!
I anticipate that one of the problems encountered with this design would be effective sealing of the combustion chamber. Cylinder pressures under combustion are immense, and I'm having difficulty seeing a way to seal what would effectively be the cylinder head, since it's supposed to be able to move relative to the block. Kenneth, any more info on the related engines which have actually been made?
What do you mean about avoiding the spark plug? Compression ignition? Using a Diesel cycle rather than an Otto? I would imagine that that would have many problems of its own!
Aug14-05, 11:40 AM   #22
Recognitions:
Boy, do you know how to read????. I have little to say about all this stuff that has nothing to do with the design of the OP. Don't quote me again, if it is not relationed with the main purpose of this thread.
Aug14-05, 11:43 AM   #23
Sorry If i miss quoted you clausius. Do you think it would help to make those pistons have a curvature of the housing though? It should give you more compression.
If you look at the top of his piston, its flat. What Im saying is, why doesnt it have the radius of curvature as the cylinder wall. You can see the space inside there when its moved to top dead center because the cylinder wall is a curved circle and the piston head is flat. The pistons are round, but the head of the piston is pictured as being flat.
Aug14-05, 11:50 AM   #24
Quote by Clausius2
Then, I believe we are pretty much in agreement. Thanks for the clarification.
Quote by Clausius2
I'm not quite as optimistic as you about the good motives or lack of politics within the industry, but on this we can agree to disagree. The problem I see with waiting for a new idea to prove itself before it is accepted is the old chicken-egg problem. It won't be accepted until it has been proved, it can't be proved until it is thoroughly developed and tested, and it won't be developed and tested until it has been accepted by someone who can afford the cost of it. Thus many great ideas languish and die, unless they happen to be invented by someone with deep pockets, like Edison in his later years. You apparently have more faith in the natural goodness of humans than I do.
Quote by Clausius2
I concur. Maybe we can discuss some of the apparent problems, and possibly how they might be solved.
Quote by Clausius2
I think it is shown at the bottom of the casing. This would seem to be the logical place for it. It should not rotate, though with the (I think strange) double-rotation of the block and the crankshaft, I can't be sure. The drawings are very difficult to make out, we could do better with something clearer and easier to read. Maybe we should suggest that the author dedicate a site and put the information there.
KM
Aug14-05, 11:50 AM   #25
Recognitions:
Sorry, I am with very bad mood last days. My undergrad project doesn't work well.
Yes, I do think making such curved design would be better, but take into account that burnt and unburnt mixture could be accumulated in the edges of the pistion surface, because it would be a cooler and safer place to remain. Also a convex wall will influentiate combustion process in an unknown way. Combustion chambers have standard shapes which has been broadely experimentally tested. I am not able to predict the final performance when a change happens inside it.
Aug14-05, 09:24 PM   #26
Quote by Clausius2
I think this problem is solvable, but it will probably take work. Others have made somewhat similar designs and they have worked pretty well. The idea of a rotating radial engine isn't unique to this concept - - - what I see as different is their crankshaft arrangement, and I see problems with that, at least with the three-piston configuration. Look at how small the crankshaft is in comparison. I am afraid the power generated could twist that shaft like a pretzel. They can increase the block diameter, but that will add a lot of weight and waste a lot of space, unless maybe they can come up with more cylinders. I just don't know what the answer might be.
Quote by Clausius2
True, but I think it can be done simply because it has been done before, on similar designs.
And I think sealing this one will be one of the main problems they face in implementing an Otto Cycle engine, as is stated in the following:
Quote by brewnog
Right! Basically they have a cylinder (the block) rotating inside another cylinder (the outer wall), and there has to be clearance for this. Compression will leak out all around the 'tops' of the cylinder chambers. This is essentially the problem that the Wankel has had to handle for all these years. I have run across a couple of rotating chamber Axial-Rotary piston engines in the past. Unfortunately, the one most like the one in this string seems to be long lost. I have an old article on the other, but it differs in that the pistons operate in the opposite direction (Power stroke is out from the center).Mostly non piston engines with similar sealing considerations are:
1. The Wankel
2. The Veselovsky Rotary Otto Cycle Engine - - basically like a Wankel turned inside out. The semi-triangular part is the cavity in the casing, where the rotor inside is semi-elliptical - - just the opposite of the Wankel.
3. The Bricklin Axial (pistons move parallel to the axis) Rotary Otto Cycle piston engine
4. The Starrotor Brayton Cycle engine - - Basically solves the problem by ignoring it and accepting lower compression ratio (~ 6 to 1), Which they can do because it is a Brayton Cycle engine (which depends heavily on a large volume of air rather than high compression.
Thread Closed
Thread Tools
Similar Threads for: The four-stroke engine with rotary cylinder block
Thread Forum Replies
Crower's Six-Stroke Engine Mechanical Engineering 9
Wankel Rotary Engine Computing & Technology 19
Engine cylinder pressure Mechanical Engineering 15
Rotary Vane Engine Mechanical Engineering 3
Wankel Rotary Engine Lab Calculus 0
