Defining Maximum and Minimum Functions for Common Domains
The discussion revolves around defining maximum and minimum functions for various mathematical functions on a common domain. Participants explore how to express these definitions for specific functions such as sin(x), cos(x), and x, x^2, while considering the implications of their behavior over different intervals.
  • Some participants propose definitions for max(f,g) and min(f,g) based on conditions of f(x) and g(x) over a domain D.
  • Others argue that the behavior of functions like sin(x) and cos(x) will depend on the value of theta, indicating that the max and min functions are not constant across the domain.
  • A participant introduces an alternative formulation for max and min using absolute values, suggesting that max(f,g) = (f + g + |f - g|)/2 and min(f,g) = (f + g - |f - g|)/2.
  • There is a discussion on the intervals where one function is greater than the other, particularly for x and x^2, noting that x is greater than x^2 for values between 0 and 1.
  • Some participants seek clarification on how to apply these definitions to specific functions and whether analyzing the graphs is sufficient for determining intervals.
  • There is a mention of the continuity of the functions, which allows for the determination of intervals where one function dominates the other.
Participants express multiple competing views on how to define and analyze the maximum and minimum functions for the given examples. The discussion remains unresolved regarding the best approach to take for defining these functions across different intervals.
Participants highlight the importance of identifying points where functions are equal and the intervals where one function is consistently greater than the other. There is an emphasis on the continuity of the functions involved, which affects the analysis.
This discussion may be useful for students and practitioners in mathematics or related fields who are interested in understanding the behavior of maximum and minimum functions across different domains and intervals.
irony of truth
I want to let f and g be functions to be defined on a common domain D. Then the maximum and minimum functions are defined as follows for any x belonging to D...
max(f,g)(x) = f(x), if f(x) >= g(x)
max(f,g)(x) = g(x), if g(x) > f(x)
and
min(f, g)(x) = f(x), if f(x) <= g(x)
min(f, g)(x) = g(x), if g(x) < f(x)
How do I define my max(sinx, cosx) and min(x, x^2)?
think about it: when is cos greater than sin over the same domain? clearly the min and max functionals will depend upon the value of theta.
same for x and x^2 - clearly x is greater than x^2 for values less than 1, and less than x^2 for values greater than 1.
and
|f-g|=max(f,g)-min(f,g)
so
max(f,g)=(f+g+|f-g|)/2
min(f,g)=(f+g-|f-g|)/2
also the functions you are considering are continuous so if you find when they are equal, you can find which is greater on an interval where they are always not equal by considering any point in that interval.
for example
f=3x+2
g=2x-3
f=g->x=-5
so we consider
x<-5 then g>f
x>-5 then f>g
or we could try
max(f,g)=(3x+2+2x-3+|3x+2-(2x-3)|)/2
=(5x-1+|x+5|)/2
=(6x+4)/2=3x+2 x>-5
=(4x-6)/2=2x-3 x<-5
so
for example
f=3x+2
g=2x-3
f=g->x=-5
so we consider
x<-5 then g>f
x>-5 then f>g
or we could try
=(5x-1+|x+5|)/2
=(6x+4)/2=3x+2 x>-5
=(4x-6)/2=2x-3 x<-5
I want to know how you got |f-g|=max(f,g)-min(f,g)...
Also, will that example you posted be my guide to solve this? So, I have to say the interval in which the two functions are as designated...
quetzalcoatl9,
You mentioned that "think about it: when is cos greater than sin over the same domain? clearly the min and max functionals will depend upon the value of theta"
The graph seems to look like "lots of McDonald's M"
You also mentioned that "same for x and x^2 - clearly x is greater than x^2 for values less than 1, and less than x^2 for values greater than 1. "
x > x^2 when 0 < x < 1... not less that 1.. :D
x < x^2 when x > 1 or x < 0.
x = x^2 when x = 0 or 1.
Sine and Cosine are uniquely defined by their behavior on [0, 2pi ). So if you define the behavior of max(Sin(x), Cos(x)) on that interval, by extension you know what it looks like everywhere.
max(f,g)=min(f,g)->f=g
max(f,g)>=min(f,g)
so max(f,g)-min(f,g)>=0
and either max(f,g)-min(f,g)=f-g or max(f,g)-min(f,g)=g-f
hence
max(f,g)-min(f,g)=|f-g|
There are two easy ways to do these.
They are easy because the functions are continuous and because they are equal only on discrete sets. That is for every x such that f(x)=g(x) there exist a positive number h so that x is the only point of equality in (x-h,x+h).
Method 1: piecewise definition
here we aim to partition the real numbers into intervals and specify which function to use on the interval. ie
x<a
a<x<b
b<x<c
c<x
with f(x)=g(x) if x=a,b,c
so on any interval where f and g are continuous and never equal |f-g| never changes sign thus if f>g for any point in such an inteval f>g for all points.
method 2: absolute value
allow us to right out the min and max right away
sometimes further simplification is possible
sometimes we use this to give the min and max as piecewise defined functions
Hmm, thank you for the help...
If I were to define my function, can I just "plugged in" the f(x) and g(x) with their corresponding functions.. then just analyze the behavior of their graphs, of course, I will have to find those intervals?
max(sinx, cosx)
max(f,g)(x) = sinx, if sinx >= cosx
max(f,g)(x) = cosx, if cosx > sinx
max(sinx, cosx)
find out when sin(x)=cos(x)
then show sin(x)-cos(x) changes sigh at all of its zeros
then which function (sin(x) or cos(x)) is used in each interval can be found by finding which is used for any point in the interval
as has been said you can do any interval of length 2pi and then extend to all numbers.
is a fine definition
as is
max(f,g)(x)=(sin(x)+cos(x)+|sin(x)-cos(x)|)/2
but you probably what to express the conditions
sin(x) > cos(x)
cos(x) > sin(x)
in a more useful form
what properties of max(sin(x),cos(x)) do you want to highlight?
Ok... I got it... thank you for the help
