asdf1
- 734
if h=ln(absolute x)
then how do you calculate e^h?
The discussion revolves around the calculation of \( e^h \) when \( h = \ln(|x|) \). Participants explore the implications of using absolute values in logarithmic functions, particularly in the context of real and complex numbers, and how this affects the interpretation of results in differential equations.
Participants express differing views on the necessity of absolute values in the context of the logarithm and its implications for real versus complex numbers. The discussion remains unresolved regarding whether the absolute value is essential in all cases.
There are limitations in the discussion regarding assumptions about the domain of \( x \) and the definitions of logarithmic functions in different contexts (real vs. complex). Some participants reference specific mathematical steps that may not be universally applicable.
This discussion may be useful for students and practitioners in mathematics and physics, particularly those dealing with logarithmic functions, differential equations, and the nuances of real versus complex analysis.
VietDao29 said:It must be |x|. Have you ever seen:
[tex]e ^ {\mbox{something}} = \mbox{a negative number}[/tex]??
Viet Dao,
lurflurf said:yes
[tex]e^{\pi i}=-1[/tex]
What were the preceding steps? This type of thing happens a lot when what you were finding was the absolute value of something and droping it gives the something.asdf1 said:that's what i originally thought,
but the correct answer doesn't need absolute value...
i think that's strange...
Well, you can always take a numerical example if you're in doubt...:asdf1 said:that's what i originally thought,
TD said:Well, you can always take a numerical example if you're in doubt...:
[tex]\begin{array}{l}<br /> e^{\ln \left( { - 1} \right)} = - 1 \\ <br /> e^{\ln \left| { - 1} \right|} = 1 \\ <br /> \end{array}[/tex]
Again where how did this arise. One way absolute values often arise in arguments of logarithums is when one wants an antiderivative of a logarothmic derivative that is restricted to reals and valid almost every where.TD said:My example wasn't necessarily over the reals, I don't see why we'd have to exclude to complex numbers - at least not for this example which is only intended to show that abs values are needed.
So it was due to integrating a logarimic derivative.asdf1 said:Originally, I was trying to solve this problem:
dy/dx + ytanx = sinx, y(0)=1
The first step I did was to integrate tanx and then there came the absolute value dilema...
lurflurf said:So it was due to integrating a logarimic derivative.
Say you were to solve th associated homogeneous problem in preparation for variation of parameters.
y'+y tan(x)=0
y'/y=cos'(x)/cos(x)
log(|y|)=a+log(|cos(x)|)
|y|=|C||cos(x)| then let C absorb the sign
y=C*cos(x)
which is clearly a solution
of course if we were working with complex numbers we would never have introduced the absolute value. This problem arises though finding the function. It has nothing to do with the function itself.
What do you meanasdf1 said:that question seems to work, but in this question:
y`= -y/x, y(1)=1
the same problem arises, but the constant doesn't absorb the negative sign...
it's weird~
