Why the gravity is weaker in the poles than in the equator
  • Context: Undergrad
  • Thread starter Thread starter sea_wizard
    Equator Gravity Poles
The discussion centers on the differences in gravitational strength at the poles versus the equator, exploring theoretical explanations, misconceptions, and the implications of Earth's shape and rotation on gravity. It includes references to Newton's laws, relativistic effects, and the behavior of materials under gravitational forces.
  • Some participants propose that gravity is weaker at the equator due to the Earth's flattening and increased distance from the center of the Earth.
  • Others argue that if the Earth did not spin, gravity would be stronger at the equator due to a higher vertical column of Earth volume, but the centrifugal force from rotation lowers gravity at the equator.
  • A participant mentions relativistic effects as a factor in gravitational differences, presenting a formula that incorporates velocity and gravitational force.
  • One participant challenges a claim about gravity at the center of the Earth, stating that the gravitational field is zero there due to the balance of mass above and below.
  • Another participant emphasizes the importance of understanding physics concepts correctly, suggesting that misconceptions can arise from a lack of thorough learning.
Participants express differing views on the strength of gravity at the poles versus the equator, with some asserting it is stronger at the poles and others supporting the idea that it is weaker at the equator. The discussion remains unresolved with multiple competing perspectives.
There are unresolved assumptions regarding the effects of Earth's rotation, the implications of relativistic effects, and the interpretation of gravitational behavior at the center of the Earth.
sea_wizard
according to Newtons law since the Earth is flatten in the poles the distance to the center of the Earth is bigger in the equator and therefore its gravity is stronger there.
with this same argument you could say that if you got to the center of the Earth the distance tends to 0 and therefore the gravity tends to infinite, hummm
according to me if the Earth didnt spin the gravity should be bigger in the equator because the vertical column of Earth volume till the antipodes is higher there so there should be more gravity but when the Earth spins the centrifugal force lowers the gravity in the equator but not in the poles.
the reason for the eatrh to be flatenned in the poles is the same centrifugal force (wouldnt happen the same with a clay ball fast spinned)
my teacher explained me that Newton didnt say this but i know to be right
i meant that the gravity is stronger in the poles than in the equator
Also due of relativistic effects
Gm(1-(v/c)^2)^½/r^2 = g
At the scale of planets, you can often consider everything to be liquid. The forces involved are so large that the shear strength of materials isn't sufficient to overcome it.
Now, if you imagine the surface of the Earth as covered in water, and without tides, for a moment, you can see that the net force of gravity at the surface must be equal everywhere. Otherwise, there would be flow towards the- area of greater attraction- like the flow caused by the tides. So, the shape of the Earth effectively balances net surface force.
BTW: Since the internals of the Earth are not perfectly spherical, the surface of the oceans is not either. In fact, a survey of average surface of the ocean generates a map of the ocean floor.
This is actually backwards. At the center of the earth, the gravitational field is zero -- the mass above you exactly balances the mass below you, in every direction.
The rule to remember is that the only mass that effects you is the "interior mass," which is that mass within the sphere defined by the distance between you and the center of mass. Mass outside this sphere does not affect you gravitationally, because it is balanced on both sides. When you're on the surface, the entire Earth is within that interior sphere, so you have the maximum gravitational field strength. When you get the center of the earth, the interior volume is zero, so the interior mass is zero, hence there is no gravitational field.
- Warren
This is why it is best to actually make the effort to learn the physics rather than make a half-hearted attempt to understand it and then discard it due to misunderstanding it.
I think this is a pathology of smart people, so don't be upset (I have it too ): Sometimes you'd rather figure something out on your own than learn it from someone else, even though if you try to figure it out on your own you may reach the wrong conclusion.
  • · Replies 51 ·
  • · Replies 24 ·
  • · Replies 49 ·
  • · Replies 32 ·
  • · Replies 22 ·
